| Technical Stuff Discussions related to the technical side of cars (Vtec, ABS, Intercoolers et al). |
| | Thread Tools |
| | #1 (permalink) |
| Senior - BHPian Join Date: Jul 2006 Location: mumbai
| Hi all buddies, I am facing this problem of baleno making kr kr kr kind of noise when accelerating in any gear.it has been for sometime now.Please let me know possible cause of trouble. Off late findings during my shiridi visit along with this noise was: Baleno rpm was going high towards the end of ghat section, became normal later on. is my clutch failing? Ac no ,off is highly noticeable as she shudders like a carb car. Is my cam timing belt going to pack off. Replaced the plugs after she was a bit erratic in idling, earlier gap of plug was .4mm but now made it .75mm. observed burn marks on previous plug. 0-100 is taking more time and she is not spooling up as she used to when acclerator is slammed in 5th gear at 40kmph. do i need to check the tappet clearances. will service center do it properly. i am scared of them opening up the engine. crossed 70kms. when ac comes on noticed voltage going to 12v, also the shuddering is more evident when the voltage is aroung 12. this kr kr noise is not evident to passengers only me!!! ![]() Last edited by gigy : 20th June 2007 at 11:24. |
| | #3 (permalink) |
| BHPian | from many forum members posts i have read .4 seems to be the best setting. pm supremobaleno Overrevving and car not moving at the pace it should normally will indicate clutch failing and can be noticed in steep inclinces where a downshift will be required and rpms increasing with less momentum will be evident.
__________________ 332kmph 1999 unrestricted GSXR1300R ROYAL ENFIELD MACHISMO 1992 636 RB20DET NISSAN Last edited by 2fast4u : 20th June 2007 at 16:34. |
| | #7 (permalink) |
| Newbie Join Date: Dec 2006 Location: hyderabad
| 2. Check alternator charging. 3. Firing order. Misfiring. 4. Open the engine cover n see if the engine judders at low RPM( AC OFF/ON). If Yes then get the ECU checked along with HT harness
__________________ AeroSan |
| | #9 (permalink) |
| BHPian Join Date: May 2007 Location: CHENNAI
| not sure about your cars performance being affected but the krrrr.krrr noise could also be a damaged fender lining touching your tyres as i found out in my car few days back.
__________________ my vRS = my VERY RASH SKODA |
| | #10 (permalink) |
| thanks for the inputs buddies. voltage is normally 14 but goes down to 12 when ac starts up takes some time to come back to 13-14v.there is whining sound from the engine bay itself but its there for almost a year.alternator belt condition is ok. dont know about its bearing and the pulleys.the engine vibration is noticeable when the ac cuts in and voltage falls. there is nothing rubbing on the tyres. the noise is not there even when redlining it while stationary. it comes on while on road and slam accelerating. can axles slip on high torque? will ac amplifier failure cause check engine light to come on or will it show in OBD tool? i doubt if it is not working.then ecu is not spooling up when ac comes on and engine struggles to take up sudden unknown load. is it possible? normal service i used to do it as DIY. replacement i give it to a know mechanic who knows to replace but not fault isolation at higher level. major problem then have to take it to sai service. i wanted to isolate possible problem before handing the car over to them and wait outside with my bank balance. |
| | #11 (permalink) |
| BHPian | i think the best option is of going to agency, they know your car better and handles it with care like no one else will do. Rest depends on you. Please keep us updated.
__________________ Bajaj Pulsar 180 DTSI 22 oct 2008 Hyundai Verna VGT Sx 8 Jan 2009 Maruti Suzuki Alto Lxi 11 Nov 2009 |
| | #13 (permalink) |
| at 12v the engine vibrates which is visible on the steering wheel like the old esteem. once upon a time there was no such issues,. didnt notice ac coming on and off except via cooling.i read in the suzuki manual that as soon as ac is switched on the ac amplifier sends signal to the ecu and it spools up accordingly before engaging the compressor, that way everything should work out smooth. i have a voltmeter always connected. cant measure current as my multimeter has maximum range of 10amps. i tightened the tensioner for ac and power steering belt three turns since its a new one and was not retorqued after first installation. on reving the engine at idle with all electrical load on at 4000rpm there was this sharp sound like bearing rubbing, so reduced one turn.there is enough play left on belt.power steering has become lighter like before.ac vibration has reduced a bit i think. anyways decided to change the clutch first through my local mechanic.will buy him the spares. any recommendations while changing clutch? which spares? economical ones. the one i had is harder to operate? is softer one adviced?i have burnt the present one in less than 30kms. |
| Thread Tools | |
Similar Threads | ||||
| My NHC clutch making a squeaking noise on release | battada | Technical Stuff | 12 | 9th November 2009 12:24 |
| Zen MPFI making big kr..kr..kr..kr noise | nicejits | Technical Stuff | 3 | 22nd June 2007 14:41 |
| Swifts making a noise .. | khaadu75 | Modifications & Accessories | 35 | 11th June 2007 23:16 |
| New AC making noise | Real_man | Technical Stuff | 2 | 22nd March 2006 05:06 |
| Air Con making noise!! | Shan2nu | Technical Stuff | 20 | 21st April 2005 19:42 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607
Any idea what is the "current" reading on the mutimeter?
