| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #16 (permalink) |
| Team-BHP Moderator ![]() Join Date: Oct 2005 Location: Hyderabad
| Or else if everything else fails here is a desi jugaad to find the source. Since you say it happens only when you wash the car we can probably be sure that the washing water is seeping in. Do something, ask someone to sit inside the car, doors locked, glasses up. That is to say the way your car normally is when you wash it. Now take a pipe, bucket or whatever you use and start the wash routine. Ask the person inside to keep a watch. Once the carpet starts getting wet the person inside will also know from where it is coming in. Whether its the door beading or the window glass or some plug on the floor. |
| | #17 (permalink) | |
| BHPian Join Date: Mar 2006 Location: Pune
| Quote:
| | #20 (permalink) |
| BHPian Join Date: Jun 2006 Location: mumbai
| guys sorry for being off the topic but my 1.6 sport(2006 model) seems to have water seeping through the floor. the floor mat is completely soggy and its not that I am driving through pot holes or water logged roads. My drive to office is just 4 km via palm beach to vashi has anyone else over here faced such problem? Mod's Note: Please run a search on the board before you post a query. Do not post in irrelevant threads. post moved. Last edited by Zappo : 6th August 2007 at 00:09. |
| | #21 (permalink) | |
| BHPian Join Date: Sep 2007 Location: Banglore
| Quote:
http://www.team-bhp.com/forum/techni...tml#post824384 (Leaking Getz - weird issue - solved) Is drain holes in rear door can cause this problem, i haven't checked that till now. | |
| | #22 (permalink) | |
| BHPian | A similar issue was reported in a getz. Quote:
__________________ ThunderBird 2003, no speedo, no range limits. Wagon R, 2004. Well trained reflexes are quicker than luck. | |
| | #23 (permalink) |
| Senior - BHPian | Check the beading on the roof...the ones which can be removed to allow the roof rails to be attached.A lot of times the metal below the beadings gets rusted and cracks and water can seep through.If this happens you will find the rear footwells wet.
__________________ If you try,and succeed at first, try not to look astonished. |
| Thread Tools | |
Similar Threads | ||||
| Water in Diesel indicator in palio D | sfilinto | Technical Stuff | 6 | 7th January 2008 10:04 |
| Strange Palio Problem? 1.2 ELX | extreme_torque | Technical Stuff | 7 | 2nd October 2007 23:05 |
| palio 1.2 nv 'pressure sensor error and water pump issue' | kapilsharma80 | Technical Stuff | 5 | 17th September 2007 17:58 |
| Oil Leak on my bike | abdriver2000 | Motorbikes | 9 | 7th December 2006 18:59 |
| Power Steering oil Leak | dev | Technical Stuff | 9 | 24th May 2006 14:45 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407
