Old 27th June 2007, 11:05   #16
Vid6639's Avatar
Thanked: 19,370 Times
Originally Posted by Rtech View Post
I personally have tried Shell, Motul and Mobile and find Motul the best. Hard to get though. Shell is cheaper and just as good as well. Nothing wrong with Mobile, but just thought I'd mention that there are other options out there as well.
HM uses MOTUL as OE oil for the Lancer and Cedia. Although I'm not sure if they use synthetic or mineral.
Old 27th June 2007, 11:31   #17
gd1418's Avatar
Thanked: 655 Times
Why...? A detailed reason will be helpful..
Also, synthetic oil should never be used over the initial run-in period.
Old 27th June 2007, 11:37   #18
Thanked: 20 Times
Read thread on synthetic oil vs mineral oil
swathyd is offline   Reply With Quote
Old 27th June 2007, 12:48   #19
tsk1979's Avatar
Thanked: 15,641 Times
For Bombay heat (where I assume the temparature will never be below 5 degrees) 20W50 oil makes much more sense than a 0W40 or a 5W40 or a 10W40 or a 15W40.
Synthetic or mineral, that I guess depends on your budget.
You will do an engine flush I suppose.
I advise you not to use the flush which says idle for 5 minutes. These are very "harsh".
Try the STP etc., which require 35 minutes of idling before draining oil.
Mobil 1 Super Syn is a 15W50 API-SL engine oil with 2600ppm of detergent and with P-1343 Zn-1390 B-205 ppm levels.
If I were to splurge on a synthetic for a petrol car, this would be my choice.
Then there is a Mobil 1 EP 15W50 oil too which high levels of these three metals.
Old 27th June 2007, 12:56   #20
Dippy's Avatar
Thanked: 163 Times
Thank you for the responses fellows
@ Jaggu : I plan to keep the car for 6 years atleast if not more.
@ vid & GTO : I dont drive the car hard and from what I could make out, the previous owner never really revved the car in its life. My driving style is very sedate.
I was thinking of Mobil 1 just to keep the engine happy. Is 10k a good interval between oil changes for Mobil 1? My air filter is the stock K&N replacement. Cleaning that is not a problem.
So Mobil 1 it is?
Dippy is online now   Reply With Quote
Old 28th June 2007, 00:04   #21
Thanked: 20 Times
what about motul then ?
Old 28th June 2007, 11:19   #22
Thanked: 9,697 Times
Dippy, in reply to your post on my vtec thread
I changed at 40000. Car felt tappety but it pulled harder and revved more smoothly. It tolerates harder use. Considering that it goes on the track every two -three months. It is worth it. Also car feels less ropey when a service is due. I have extended intervals to around 4-5k
Old 28th June 2007, 11:41   #23
Dippy's Avatar
Thanked: 163 Times
Thanks ajmat the regular recommended oil change is every 5000 kms. What should be the specific interval after changing to synthetic? Can it be 10,000 kms?
Old 28th June 2007, 13:04   #24
manveet's Avatar
Thanked: 585 Times
Default My Experience
I added Mobil 1 Supersyn to my OHC about a month and a half back after doing a thorough Engine Flush. My Odo was clocking about 68,000 then.
I distinctly remember noticing a very perceptible Smoothness to the engine when I red-lined just after the change.
Obviously, now I won't be able to tell you the difference because I've got used to the Mobil 1. But yes, the fact that I perceived a change immediately post change does corroborate the general belief that Synthetic Oil is good for the Engine.
manveet is offline   Reply With Quote
Old 28th June 2007, 16:45   #25
nitrous's Avatar
Thanked: 282 Times
@Dippy: I'd suggest a change of the transmission oil.
And yes, 10,000 is a good oil change interval.
Old 28th June 2007, 16:49   #26
Dippy's Avatar
Thanked: 163 Times
@nitrous : Absolutely. AT tranny oil is due for a change at the 40k service. Honda recommends a tranny oil change at every 20k kms.
Old 28th June 2007, 22:26   #27
higautham's Avatar
i'm going to have mobil1 for my OHC this week. only API-SM 5W50 is available here. is it ok for my car. odo status 53K.
higautham is offline   Reply With Quote
Old 28th June 2007, 23:09   #28
nitrous's Avatar
Thanked: 282 Times
Yes,Gautham. Go ahead.
But, dont forget to flush the engine before oil change.
Also,Id suggest we discuss lubricants in this thread:http://www.team-bhp.com/forum/modify...neral-oil.html (ARTICLE: Synthetic oil vs Mineral oil)
Old 30th June 2007, 09:05   #29
higautham's Avatar
I changed to mobil1 supersyn in my OHC yesterday. soon after the change, engine become smoother.
Lowering the OHC and other suspension queries manveet Modifications & Accessories 38 8th April 2011 13:16
Scorpio CRDe @ 70,000 kms! 5,000 of Agony & 65,000 of bliss smats Long-Term Ownership Reviews 17 8th May 2010 17:37
Transport your car by a bus: the Volkner Mobil jkdas Commercial Vehicles 39 3rd April 2010 14:50
Accent CRDI - Questions on Turbojet/SystemD/Mobil 1 Luke Technical Stuff 3 6th January 2007 11:01
mobil 1 for CBZ heavy_foot Technical Stuff 0 19th October 2006 06:10
