Old 26th June 2007, 20:55   #1
abhaybakshi's Avatar
Thanked: 72 Times
Default Swift pushed hard in rains and ghat
Folks,
Just back from the approax. 1000 KM trip from Kokan and Goa with my new (Dec 2006) Swift.
My baby was pushed through horrible rains, ghats ....
Only good thing was roads were real good with occasional small potholes..
My cousin who is notorious for rash driving, had driven my Swift for couple of hours turning on hairpin bends at high speeds (80-90 kmhr) with full load (5 people) and braking sharply many times....
My concerns are,
1. Should I check suspension, braking system ? I absolutely dont find any problem with them but I feel that they should be checked
2. Can car like Swift take such beating without much wear and tear to importane systems like suspension, gearbox, clutch and brakes ?
abhaybakshi is offline   Reply With Quote
Old 27th June 2007, 00:13   #2
nitrous's Avatar
Thanked: 285 Times
Check for brake pad wear or abnormal tyre wear.
Although, the above wouldn't happen in a 1000 km drive.
The conditions that u've quoted sound like track racing conditions.
Old 27th June 2007, 00:17   #3
rjstyles69's Avatar
Thanked: 795 Times
And you sat obliged through the ordeal ? Safety 1st mate .
Old 27th June 2007, 06:18   #4
paras211's Avatar
Thanked: 57 Times
90 on a hairpin wow
paras211 is offline   Reply With Quote
Old 27th June 2007, 07:51   #5
dr.abhijeet's Avatar
Thanked: 67 Times
u need to check the sidewalls of ur tyres ,since ur car was loaded,and if high rpm was maintained during climbing turns with steep gradients, keep an ear for driveshaft noise
dr.abhijeet is offline   Reply With Quote
Old 27th June 2007, 10:32   #6
Thanked: 245 Times
This is nothing to boast about, you should be thankful that you are still safe and dont let him drive like this again.
Old 27th June 2007, 13:28   #7
risga's Avatar
Thanked: 46 Times
Its like pushing the car to its limits. Apart from a little extra wear and tear to the brake pads, nothing to worry.
Dont take it for unnecessary check-ups. The less mechanics touch your car, the better.
risga is offline   Reply With Quote
Old 27th June 2007, 13:46   #8
akroy's Avatar
Thanked: 29 Times
Absolutely correct dadu,
plus Abhay, I donot agree that your car turned at 80kmph on a hairpin...It Simply cannot !!! You should be thankful to your stars that the car didnt skid, otherwise it would have gone out of control....
Plus assuming that u have a Lxi-Vxi which has 165 JK tyres...it is really risky to do higher speeds in the rain...
Driving in rain is really nice if u r on a trip, u can enjoy the nice surrounding...why speeding up and risking the life...
Enjoy and Take care...
Abhi
akroy is offline   Reply With Quote
Old 27th June 2007, 17:25   #9
gd1418's Avatar
Thanked: 656 Times
Thrill Kills. This is an absolute no-no. You must drill some sense in your cousin's grey matter. And hairpin bends at 80-90? impossible.
You are lucky that the swift did not land in the gorge...
Folks, My baby was pushed through horrible rains, ghats ....Only good thing was roads were real good with occasional small potholes..
Old 28th June 2007, 17:16   #10
Thanked: 146 Times
if the swift can do 80 90 on hair pin bends then either the driver skills should be comended or the car suspension may be modded. with stock suspension it will turn turtle.
so best is u check ur brake pads & suspension (if its stock) btw if its stock and no damage if u still intend to give ur friend to drive then do fix some aftermarket BRACES.
Jr Godzilla is offline   Reply With Quote
Old 28th June 2007, 17:56   #11
nanu28's Avatar
Thanked: 60 Times
Your Friend (Driver): Unlucky to be alive.
Your Other Friends: Luck to be Alive.
You: Dont know if I can post a comment on you, which would justify.
PLease dont try your thrills with others at lives at stake!!!!!!
nanu28 is offline   Reply With Quote
Old 28th June 2007, 18:20   #12
typeOnegative's Avatar
Thanked: 20 Times
Abhay, I don't think you have to get anything checked as of now. Your car is still new and I can understand your anxiety - but I think most cars can take this abuse early on.
typeOnegative is offline   Reply With Quote
Old 28th June 2007, 19:43   #13
Sudipto-S-Team's Avatar
Thanked: 266 Times
Everyone likes honing their rally skills on someone else's car. Don't be that someone.
Sudipto-S-Team is offline   Reply With Quote
Old 28th June 2007, 19:53   #14
CrAzY dRiVeR's Avatar
Thanked: 19,909 Times
Guys,
Dont think he is happy with the situation nor is he boasting of it (I hope am not wrong)
He might have been helpless in the situation. Let him explain.
If he were boasting, would he probably ask like this?
Monsoon Offroading/Trail-driving in Sakleshpur and Bisle Ghat Samurai 4x4 Excursions 108 4th January 2016 09:14
Monsoon masti: Malshej ghat, Jivdhan fort and Naneghat. ASHISHPALLOD Travelogues 52 4th August 2009 15:34
523i & 525i Pushed to the Limit! Sahil Test-Drives & Initial Ownership Reports 77 13th September 2007 00:30
THOPPUR GHAT to KRISHNAGIRI kb100 Route / Travel Queries 8 11th October 2006 14:20
