Old 9th October 2007, 19:03   #106
ScarySkulls's Avatar
Thanked: 19 Times
Originally Posted by anandtheleo View Post
@Scary- I too have this shuddering you have mentioned. But for me it appears only after the car has gone through one cooling period in the day i.e once i start in the morn it is smooth and once i travel 10 kms and stop for say 1 hr and then start the vehicle the shuddering starts. does this happen to you too? or is it there from the start?
Observed this.
Car jerks less after its been given a proper warmup. And rarely so when it properly warmed up and cruising around the city.
ScarySkulls is offline   Reply With Quote
Old 9th October 2007, 20:21   #107
anandtheleo's Avatar
Thanked: 208 Times
Hi Scary,
I saw in some other thread here (link given below) on TBHP about the same problem, but the complaint was about the swift behaving this way. The shuddering seems to be affecting the maruti Swift as well as Alto. Dont know why this is happening, also wonder if Swift and Alto share the same clutch manufacturer.
http://www.team-bhp.com/forum/techni...tml#post586557 (Does the Maruti Swift have a weak clutch)
Anand.S
anandtheleo is offline   Reply With Quote
Old 10th October 2007, 09:05   #108
Thanked: 19 Times
I have driven the Swift extensively. It sometimes gives more efficiency under same city driving conditions as my Alto.
Yes there is shuddering present in it also but hardly 10% of Alto.
Old 10th October 2007, 10:37   #109
anky's Avatar
Thanked: 107 Times
Post 12kmpl
I too get 12 to 13.5 kmpl in my alto 2004lxi. I drive 100% ac and in moderate traffic. I too experience the shudder in the mornings. Started after about one year of ownership.
anky is offline   Reply With Quote
Old 10th October 2007, 17:43   #110
mail4ajo's Avatar
Thanked: 261 Times
Originally Posted by mail4ajo View Post
Wanted to know if a loose clutch increases fuel comsumption? I asked to tighten my clutch in the last service and need to check the FE now. It was 12kms (Dropped from 15kms 3 months back) in heavy traffic with full AC.
Any one has feedback on this?
mail4ajo is offline   Reply With Quote
Old 12th October 2007, 21:48   #111
mail4ajo's Avatar
Thanked: 261 Times
Does someone know how the service center guys check the FE of MPFI cars? You cannot use the old school method where the fuel lines are removed and connected to a container. I was told there is a equipment (not tech2) which when connected and driven, gives the FE of the car.
This equipment is available only at Maruti service masters in chennai.(company owned service outlet). An appointment needs to be taken for it.
Any idea how this works?
Old 12th October 2007, 21:53   #112
Vid6639's Avatar
Thanked: 21,046 Times
If the clutch is adjusted properly i.e. play is less there will be lesser slippage and the action of engaging will be smooth without the need to increase the revs. The clutch will slip less allowing the full power to be transferred and saving on fuel.
I get exactly 13kmpl now. I have stopped bothering about the mileage and now regularly cross 80km/hr in second gear. Also found out that the rev limiter cuts in very violently at 85km/hr in second gear.
Old 13th October 2007, 13:27   #113
Thanked: 19 Times
your 13kmpl is with this kind of redline driving??
Old 13th October 2007, 13:40   #114
Vid6639's Avatar
Not always redlining. Only sometimes. But I'm on the faster side and extremely rev happy. It never goes below 12kmpl and never above 13kmpl.Once I got close to 14kmpl but that was cause i was driving back from work everynight at 2am.
I tried to see how much I could get out of it but no matter how i drove it never crossed 13kmpl so now I just drive how i feel like without seeing the mileage.
Old 13th October 2007, 20:29   #115
Thanked: 71 Times
I am having Alto for last years with running of 95K. In Mumbai I used to get milage of 13 to 14. After coming to Pune with bit more highway run on my way to office, I am getting average between 14 to 15. But never more than this except if it is total highway run.
radek is offline   Reply With Quote
Old 15th October 2007, 19:13   #116
mail4ajo's Avatar
Thanked: 261 Times
Thumbs down
Serviced my car and corrected the loose clutch and still only 13kms/litre with 90% AC......
I am getting fustrated because even my friend's Swift get 12kms. My driving style, route, and petrol bunk hasnt changed from the time I used to get 15kms/litre. What could be wrong?
Does someone know how the service center guys check the FE of MPFI cars? I heard there is an equipment for this. Any idea??
Old 15th October 2007, 21:57   #117
Jaggu's Avatar
Thanked: 8,680 Times
try a different petrol station and also ensure your plugs/air filter etc are in shape, and hopefully the gas job hasnt changed any other setting?
Old 15th October 2007, 22:50   #118
mail4ajo's Avatar
Thanked: 261 Times
Will try a different bunk for sure. But I used to get 15kms consistently filling from this bunk and even after gas conversion.
Jaggu, Any idea on the FE checking equipment?
Old 16th October 2007, 00:38   #119
Jaggu's Avatar
nope am not very sure of FE equipment for the FI cars, i havent bothered with FE since the ol zen in 1996, reason being i could manage 18 to 19 kms within city with AC with a bottle of petrol but never went beyond 13 kmpl with tank full of petrol
so now whatever measuring done by me is through couple of tank to tank full fills.
Old 17th October 2007, 09:58   #120
Thanked: 19 Times
Was using a friend's Swift last week. 17" rims with 205 section tyres.
No change in driving style or A/C usage.
Mileage -> 10kmpl.
And my puny 796cc with 155section tyres--> 12kmpl. WOW.
A/C and fuel economy & How to use aircon optimally. Lukeskywalker Technical Stuff 115 15th June 2014 12:09
Does Weather Affect Fuel Economy wolfinstein Technical Stuff 34 20th August 2009 00:57
A New type of engine -> NEVIS Engine, 2x Fuel Economy, 2 Stroke 2 Cyl 1000 cc 250hp 1Day Technical Stuff 16 2nd January 2009 18:24
Electronic ways of IMPROVING fuel economy Godfather Technical Stuff 8 1st October 2006 08:50
Tyre pressure vs fuel economy sbasak Technical Stuff 15 27th February 2006 23:31
