| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian | Friend any insight will help. I have been seeing this problem for over a month. When I turn the head lights on the left hand side head lamp turns on a little late, probably seconds later than the right handside one. Some times it take longer or does not turn on. Could it be any thing other than a loose contact ? The car is Petra 1.6.
__________________ I have one dream, Fiat with great A.S.S. |
| | #2 (permalink) |
| Team-BHP Moderator ![]() Join Date: May 2004 Location: Bangalore
| contacts loose, corroded. check the earthing for the LT side and also swap the bulb and see if its a bulb issue.
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin |
| | #3 (permalink) |
| BHPian Join Date: Mar 2005 Location: Mumbai
| Its probably the relay of the headlight which comes on later, which is to blame. If its annoying, replace it with relay for wiper or something. But, since it sometimes does not come on at all, better to replace it. The relay is like a switch. They are used to avoid the need for the entire circuit current to pass through the switches in the cabin. So, these would be typically be for circuits using large currents. So 4 for headlamps (2 for high beam and 2 for low beam), 1 for wiper etc. Last edited by risga : 24th June 2007 at 10:17. |
| | #4 (permalink) |
| BHPian | this can be got done by some cleaning WD40. also check your contact points of the electrical connection where ever they are located and clean / scrap if theres rust with a sparkplug cleaning knife. Give this a try if the problme persists then it has to be the relays or some connection as other members have said.
__________________ 332kmph 1999 unrestricted GSXR1300R ROYAL ENFIELD MACHISMO 1992 636 RB20DET NISSAN |
« Your choice of Gear Box: Tall or Short?
Scratching and vibrating noise from SKODA OCTAVIA 1.9 Ambient »
| Thread Tools | |
Similar Threads | ||||
| (DIY) Head lamp washer | manikjeet | Modifications & Accessories | 33 | 31st July 2008 17:39 |
| Palio head lamp problem. | Firebird | Technical Stuff | 4 | 11th July 2007 09:48 |
| head lamp assembly for OHC | four_tire | Modifications & Accessories | 5 | 14th September 2006 09:44 |
| Head light not turning off | naveendhyani | Technical Stuff | 18 | 1st August 2006 14:21 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
