Thread Tools
Old 29th June 2007, 01:29   #1 (permalink)
rohitgaur's Avatar
Default T stands for TATA or Trouble, Tyre issues
Friends
A colleague of Mine , with his heart in the right Place went for the TATA Xeta, saying that TATAs have come of age and make the best cars around.
However , Trouble began when his First set of OE Tyres went balding(Alignment Out: Spoke the MRF Guy at the Agency), when one fine day One of those tyres gave out and he nearly lost his life on the everbusy G T Road. The Chap comes to the TATA agency & is told : Go for Tubeless Tyres, He dishes out 15 grand from his pocket to switch tyres at 5000KM (not a Typo, 5 0 0 0 . 0 0 )Five thousand Mark. Two months it is fine
Yet again the car is driving like crazy He drives down 125 KM and Lo , One More tyre has baldness showing clearly on the Inside , (It is the Left rear wheel)
Suggestions requested for going through with Customer care at TATA and getting this thing solved. He is willing to go legal for this
Advise Guys
RG
This is for a resolution by TATA as the car has extended Warranty , and is only 8 months old
__________________
NOW: 05 Palio 1.9D Canary Yellow, ELX SPRT/05 Santro Xing ERLX
PAST: 02 Palio1.2 ELX /02 Santro Xing/99 Gypsy KING/94 Yezdi CLII
rohitgaur is online now   Reply With Quote
Old 29th June 2007, 10:54   #2 (permalink)
Team-BHP Moderator
Jaggu's Avatar
check the wheel alignment first, then check the struts, looks like defective camber angle of one of the struts causing the wear
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 30th June 2007, 00:44   #3 (permalink)
Jaggu has pin pointed the exact problem , its definitely a defective camber angle problem and service centre guys will try to wash their hands off it by saying its a normal alignment problem .
spookey is offline   Reply With Quote
Old 30th June 2007, 21:55   #4 (permalink)
esteem_lover's Avatar
would you not have warranty ? TATA has to take care of that & they will. have you approached them & if you have, what was their response.
__________________
can't you hear me? What, do you have bubble gum in your ears ? like Mr.Bean ?
The Bean effect on my 4 year old
Old 30th June 2007, 22:16   #5 (permalink)
Sudipto-S-Team's Avatar
Your friend looks like is headed for a long and protracted battle. Till it is resolved, please ask him to keep rotating the tyres at regular intervals. If the previous set had to be junked at 5000 km, then the rotation should be done perhaps every 500 km.
Please keep us posted on the progress.
__________________
Humber, BSA (Indian), Yezdi, HH SS100, 800, Peugeot 309, Zen Lxi
Currently Bullet 350, Esteem Lxi
Sudipto-S-Team is offline   Reply With Quote
Old 30th June 2007, 23:15   #6 (permalink)
CrAzY dRiVeR's Avatar
Another thread to prove TATA cars haven't come of age!
Xeta must be a good VFM offer. but with problems like these popping up often, doesnt seem 'value' for money.
__________________
I'm far from perfect. I hope i can improve.
Thats why i'm here!
CrAzY dRiVeR is online now   Reply With Quote
Old 30th June 2007, 23:47   #7 (permalink)
wolfinstein's Avatar
It could be a Manufacturing defect with the Tyres..! AFAIK- TATA offers only Bridgestone/Apollo/Goodyear/JK Tyre as OEM Tyres...MRF suits Maruti the best ! Not any other car...!
__________________
" When was the last time, You did something for the first time "
wolfinstein is offline   Reply With Quote
Old 1st July 2007, 00:01   #8 (permalink)
Team-BHP Moderator
theMAG's Avatar
I think this Xeta is one of those that slipped thru Tata's tightening QC. Bad luck.
__________________
If you lose your temper, you’ve lost the argument
Old 1st July 2007, 00:37   #9 (permalink)
rks
rks's Avatar
@rohitgaur, I suggest your friend take a look at the section "Diagnosing problems from tyre wear" in the following website:
Car Bibles : The Wheel and Tyre Bible
In particular, the wear pattern in all the tyres should be examined in detail and then checked to see if they match any of the wear patterns described above (shoulder wear, centre wear, one-sided wear, spot wear, diagonal wear, feather-edged wear). Then the problem can be diagnosed from the given table.
Old 1st July 2007, 04:21   #10 (permalink)
speedzak's Avatar
It is normal for a new car to have alignment / wheel balancing problems. It should be clarified before and after we take delivery of the car. Even if it is a merc, it is always to recheck these things.
If the alignment and camber settings are fine, then you should've tried for a replacement in the first place itself. Now, It'll be a bit of a painful ride. But I wish your friend all the best.
__________________
If you want to see a rainbow you must first sit through the rain.
(Hungarian Proverb)
speedzak is online now   Reply With Quote
Old 1st July 2007, 09:17   #11 (permalink)
Harrie's Avatar
My Indica V2 had a simlar problem. But was not an issue with the alignment though. The steel braids in the rear right tire melted and the tire lost shape Was very funny how it happened. But got it replaced under warranty.
__________________
Its like turbo lag. But funny there isn't a turbo.
Harrie is offline   Reply With Quote
Old 1st July 2007, 13:02   #12 (permalink)
Team-BHP Moderator
tsk1979's Avatar
When our indica v1 tyres went bald at 10,000kms, we were given new tyres on a pro rata basis, at 1/3 of cost(Tata says tire life is 30K)
He should take it to higher ups. If that does not happen, legal is the way
__________________
Old 1st July 2007, 13:14   #13 (permalink)
I think you need to pursue the case and tata guys will certainly help you ,they know there problems better than any body else a can quick Fix them ,and 1 % if they dont help then consumer court is the name of the game, just a 2 days back only in another thread i had told a guy to stay away from xeta and buy a wagon R or Santro ,and tatas have certainly not come of an age they only give inexpensive cars , with little money for service and spares ,but the cars are nowhere near as reliable as one expects them to be
rubin2006 is offline   Reply With Quote
Old 1st July 2007, 13:17   #14 (permalink)
Team-BHP Moderator
Zappo's Avatar
I think your friend needs to call up the regional headoffice and talk to a senior customer care manager. Normally that does the trick in 90% of the cases. If it does not seem to work out write a stinker to the Tata Customer care. By then your friend probably would have gone into it for the long haul.
__________________
Announcements are important.
  • Read the Advertising Announcement here.
  • Classifieds section has its rules. Read here.
Zappo is offline   Reply With Quote
Old 1st July 2007, 14:00   #15 (permalink)
dockap's Avatar
TATA=Tension And TROUBLE Always
dockap is offline   Reply With Quote
Thread Tools
Puncture (tubed tyre) and tyre type/age rex_varghese Tyre & Alloy wheel Section 2 13th November 2007 19:19
The new BHP-ian stands up! eflanker Introduce yourself 5 30th July 2007 11:58
Which Tyre for my Tata Indica v2. rkbharat Tyre & Alloy wheel Section 0 7th September 2006 17:34
Gash in Tyre at the edge of the tread...safe or trash the tyre ? zaphod Technical Stuff 8 31st August 2006 13:24
What does these names stands for toyota Shifting gears 36 24th May 2005 00:06
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
