Old 21st June 2007, 13:32   #16
lurker's Avatar
Thanked: 678 Times
I think you are right ben, when a car is passing through water it is always advisable to shift to a lower gear before entering the water and then not shifting gears or playing with the clutch while passing through it. If it stalls inspite of all the precautions somewhere in between then just switch off the engine and push it across.
lurker is offline   Reply With Quote
Old 21st June 2007, 13:38   #17
suman's Avatar
Thanked: 257 Times
Opinions, guys?
Benny, I would tend to agree with you but its more a post mortem, we first need to see if the diagnosis itself is faulty.
Old 21st June 2007, 13:38   #18
Thanked: 245 Times
and never race through the water, just be calm and drive at a low constant speed, the water splashing (due to speed) all around under the hood can cause more damage than you can think.
Old 21st June 2007, 13:51   #19
Vid6639's Avatar
Thanked: 21,086 Times
Any ideas on what is to be done for claiming it under warranty or whether there is a clause for this for insurance.
Yup, No water has entered the cabin at all. it's bone dry.
What I dont understand is the piston and con rods needing replacement?
Old 21st June 2007, 14:04   #20
doctorque's Avatar
Thanked: 380 Times
well 26/7 happened much before fiestas launch so it has been tested to pass through 450mm of water comfortably, well that is what we were told in training.
(guess other manufacturers just test it for 300mm of water.)
and still something like this happens is actually a shame for ford india unless it was a driver error (which is highly possible i believe.)
i still believe in the product though.
doctorque is offline   Reply With Quote
Old 21st June 2007, 14:32   #21
Thanked: 279 Times
I cant understand the part of 1 piston costing 41000. Could this be true? I guess that is the price for set of 4 but mentioned in qty as 1
badri is offline   Reply With Quote
Old 21st June 2007, 14:57   #22
Vid6639's Avatar
ok so I'm mailing Ford using the id given by benny.
I am attaching the estimate from ganges ford for the repairs.
Any other suggestions as to what to write to them?
Old 21st June 2007, 15:10   #23
benbsb29's Avatar
Thanked: 4,281 Times
Vid, there is also a customer care number mentioned in the thread in the Shifting Gears section which mansi had created. Try that also, for a verbal complaint.
Old 21st June 2007, 15:11   #24
alabjarus's Avatar
Thanked: 16 Times
Vid, why would anybody change 'Steering Oil' and 'AC Gas' for an engine failure issue...!
I get a bad feeling about Ganges Ford's intention. Beware....! Double check.
alabjarus is offline   Reply With Quote
Old 21st June 2007, 15:12   #25
ritayan's Avatar
Thanked: 29 Times
There is also Bothra Ford in Calcutta. Have they opened up the engine? I think the dealer is taking him for a ride. Last weeks downpore my dad took our santro all over and even had slight water seapage into the cabin but no other problem.
ritayan is offline   Reply With Quote
Old 21st June 2007, 15:15   #26
suman's Avatar
Thanked: 257 Times
I thought that closed down a few years back?
Old 21st June 2007, 15:54   #27
WhiteKnight's Avatar
Thanked: 76 Times
Agreed. What we need is a second opinion. Do we have any TBHP tech gurus in Calcutta? Else I think get a private garage mechanic to have a look.
WhiteKnight is offline   Reply With Quote
Old 21st June 2007, 16:35   #28
ritayan's Avatar
Thanked: 29 Times
My Mistake, yes Ganges is the only dealer in all of West Bengal, but I know a good place and my Dad has been associated with the trade for a long time. If any help is needed I can ask him to help out. I am sure he will be glad to do so.
Old 21st June 2007, 16:38   #29
Rudra Sen's Avatar
Thanked: 4,295 Times
To me it looks like a big con.
Vid’s uncle knows nothing about cars. Taking that, one and only dealer from Kolkata is taking a big chance.
Even for ankle deep water (taking as water has not gone inside the cabin) it’s really difficult to believe that water has gone through tail pipe. And gone where and how far? Are we to believe that water has gone past both the mufflers and cat-con housing to reach the exhaust ports?
And how much force it takes for water to come up through air inlet path to reach filter and then go through? At what speed we’re talking about?
Yes water can get sprayed inside via radiator/AC condenser fans. But then it’s only water droplets. But for ankle deep water one can rule that out.
Vid has a problem in hand and let’s help him however we can. Let’s not discuss how to drive through water please.
Requesting Kolkata members to help Vid and his uncle. Someone should see it through from your side.
Old 21st June 2007, 16:55   #30
Vid6639's Avatar
Just spoke to my uncle who called them up. They say the water has gone through the air intake. I also find this hard to believe as they say there is no damage to the turbo!
I'm writing a mail now to ford to ask for justification to the estimate so that they send across a ford rep to get it inspected. I'll forward the mail to the Calcutta gang as well.
Thanks a lot guys.
Ford Fiesta 1.4 TDCi ZXi 60,000 kms. review / Still fida over the fiesta Sugeeta Long-Term Ownership Reviews 60 29th September 2015 12:18
1.4 Fiesta EXI TDCi or Swift VDi EDIT - Booked Fiesta ZXi iamkapilb What Car? 28 6th March 2010 08:26
Ford Fiesta 1.4D ZXi Ownership Woes. EDIT : REPLACEMENT FIESTA. Pics on Pg. 5 Mad Monkey Long-Term Ownership Reviews 105 3rd March 2010 15:26
Altis vs SX4 vs ANHC vs Fiesta. EDIT : Black Fiesta 1.6S it is! tarunt Sedans 25 30th September 2009 18:32
Please help me decide: Fiesta S or Fiesta ZXi? EDIT: Booked Fiesta S! Pics on pg5. frankmehta Sedans 108 18th August 2009 13:43
