Old 25th June 2007, 13:50   #16
shineshine's Avatar
Thanked: 37 Times
Me too had the same problem with my Palio 2002. For me it always happened in running where the engine suddenly loose power and the 'Check Engine' light comes on. After covering some distance the power gets restored. The problem was diagnosed by Engine Scanning computer.
BTW. I was adviced to change the two coils since mixing up old and new coils may gave slightly different current to the spark plugs and may end up in a slight 'Engine missing'.
I've changed both coils and now my palio is running absolutely fine.
(Please note that in Palio, a single coil powers a pair of spark plugs)
One more thing to note...after the change my LPG fuel efficiency has increased to about 15%.
shineshine is offline   Reply With Quote
Old 25th June 2007, 23:49   #17
rdkarthik's Avatar
Thanked: 11 Times
Mixing an old coil that works with a new one will not cause any slight 'engine miss'. Maybe they were trying to replace both as a preventive measure....
rdkarthik is offline   Reply With Quote
VW Jetta: Issue with fuel delivery system & check engine light Kanboy Technical Stuff 22 1st December 2017 12:18
Changing ignition system for gypsy - will it help fuel economy? Crazy4Power Modifications & Accessories 1 21st May 2008 11:26
No ignition light kavesh55 Technical Stuff 5 24th January 2008 13:38
Siena - ECU check light not working superavi Technical Stuff 5 17th October 2006 16:12
Palio not starting; ECU Check light not lighting up shineshine Technical Stuff 2 12th August 2006 11:50
