Old 22nd June 2007, 22:42   #1
saurabh711's Avatar
Unhappy Wheel Bent in Indica Turbo
Tonight I didn't see a deep and small pot-hole, and bumped my front left wheel real badly in it. I was going at something like 60 kmph.
When I reached home and got to check it, first I found that the wheel hub had gone off :( and then I found a small dent in the wheel circumference :(
Two questions here, can I get the wheel fixed and back in shape? and also, can I buy a single wheel cap for my Indica Turbo from the Tata Spare shop?
Saurabh
saurabh711 is offline   Reply With Quote
Old 22nd June 2007, 22:56   #2
abhishek_rait's Avatar
Thanked: 7 Times
hi ,
you can get it done from any good tyre selling shop who has a rim straightener. but check the quality of work done and get the rim balanced. for hub caps you need to ask them whether they keep spares with them i hope they do otherwise u can surce them for any descent local spare parts shop
abhishek_rait is offline   Reply With Quote
Old 23rd June 2007, 00:58   #3
tsk1979's Avatar
Thanked: 16,420 Times
You can get a single wheel cap if you have good relations with service managers. It will cost 200+rs.
Better go to an independent shop and take the same thing for 150 odd.
The DLS cap costs 100rs/piece. So if yours is a full cap it will be more.
As for straightening, don't go to somebody who uses a hammer. I did and had to buy a new wheel for 750rs. Instead go to a tire shop with the straightening machine.
Old 23rd June 2007, 01:38   #4
ritayan's Avatar
Thanked: 29 Times
A good wheel straightening place will do the job, the same happened to my Marina 6+ months back on the way to Ludhaina, the tyre shop charged Rs 40 per rim. Yes you can buy the full caps individualy (its a DLG i guess) @ 475 per piece last when i bought them.
ritayan is offline   Reply With Quote
Indica V2 Turbo - Turbo Failure abhik Technical Stuff 15 30th November 2017 17:24
Bent wheel on Fiat Palio meremortal Technical Stuff 2 3rd October 2009 21:41
Indica NA DLS vs Turbo DLS vs Turbo DLG greenhorn Hatchbacks 10 5th May 2007 17:20
Indica Turbo vs Non Turbo lbhavani Technical Stuff 0 5th September 2006 22:22
New Indica Turbo - is the turbo on? gakudva Technical Stuff 5 15th July 2006 23:00
