Old 19th June 2007, 17:57   #16
Thanked: 149 Times
Something wrong with the temperature sensor? If the sensor is broken, it will not start the fan when required?
Another possibility - blocks in coolant circulation path within the engine block.
Old 19th June 2007, 23:27   #17
2fast4u's Avatar
best is to do a pressure test. If it holds pressure then good.
Now zero in on the Pressure Cap. Test the bugger also.
cheers
2fast4u is offline   Reply With Quote
Old 20th June 2007, 12:08   #18
prateek's Avatar
what is pressure cap buddy?same one at the top of radiator?
cheers
prateek is offline   Reply With Quote
Old 20th June 2007, 12:09   #19
prateek's Avatar
how can i conduct pressure test on my car?
Old 20th June 2007, 13:11   #20
risga's Avatar
Thanked: 46 Times
There is a thermostat device in the cooling system, which causes the coolant to bypass the radiator. This is to helps heat up the engine to optimal operating temperature fast. Once this temperature achieved, normal coolant flows through the radiator.
It seems in your car, this is faulty and not allowing the coolant to pass through radiator.
risga is offline   Reply With Quote
Old 20th June 2007, 18:10   #21
prateek's Avatar
where it can be located risga?if u can tell it will help me alot.
Old 20th June 2007, 18:38   #22
2fast4u's Avatar
first its located normally on the top hose section meeting the engine. dont worry on checking the thermo as its a simple test to do but will be technical for you to do. just take to good garage get it pressure tested and get the Radiator cap pressure tested.
The cap is such a small item which controls a lot just like a pressure cooker.
Old 20th June 2007, 18:44   #23
2fast4u's Avatar
hey buddy post some pics of your ride and ur engine bay with the turbo stuff. would love to have a look.
Old 22nd June 2007, 16:29   #24
risga's Avatar
Thanked: 46 Times
This is something which can be checked only at a service centre. The location would vary for each engine. I used to be a service engineer with Tata during the good old days of Sierra/ Estate. This was the first thing checked whenever anybody complained of overheating. Many local mechanics actually remove this totally (not desirable).
Opel Corsa Sail 1.4 Engine heating problem. Please Help! stevie Technical Stuff 15 20th January 2010 00:59
Strange Heating Problem in 2002 model santro Pls..... help manne Technical Stuff 9 17th May 2009 03:53
Ford Fusion - Engine Heating Problem vij4all Technical Stuff 45 5th October 2008 15:41
Over Heating Problem lancer_maniac Technical Stuff 13 13th December 2006 20:32
