Old 28th June 2007, 19:26   #1
easyrider's Avatar
Default Anti-roll bar in Scorpio
Can we fit a rear anti-roll bar in Scorpio to make it a more stable ride and avoid that dangerous SUV phenomenon "rollover" ?.
easyrider is offline   Reply With Quote
Old 29th June 2007, 11:37   #2
risga's Avatar
Thanked: 46 Times
Anti-roll bar can at best prevent the car from rolling while turning, but if you go beyond the safe thresh-hold centrifugal force, the vehicle will still tip over. In this case, there will be less warning.
Imagine a car with no suspension. Body just welded to the chassis having wheels. There would be zero rolling, but this contraption would still roll over. Cannot defy physics...can you.
risga is offline   Reply With Quote
Old 29th June 2007, 14:26   #3
Thanked: 103,368 Times
I thought the Scorpio already had a rear anti-roll bar? Whats the point?
Tata Manza Recall : Tata to replace anti-roll bar bush Turbo_Charger Technical Stuff 6 5th April 2012 11:21
Rear anti roll bar for Indica greenhorn Modifications & Accessories 4 13th February 2009 21:38
Can I fit anti roll bar on Swift ? abhaybakshi Technical Stuff 8 29th January 2007 20:04
Anti honda?? Anti suzi?? Anti fiat?? Anti ford etc etc?? Vent out ur opinions here!!! mclaren1885 Shifting gears 3 29th June 2006 14:23
