| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Feb 2007 Location: Jabalpur
| Yesterday while parking my car (Hyundai Santro Xing XS),I moved over a big stone, thinking that the car would be able to pass over it. But the stone got stuck under the underside of the car and I could feel it. After some manoevering, I was able to climb over the stone, and I could clearly see scratch marks over the stone ( approximately a cubewith sides about six inches, with a sharp edge on top), made when it came in contact with the underside of the car. On trying to see the damage under the car, there was little I could see. When driving again, I could sense that the car was running rather laboriously, third gear running felt like I was in second gear, and on fourth gear, I felt like I was running in third gear. What could be the reason ? My guess is that the stone that got stuck underneath has caused the brake components underneath to shift from their usual positions. Can someone explain technically what may have happened ? It is clear that I have to go to the service centre to get the problem rectified. And how much will it cost ? Please help. And thanks in advance. |
| | #3 (permalink) |
| BHPian Join Date: Mar 2006 Location: Phoenix, US
| Check if you have stone chip stuck between your brake disc and calipers. If you drive with anything wedged there it should make an screeching sound. How abt the second possiblity that your shift rod has actually moved and lower gears are getting engaged! |
| | #7 (permalink) |
| BHPian Join Date: Feb 2006 Location: New Delhi
| I think you could have hit the Cat Con or silencer pipe, which are narrowed now causing restrictive exhaust of gas flow and forcing some back into the engine. Get it checked ASAP.
__________________ " When was the last time, You did something for the first time " |
| | #8 (permalink) |
| BHPian | first thing you do next time when a stone gets stuck is check to see where the f is the stone wedged and if it could damage the underside best would be to jack it up. as of now let us know whether u were doing a reverse or forward parking and which wheel in particular did go over the stone to get it stuck in ur underside. ![]()
__________________ 332kmph 1999 unrestricted GSXR1300R ROYAL ENFIELD MACHISMO 1992 636 RB20DET NISSAN |
| | #9 (permalink) |
| BHPian | [COLOR=black]Hey Man it is serious. I remember last time It happened to me. I was driving from Dalhousie to Dharmsala and I know there is a route which saves at least 1 hr and I took that the road was pretty good but as happens in all hill stations, some patches was like hell. So while negotiating such patch a stone hit the bally of car and Car make to neutral by itself and after that come what may I could not engage the gears. It was in middle of jungle and no one to help, the only luck was that I had to come down the hill so I pushed it for some time and then drove it on neutral on slope. When road side mechanic went under the car he found that some rod which engages the gears has been dislocated , he some how managed to engage the 3rd gear and I drove 100 km in 3rd gear. So get it checked ASAP, before some serious damage happens[/COLOR]
__________________ SUCCESS NEVER ENDS, Failure is not final.... |
| Thread Tools | |
Similar Threads | ||||
| Falling stone cracks front windscreen | Lukeskywalker | Street Experiences | 28 | 21st June 2007 18:22 |
| Coming soon: Buy your car online! | tsk1979 | The Indian Car Scene!! | 19 | 23rd May 2007 22:03 |
| HELP!!: Hit a Stone/cement block cracked a RIM & busted a tyre | aZa | Tyre & Alloy wheel Section | 11 | 15th October 2006 12:24 |
| Stepping stone for Indians to race abroad | Rtech | Motor-Sports!! | 13 | 18th February 2006 00:31 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445
