| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian | Hey guys, I thought it would be interesting to know the Best 0-60 and 0-100 times clocked by you guys. Cars, bikes, stock, modded... anything. I'm starting with mine. 0-60: 4.7 sec 0-100: 9.2 sec In my Opel Corsa 1.4 with some serious mods under the hood. (Mods, if you think this belongs in some other section, please move it) |
| | #4 (permalink) |
| Team-BHP Moderator ![]() Join Date: Feb 2004 Location: Bombay / New York
| For what its worth i would strongly suggest that when you post in this thread you mention the method you used to measure the speed and time taken. Its understood that these readings will be fairly inaccurate if the tools are a stopwatch and speedometer, but im sure we could still get within +/- 1 sec. cya R |
| | #5 (permalink) |
| BHPian | Well, used a nike lap timer (my wife clocked it sitting next to me). I know speedo is always a little above actual speed but somewhere I had heard that with oversized tyres, the speedo will actually show a lesser speed than actual (correct me if I'm wrong). My tyres are 195/50/15 as opposed to 175/65/13 stock. |
| | #8 (permalink) |
| BHPian | these are the speeds and respective times i have achieved: 0 - 60 kmph ----> 7.0 sec on my suzuki zeus @ 1100km on the odo in the CASTROL THROTTLE MAX, HYDERABAD. 0 - 100 kmph ----> 19 sec in my 2003 indics dls, measured using a stop watch by my cousin sitting next to me. |
| | #9 (permalink) | |
| BHPian Join Date: Aug 2006 Location: Bangalore
| Quote:
| | #10 (permalink) | |
| BHPian | Quote:
Under the hood: K&N cold air intake kit, 4x2x1 custom free flow exhaust with a Magnaflow mid pipe and race spec end can, FSE fuel pressure regulator with pressure boost valve, Iridium plugs and 2mm throttle body expansion, head porting and polish with mildly shaved pistons. (Getting a high lift cam and standalone ECM by July end, will keep you updated) | |
| | #12 (permalink) |
| Team-BHP Moderator ![]() Join Date: Mar 2004 Location: Mumbai, India
| What is a shaved piston? Does it mean you take material off the piston? That would drop compression? Or to create a dome to bump compression?
__________________ BE 6.5 You lose some, you lose some. |
| | #14 (permalink) |
| Senior - BHPian | K&N cold air intake kit - 1bhp? 4x2x1 custom free flow exhaust with a Magnaflow mid pipe and race spec end can- 2bhp? FSE fuel pressure regulator with pressure boost valve - Makes a difference ![]() Iridium plugs - 0 bhp? and 2mm throttle body expansion - Higher air flow. head porting and polish - 5bhp? with mildly shaved pistons - How does it help? (Getting a high lift cam and standalone ECM by July end, will keep you updated) - Now that is some serious mod. So what's the stock timing of a corsa 1.4?
__________________ Phoenix! |
| | #15 (permalink) |
| Senior - BHPian | even after mods u are unable to pull 100. Dude i can do that in stock and have done many times. I think your speedo has major error showing lower speeds.Maclaren its around 13.5 - 13.8 secs 0 -100 of stock..
__________________ For every idiot there is an equal and opposite gender idiot. Singles are people with incomparable intelligence! Last edited by abhibh : 29th June 2007 at 15:26. |
| Thread Tools | |
Similar Threads | ||||
| Palio and Panda replacements coming in 2009 - Times of India, Times Drive | 4strings | The Indian Car Scene!! | 14 | 5th June 2008 07:41 |
| Times Drive Errors | BUSA | Shifting gears | 7 | 31st December 2006 18:18 |
| Australian TV Times | GTO | Motor-Sports!! | 6 | 6th March 2004 01:52 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447
