Old 25th June 2007, 16:40   #1
bottle's Avatar
Thanked: 138 Times
Default replaced palio starter mechanism
hey ppl,
was having some issues with a palio 1.2 elx.. on certain occasions it would not start . turning the key would give no response , ie it wouldnt even crank . first thought it was a battery issue but turned out fine
later took it to sundaram they said that it could be a problem with the starting mechanism.. first they replaced some starter sensor for 1.2k and then later on inspecting the starter motor/ mechanism said that it was totally worn out and needed to be overhauled (cost 3.5k) i said fine and gave it in
after a day they call and said that all parts are on their last legs and the entire starter mechanism needs to be replaced . (cost now 5k+ the 1.2k for faulty sensor)
service engineer said that starting probs are common around 30k kms (my car has done 35k) but havent really seen any mention of it here or at pug so just thought id get thoughts of members about this
will get details of exact parts replaced when i collect vehicle
bottle is offline   Reply With Quote
Old 25th June 2007, 16:44   #2
Thanked: 105 Times
I do read it quite that "This problem is common in this car". Not in fiat but all other cars too. I do read it quite often whenever any of the strange behaviour happens to the car they say the same thing.
pawan_pullarwar is offline   Reply With Quote
Old 25th June 2007, 16:58   #3
sreedotk's Avatar
Thanked: 22 Times
I too had a similar issue a month and half back. My starter motor burned. It had driven about 60 odd kilometers in Sweltering heat of chennai with a fully loaded car Luggage and people. Came back home parked the car , next day found that the car does not start and the battery was dead. The culprit turned out to be a short circuited starter motor. Got it replaced for a tad less than 5 K
sreedotk is offline   Reply With Quote
Old 25th June 2007, 17:08   #4
moralfibre's Avatar
Thanked: 6,532 Times
Dont give it in bottle. Spank their backsides and make them do it right. IT IS NOT A COMMON PROBLEM but some starter solenoids of a particular batch were faulty. Guess that could be the issue?
Old 25th June 2007, 17:13   #5
superavi's Avatar
Thanked: 13 Times
My Siena's done 65K plus, a matiz that's done 80K plus, the starter has had no issues. Look for other explanations before agreeing.
Superavi
superavi is offline   Reply With Quote
Old 25th June 2007, 17:14   #6
Jaggu's Avatar
Thanked: 8,689 Times
try to get this done under warranty coz failure at such low mileage is not acceptable.
Old 25th June 2007, 17:24   #7
bottle's Avatar
Thanked: 138 Times
well have already commited so dont think i can back out now.. wanted to get it done fast especially after one day engine died in middle of junction making a u turn and i wasnt able to start it for a few mins .
will talk to them and get a proper explanation .. explanation given was that all the bushes and bearings were totally worn out so whole unit had to be replaced
edit : also car is out of wty since its crossed 3 years of age
Old 25th June 2007, 17:33   #8
Jaggu's Avatar
damn 3 years means you really cant do a fight for warranty, atleast ensure the new starter comes with some guarantee
Old 25th June 2007, 17:42   #9
nitrous's Avatar
Thanked: 285 Times
warranty ?
electrical parts don't have warranty ,saar!
Old 25th June 2007, 17:48   #10
Jaggu's Avatar
Originally Posted by nitrous View Post
warranty ?
saaaaaar they do have if its a part like starter!! fyi i have replaced iKON window winder motor, now ordered for ignition switch for swift D.
yes bulbs might not have, read manual and they will have the fine print and if you are referring to replacement part, then they also do have depending on the part and also the dealer also will give a time frame in which they can take responsibility.
Old 25th June 2007, 19:29   #11
hydrashok's Avatar
I had to replace my starter sensor about a month back. Starting trouble. [35000-odd kms. Palio 1.2 ELX PS petrol, 2002 (Sep)]
Old 25th June 2007, 19:37   #12
nitrous's Avatar
Thanked: 285 Times
Im sorry if u got angry. I was trying to say that the service guys use that statement.
@Bottle: Do U always go to the Sundaram A.S.S?
Did u try to procure the starter motor from the open market??
Old 25th June 2007, 19:50   #13
vivekiny2k's Avatar
Thanked: 184 Times
any kind of driving would not affect the starter, it's only used to START the engine. and then it stays idle.
battery was dead? there must have been some other short circuit. AFAIK, starter motor is open circuited until you crank it with the key ON. so even if there was a short circuit inside it, it would not be connected to the battery in first place.
My experience (even here in US) has been really bad with mechanics. they are either incompetent, or greedy, when they give the costliest estimate for repairs.
one shop wanted to replace my disc and brake pads. totaling around 400$, all i needed was pad replacement ( cost 60$ with labor). same shop could (would?) not detect a problem with the radiator cap, i am guessing coz it just costs 8$ to replace.
vivekiny2k is offline   Reply With Quote
Old 25th June 2007, 19:58   #14
nitrous's Avatar
Thanked: 285 Times
OT:I thought U find good service in the US at every street corner.
Old 25th June 2007, 19:59   #15
Thanked: 294 Times
sometimes the only problem in the starter is the carbon brushes but the service guys replace the whole thing.
Seat belt mechanism replacement razor4077 Modifications & Accessories 38 27th January 2013 18:21
How effective is the auto-cut mechanism of the fuel service stations? Zappo Technical Stuff 35 27th March 2009 14:34
What is right mechanism to reduce speed? sathya_nars Technical Stuff 84 4th November 2008 16:39
Building a model car-need help with mechanism ns_jughead Shifting gears 2 21st November 2007 01:36
Hydraulic Bonnet Opening Mechanism.How do i install nikibusa Modifications & Accessories 7 26th April 2007 13:40
