Thread Tools
Old 25th June 2007, 11:35   #1 (permalink)
Default Strange water leak in my Palio
I have got water leak in my Palio. Strange thing is, water not leaking from the roof or door side, no sign from anywhere. Water is lodging in right back seat's floor, exactly behind driver's seat, even left floor is comletely dry. I noticed, it happens whenever I wash my car once in a week. Cause I drive it only on weekends
I tried to find out the source myself, now only thing left is remove roofmat and floormat completly and check the leak. But I want to avoid removing company fitted mats.
TBhpians help will be appricited.
pawan_pullarwar is offline   Reply With Quote
Old 25th June 2007, 11:40   #2 (permalink)
madan80's Avatar
There is a small rubber plug just below your door above the side skirt. make sure that it is in place. Else get it checked.
__________________
Finally - Chennai's English music radio station- 104.8FM - Im lovin IT!
__________________
2002 Lancer | 2006 Palio
madan80 is offline   Reply With Quote
Old 25th June 2007, 11:41   #3 (permalink)
moralfibre's Avatar
Pawan, if you wash the underbody of your car with a pipe ensure that the water drain plug on your floor has not worn out. If it has then there are chances that water is seeping in through that open hole in the floor. There are four drain plugs on the floor. Since you have a problem why not replace all four and drive trouble free through water logged areas.
__________________
Ask not what your country can do for you, think of a way you can make them do it!
Old 25th June 2007, 11:43   #4 (permalink)
lohithrao's Avatar
Thats funny better get it checked thoroughly.
water can seap in through "door, window or rear ws" cant think of any other source.
hehe even i do the same, thanks to traffic
btw i think you have posted this thread in wrong section, it should have been posted in "Technical" section.
__________________
Practicing the science & art of design "www.lohithrao.com"
lohithrao is offline   Reply With Quote
Old 25th June 2007, 11:50   #5 (permalink)
@Moral: I dont wash underbody. Though I will have to check water drain plug. Cause water is not draining. I used to remove it using spunch.
Old 25th June 2007, 11:51   #6 (permalink)
I checked that too. :(
Old 25th June 2007, 12:10   #7 (permalink)
alabjarus's Avatar
I have had a similar experience in my friend's Zen. The culprit was the pipe that was connected to the ac unit, that had come loose. This pipe is there to carry the condensed water from the ac unit outside.
Check and eliminate this possiblity by driving without the ac.
__________________
2008-Honda Civic 1.8MT V
2006-Honda City ZX VTEC
2003-Accent GLS 1.6
2001-Santro GLS
1999-RX135
1993-RX100
alabjarus is offline   Reply With Quote
Old 25th June 2007, 12:15   #8 (permalink)
hydrashok's Avatar
@pawan, I had a similar problem a couple of years back. But in my case, the carpet of the driver-side as well as passenger-side footwells were wet.
The problem was with the A/C dumping water into the car from some part behind the dashboard. The service people said this is a fairly common problem.
(This had nothing to do with washing the car, though. Some piping somewhere in the A/C's line got choked, and that was fixed easily). Try feeling behind the dash (right behind the center-console and see if that part is moist/wet. If so, the water is coming from the A/C.
__________________
Αυτο ειναι ολα τα ελληνικα μου
hydrashok is online now   Reply With Quote
Old 25th June 2007, 12:33   #9 (permalink)
oh.. is it ? .. I use AC in my car. I wil have to check.
Old 25th June 2007, 12:37   #10 (permalink)
moralfibre's Avatar
I doubt it is the A/C pipe doing the damage because if I read correctly your back seats floor is getting wet right? In case of an A/C pipe choke only the front passenger side floor will get wet.
__________________
Old 25th June 2007, 12:44   #11 (permalink)
I read somewhere that the older Palios (pre-NV) had this problem as the A/C cut-off temperature was pretty low. Fiat claims that this problem has been rectified from NVs. I have an NV for close to 4 years and I have not faced this problem.
__________________
Deepak Honnalli.
deepakhon is offline   Reply With Quote
Old 25th June 2007, 12:47   #12 (permalink)
2fast4u's Avatar
thats what i read too. the plugs should be the first to be checked.
__________________
332kmph 1999 unrestricted GSXR1300R
ROYAL ENFIELD MACHISMO 1992
636
RB20DET NISSAN
2fast4u is offline   Reply With Quote
Old 25th June 2007, 13:18   #13 (permalink)
Yeah, In my case front driver seat floor is totally dry.
Old 25th June 2007, 13:44   #14 (permalink)
moralfibre's Avatar
You know Pawan I just went to the parking lot to see what the possible places of a leak can be. Check the following:
1) The rubber beading where the door meets the roof. The rubber possible has worn out. (Rubber wearing out can cause many leaks and troubles you see ).
2) Once you open the door there are two drain holes in the rear door, check if they are clogged.
3) Any gaps in the window frame?
Let me know.
__________________
Old 25th June 2007, 13:56   #15 (permalink)
rohan_fonseca's Avatar
Check wether the window shuts completely as well and there is no minute gap.
rohan_fonseca is offline   Reply With Quote
Thread Tools
Water in Diesel indicator in palio D sfilinto Technical Stuff 6 7th January 2008 10:04
Strange Palio Problem? 1.2 ELX extreme_torque Technical Stuff 7 2nd October 2007 23:05
palio 1.2 nv 'pressure sensor error and water pump issue' kapilsharma80 Technical Stuff 5 17th September 2007 17:58
Oil Leak on my bike abdriver2000 Motorbikes 9 7th December 2006 18:59
Power Steering oil Leak dev Technical Stuff 9 24th May 2006 14:45
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407
