Old 17th June 2009, 10:59   #241
Vid6639's Avatar
Thanked: 19,375 Times
Then I guess it's 35litres. Don't know where I read 32 litres. Or maybe that's for the M800.
I haven't filled more than 31litres till date. These days I'm getting more than 14kmpl compared to the 13kmpl I used to get in city.
By the way, I just got my 30,000kms service done yesterday along with change to OWS synthetic oil. Will write a detailed report tomorrow after I get some niggling issues sorted out that popped up after service.
Old 17th June 2009, 11:09   #242
gpa
gpa's Avatar
Thanked: 273 Times
Vid,
I'm eagerly looking forward to the report, especially since you mentioned that you will be using OWS. Do you have a LTO report for your Alto or will you post it under the OWS thread here in the technical section?
Cheers,
gpa
gpa is online now   Reply With Quote
Old 17th June 2009, 11:20   #243
ASHISHPALLOD's Avatar
Thanked: 285 Times
looking forward to that report.
btw, as mentioned by others, alto fuel tank is of 35 lit.
sometimes, i get fe more than 20 and some times i get less than 18 on same road with same condition of driving.
ASHISHPALLOD is offline   Reply With Quote
Old 17th June 2009, 21:57   #244
14000rpm's Avatar
Thanked: 584 Times
Originally Posted by gpa View Post
Find my responses in bold. It is good to know that you managed to get a good FE on your trip and bear in mind this will improve as the car racks up the miles. BTW, nice pics, you have a well maintained car
Cheers,
gpa
"running on fumes" pun intended. thats what i thought when i pulled into the petrol bunk. Luckily it had took in only 32 ltrs. Hence, the FE turned out to be 21. (rounded).
I'm glad you call it well maintained. It does have blemishes deliberately omitted in pix.
Originally Posted by ASHISHPALLOD View Post
14000rpm, you told that got fe of 21 and lastly running on fumes. but odo pic says that 667.5km run. it means that either you got 19 fe or 3 lit of fuel in tank. i suppose the odo pic is at the end of your jorney. please clarify.
if 14000rpm really got 21 fe, then there should be at least 3 lit of fuel in tank.
The odo readings are from start of journey and end of journey.
There was 3 ltrs already in the tank which was quite surprising coz the fuel meter needle went below the red mark.
The Alto fuel tank is 32litres. So 667.5kms and 21kmpl means 31.785 litres of fuel. Around 200ml left in tank but usually the car does take in more than 32 litres if you run it till the end.
alto tank 35 ltrs.
14000rpm is offline   Reply With Quote
Old 17th June 2009, 22:16   #245
mail4ajo's Avatar
Thanked: 222 Times
My car never gave more than 16km/lt on highways. On a recent trip to Yercaud, I got 19.6kms/lt onward and 18.4km/lt return. I was surprised because I never went below 80km/hr and AC was running all the time. Odo reads 29,300 kms.
mail4ajo is offline   Reply With Quote
Old 18th June 2009, 08:12   #246
akroy's Avatar
Thanked: 29 Times
I guess you had changed you driving style . Also which petrol pump did you fill up? Fill there from next time onwards.
Abhi
akroy is offline   Reply With Quote
Old 18th June 2009, 09:16   #247
anky's Avatar
Thanked: 92 Times
Red face 12.5 to 13.5 again
Hi I would like to correct my last post that I fill my alto tyres with 30 psi and the car has a 35 lt tank. It goes upto red mark on guage at 30 lts and then ypo have 5 lt reserve.I have filled 32.5 lt at one time and the car had not stalled.I drive in city everyday (bombay) in peak traffic mostly 2nd and 3rd gears with ac on 100% and get a fe of 12.5 to 1.35 in my 04 lxi alto done 29000kms.All service at mass every 6 mts just got ingectors cleaned this time but no improvement.Any suggestions?
anky is offline   Reply With Quote
Old 18th June 2009, 10:56   #248
guys help me out....my car is a 2009 alto..it has run about 3700kms..until 2000kms i was getting an fe of 15kmpl..after which i am getting 9-10kmpl which is very low for an alto..i still have another 1300kms to go for the next service..should i give the car right now or wait until 5000kms???
shiv
shivred is offline   Reply With Quote
Old 18th June 2009, 11:51   #249
gpa
gpa's Avatar
Thanked: 273 Times
shiv
shiv,
Are you sure your car was giving you a FE of 15kmpl at such early stage? Just check your record again. Usually the FE stabilizes after the 5,000 kms mark and steadily improves till the 10,000 kms mark after which you tend do get the best FE figures. You can check the FE figures in my LTO report of my Alto.
As for the service, do not panic, get it serviced at the 5,000 kms mark. Change the engine oil and oil filter at the 5K service even though the SA will tell you that its good to run till the 10K mark. Keep a close eye on FE, if you still have a problem, you can go to a M.A.S.S to get it sorted.
Recently, I got a FE of 19.57 kmpl with very lightfooted driving in the city with only minimal use (about 10% to 15% a/c usage). You FE is highly dependent on traffic conditions and your driving style. So keep a check on your driving style and you will see a change in your FE.
Hope this helps.
Cheers,
gpa
Old 18th June 2009, 11:58   #250
Technocrat's Avatar
Thanked: 2,490 Times
@anky- For the driving conditions that you have mentioned the mileage looks fine
Old 18th June 2009, 12:05   #251
gpa
gpa's Avatar
Thanked: 273 Times
Originally Posted by anky View Post
Hi I would like to correct my last post that I fill my alto tyres with 30 psi. I drive in city everyday (bombay) in peak traffic mostly 2nd and 3rd gears with ac on 100% and get a fe of 12.5 to 1.35 in my 04 lxi alto done 29000kms.All service at mass every 6 mts just got ingectors cleaned this time but no improvement.
anky,
Given the tough conditions that you drive in, I think 13.5 kmpl is about the most that you can get. Driving in 2'nd and 3'rd gears in peak traffic and with the a/c on 100% is the ideal conditions to derive the best FE.
Here's a suggestion: Try and take the car out of the city on a long drive or drive with the a/c switched off and you should see a big difference in your FE figures.
Cheers,
gpa
Old 18th June 2009, 12:19   #252
shiv,
Hope this helps.
Cheers,
gpa
thanks gpa...i'm pretty sure i got 15kmpl..i'm also a lightfooted driver..but i use ac all the time..very rarely i push it..after the 1st service i was getting 15kmpl..i took it for a highway trip...after that the FE went down..right now it gives 15 in highways..but inside city very less..for the last fill of Rs1300 i got jus 250kms which is almost 9kmpl..isnt it very low for a 0.8l engine...
and as for the service i will give it at 5k..
shiv
Note from the Team-BHP Support Team : Please take the time to use proper punctuation as per Team-BHP rules. Avoid...typing...like...this. Thanks.
Last edited by Technocrat : 18th June 2009 at 12:47. Reason: please read the note in post, thanks
Old 18th June 2009, 12:48   #253
im_srini's Avatar
Thanked: 368 Times
Infractions: 0/1 (5)
Yes, 9 Kmpl is abnormal - my Vx gives me ~11 Kmpl with AC & ~13 without (on highways I get ~21 Kmpl).
See if you're brakes are dragging & also have your timing checked.
im_srini is offline   Reply With Quote
Old 18th June 2009, 12:50   #254
thanks srini.will do.once i got 7kmpl for a fill.but i think that was because filling at different pumps.
shiv
Old 18th June 2009, 13:18   #255
14000rpm's Avatar
Thanked: 584 Times
shiv
@shivred, I've been there dude. your Fe is absolutely i was getting the same kind of FE till my 10k service when it automatically started to give 18.5 kmpl in city!!. so be patient and drive along.
A/C and fuel economy & How to use aircon optimally. Lukeskywalker Technical Stuff 115 15th June 2014 12:09
Does Weather Affect Fuel Economy wolfinstein Technical Stuff 34 20th August 2009 00:57
A New type of engine -> NEVIS Engine, 2x Fuel Economy, 2 Stroke 2 Cyl 1000 cc 250hp 1Day Technical Stuff 16 2nd January 2009 18:24
Electronic ways of IMPROVING fuel economy Godfather Technical Stuff 8 1st October 2006 08:50
Tyre pressure vs fuel economy sbasak Technical Stuff 15 27th February 2006 23:31
