Old 25th June 2007, 20:01   #16
Thanked: 655 Times
My Sienna diesel had a starting problem, i.e., laboured cranking. Dealer said that motor had to be replaced. Got my regular mechanic to remove the starter. Took it to a good electrician who diagnosed a worn out brush assembly. Procured a Mico brush assembly for Rs 650/-. Got it replaced for Rs150 and paid the mechanic Rs 200/-. Total cost Rs1000/- and 4 hours of my time.
Quote at the dealer end - Rs 7000/-.
jyobeb is offline   Reply With Quote
Old 26th June 2007, 00:26   #17
vivekiny2k's Avatar
Thanked: 184 Times
Originally Posted by nitrous View Post
OT:I thought U find good service in the US at every street corner.
they may have good infrastructure, equipment, (billing) software, waiting lounges, warranties, all backed by insurance. all of these translate into higher costs.
still nothing matches the expertise, inclination and the will to help out the customer.
on the other hand, going by the route jyobeb took may have proved costlier here. getting a new motor installed (get a rebate on exchanging old one) is a simpler task. labor is upwards of 40$ per hour.
vivekiny2k is offline   Reply With Quote
Old 26th June 2007, 00:33   #18
bottle's Avatar
Thanked: 138 Times
well sundaram has gotten smart by quoting a 1.2k bill to start of with and gradually increasing it via phone :P at that point i was like just do whatever it takes and quit calling me
anyways i dont really know any good mechanics so not willing to risk the way you took.. but had sundaram told me outright i would have explored other options
bottle is offline   Reply With Quote
Old 26th June 2007, 09:45   #19
gemithomas's Avatar
Thanked: 138 Times
Does the FIAT engines take more time to start. I hope its not a problem wih my starter motor too!!!!!!! My adventure takes atleast 2 seconds long to get started. WHile i have not experienced this on any other car. Could someone help me on what/how should i check if there is anything wrong???
Old 26th June 2007, 09:57   #20
rapideffect's Avatar
The Rs. 650/- stuff could be the starter solenoid. In most of the scenarios this is the culprit but the dealers ask for the entire set to be replaced hence it cost more.
rapideffect is offline   Reply With Quote
Old 26th June 2007, 10:49   #21
Thanked: 655 Times
I think I know my cars. What I replaced was the 4 brush assembly on which 2 brushes were completely worn out. The solenoid is a far more expensive proposition (in the fiat at least)
Old 26th June 2007, 12:28   #22
sreedotk's Avatar
Thanked: 22 Times
Originally Posted by vivekiny2k View Post
any kind of driving would not affect the starter, it's only used to START the engine. and then it stays idle.
battery was dead? there must have been some other short circuit. AFAIK, starter motor is open circuited until you crank it with the key ON. so even if there was a short circuit inside it, it would not be connected to the battery in first place.
Yeah i thought so too, turns out that shortcircuit was not an issue related to the starter motor but more of a ignition related one. Any way i was shown the blown starter and was needing the car so just changed it
sreedotk is offline   Reply With Quote
Old 26th June 2007, 18:34   #23
vivekiny2k's Avatar
Thanked: 184 Times
shud not.
my car had this problem and the cause was a weak (worn out) starter. replaced it and it came back to normal. keep it as long as it works. but someday it may just go dead (happens to all starters, eventually)
Old 26th June 2007, 18:53   #24
bottle's Avatar
Thanked: 138 Times
got my car back they only replaced the sensor and overhauled the starting motor and total bill is 3.2k
Old 26th June 2007, 20:47   #25
streetlife's Avatar
Thanked: 11 Times
I have a 1.2 clocked exactly at 77776 kms and i didnt had a single issue with the starter.. It starts jst at half crank even in winters..
Get it checked.. how old is your battery..?
streetlife is offline   Reply With Quote
Old 27th June 2007, 10:55   #26
gemithomas's Avatar
Thanked: 138 Times
Oh! i just bought the vehicle 4 months back. But its a 2006 sept batch vehicle.
Old 27th June 2007, 14:21   #27
madan80's Avatar
Thanked: 73 Times
There was someone who also had the same problem, and it was diagnosed by a local electrician as the solenoid. However, the A.s.S were chring about8 K to change the tneire starter motor and assembly.
madan80 is offline   Reply With Quote
Old 27th June 2007, 20:59   #28
streetlife's Avatar
Thanked: 11 Times
Then you should get it checked during the regular servicing.. I dont think it would be much of a problem but still...
Seat belt mechanism replacement razor4077 Modifications & Accessories 38 27th January 2013 18:21
How effective is the auto-cut mechanism of the fuel service stations? Zappo Technical Stuff 35 27th March 2009 14:34
What is right mechanism to reduce speed? sathya_nars Technical Stuff 84 4th November 2008 16:39
Building a model car-need help with mechanism ns_jughead Shifting gears 2 21st November 2007 01:36
Hydraulic Bonnet Opening Mechanism.How do i install nikibusa Modifications & Accessories 7 26th April 2007 13:40
