Old 2nd July 2007, 13:30   #1
sbasak's Avatar
Thumbs down Oil pressure warning light
Old Ambassadors used to include an oil pressure gauge in the dashboard.
Modern cars have dispensed this to save cost.
Instead they include a tiny red electronic bulb to warn low oil pressure.
Manual says if the light comes on, stop immediately or you'll damage the engine seriously.
i.e. without oil, pistons will stuck inside cylinder bore!
Now my question is, at what level, the warning light comes up?
If the light ever comes up, how soon one need to stop?
I searched on it on Google, but surprisingly, many sites say if the light ever comes up it means already some damage has been done to engine!
I doubt how many of us check dipstick even every fortnight!
PS: How much does it cost to fit an oil pressure gauge?
sbasak is offline   Reply With Quote
Old 4th July 2007, 11:24   #2
nitrous's Avatar
Thanked: 285 Times
During my last oil change, the oil pressure light stayed on for atleast 4 seconds after start. But, the dipstick showed a reading between max and min.
When i drained the old oil , i noticed that there wasn't sufficient oil in the sump.
During my new oil fill, 3 litres went in before checking the dipstick. The oil level is about 3mm higher than the max mark.And the specified engine oil capacity for my ikon's 1.3 is 3.8L. Im puzzled with this misleading dipstick!
The 'Actual' Tyre Pressure : Is Atmospheric Pressure Counted? sr_1445 Technical Stuff 2 16th January 2014 11:05
Do you know this symbol? EDIT - Low Tire-Pressure warning Symbol akas_chauhan The International Automotive Scene 21 19th August 2010 09:23
Low Oil warning light RJK Technical Stuff 9 6th July 2008 11:52
Chevrolet Spark Seat-belt warning light adya33 Technical Stuff 13 22nd February 2008 18:00
