Old 30th May 2009, 12:50   #226
gpa
gpa's Avatar
Thanked: 282 Times
Originally Posted by 14000rpm View Post
the figures i quoted are for city drive only. on the highway i've been driving flat out so i couldn't expect more.
What is the best FE you have got thus far on the highway? Even with flat out driving and AC on fully, you can easily expect a FE in the range of 22 to 24 kmpl.
Old 30th May 2009, 13:15   #227
Thanked: 146 Times
Got my worst FE on my last highway drive to Bangalore - 15kmpl!!!
Agreed that I did some good speed, but this is not the first time. Highway driving always used to give me +18kmpl.
Need to check!
And also noticed that the vehicle was slightly struggling (with respect to previous drives) even at the Krishnagiri ghat up-slopes! :(
HappyWheels is offline   Reply With Quote
Old 30th May 2009, 15:52   #228
ASHISHPALLOD's Avatar
Thanked: 286 Times
And also noticed that the vehicle was slightly struggling (with respect to previous drives) :(
one year back, same thing happened with my alto. fe was going down day by day. it came to 13 km/ltr. newly opened maruti showroom engineer at baramati checked the car and suspected valve clearance problem. car was at 23rd month of ownership at 37500 km running. i mailed to maruti about this problem and sorted it out under warranty. fe came back to normal of 18-20 range.
ASHISHPALLOD is offline   Reply With Quote
Old 30th May 2009, 20:34   #229
Thanked: 146 Times
^^ Wow! That is bad! I hope and pray it is not that bad. I really do need to do a proper service within the next couple of weeks.
The change to fully synthetic is also on the card.
Vehicle is reaching close to 60k kms. Need to give the little guy some make over. Thinking....
Old 12th June 2009, 17:35   #230
Gansan's Avatar
Thanked: 914 Times
Is there no bottle test possible to check the FE of cars nowadays, like they do for the bikes? I remember doing such a test for my Dolhin car way back in 1995.
Old 12th June 2009, 19:16   #231
amit_mechengg's Avatar
Thanked: 1,556 Times
yes this technique is still used. i have seen it with MASS.
Old 13th June 2009, 18:03   #232
anky's Avatar
Thanked: 107 Times
Red face 12.5 to 13.5
I drive in peak hour traffic of bombay for 15 kms daily with 100% Ac on and my fuel economy never exceeds 13.5 kmpl.Tyre pressure is 28 psi and car serviced at mass every 6 months and petrol filled at same pump all the time.
anky is offline   Reply With Quote
Old 14th June 2009, 07:52   #233
gpa
gpa's Avatar
Thanked: 282 Times
anky,
you are running on very low air pressure, which is why your car's FE is suffering. The recommended air pressure for the Alto is 30 psi and not 28 psi. If you travel on good roads you can even increase it a notch or two to about 31-32 psi.
Make this change and you should see a marked improvement.
Cheers,
gpa
Old 14th June 2009, 07:59   #234
gpa
gpa's Avatar
Thanked: 282 Times
HW,
Yes, 15kmpl is on the low side for the little guy. Especially on the highway. Do check it at the 60k service. The change to fully synthetic will give you only a marginal improvement in FE, but will be great for engine performance and driveability You will have an eager revving engine that will love to be given the whip!!
Cheers,
gpa
Old 16th June 2009, 20:32   #235
14000rpm's Avatar
Thanked: 645 Times
Finally improving FE. I got 21 kmpl on my drive from BLR-ooty-BLR. 1 fuel stop strategy with no tyre changes (read no punctures). 1 tank of fuel took me to ooty and back. It was with restrained driving (80 kph) and thoughtful shifting.
It almost ended up running on fumes!!.
This is my car.
14000rpm is offline   Reply With Quote
Old 17th June 2009, 09:55   #236
gpa
gpa's Avatar
Thanked: 282 Times
Finally improving FE. I got 21 kmpl on my drive from BLR-ooty-BLR. 1 fuel stop strategy with no tyre changes (read no punctures) - Good strategy to do the trip on one pitstop, glad it worked out for you unlike for Ferrari where Massa had to slow down and let a few cars pass a few races ago just to get to the chequered flag ultimatley losing 3rd place
It almost ended up running on fumes!! - Do not run your car like this. Will lead to premature wear of the fuel pump and also cause problems for your engine due to improper fuel feed. Always ensure you tank up when ther is about 3 to 4 litres of fuel in the tank. The fuel is also used to keep the fuel pump cool.
Find my responses in bold. It is good to know that you managed to get a good FE on your trip and bear in mind this will improve as the car racks up the miles. BTW, nice pics, you have a well maintained car
Cheers,
gpa
Old 17th June 2009, 10:33   #237
Thanked: 286 Times
@14000rpm.--I got 21 kmpl on my drive from BLR-ooty-BLR. It almost ended up running on fumes
14000rpm, you told that got fe of 21 and lastly running on fumes. but odo pic says that 667.5km run. it means that either you got 19 fe or 3 lit of fuel in tank. i suppose the odo pic is at the end of your jorney. please clarify.
@gpa--Do not run your car like this. Always ensure you tank up when ther is about 3 to 4 litres of fuel in the tank
if 14000rpm really got 21 fe, then there should be at least 3 lit of fuel in tank.
Old 17th June 2009, 10:39   #238
Vid6639's Avatar
Thanked: 21,065 Times
The Alto fuel tank is 32litres. So 667.5kms and 21kmpl means 31.785 litres of fuel. Around 200ml left in tank but usually the car does take in more than 32 litres if you run it till the end.
Old 17th June 2009, 10:42   #239
gpa
gpa's Avatar
Thanked: 282 Times
Vid,
The owners manual specifies 35 litres as tank capacity. Well, atleast mine (May 2008) does. Do older Altos have a 32 litre tank?
Old 17th June 2009, 10:50   #240
Thanked: 146 Times
Mine says 35 liters of tank capacity (Feb 2005).
A/C and fuel economy & How to use aircon optimally. Lukeskywalker Technical Stuff 115 15th June 2014 12:09
Does Weather Affect Fuel Economy wolfinstein Technical Stuff 34 20th August 2009 00:57
A New type of engine -> NEVIS Engine, 2x Fuel Economy, 2 Stroke 2 Cyl 1000 cc 250hp 1Day Technical Stuff 16 2nd January 2009 18:24
Electronic ways of IMPROVING fuel economy Godfather Technical Stuff 8 1st October 2006 08:50
Tyre pressure vs fuel economy sbasak Technical Stuff 15 27th February 2006 23:31
