Old 2nd July 2007, 20:54   #1
Unhappy 1999 Baleno - Check Engine Light
While driving the check engine light appears and the car loses power and shut off. This occurs randomly. Also if i keep the car rev high the car will drive but the check engine light is still on. The light will disappear if the car is off for over 2 hours. The diagnostic error code is 47 which is not listed in any suzuki books i have.
ecurb_jm is offline   Reply With Quote
Old 2nd July 2007, 22:26   #2
mclaren1885's Avatar
Thanked: 28 Times
Infractions: 0/1 (10)
Though I am not quite sure of what error 47 is, I suggest you show the car to a tuning company who can diagnose the problem. One thing is for sure, the ECU has gone into safe mode. Do check the crank position sensor and the cam position sensors once. Or since you say the light will disappear if the car is off for over 2hrs could it be a heating issue?
Old 10th February 2008, 23:37   #3
Default Baleno Check Engine Light
Hi, i have joined T-BHP very recently ,the probelem u have mentioned is been diagnosed by us long time back in 2001 this is from a faulty CMP SENSOR. This sensor is manufactured by Mitsubishi . replace it with a new one but make sure the one u replace is manufctured after 2004 as there was a problem reported before this batch. Allso change your engine oil after proper flushing with this activity.
alankarmotor is offline   Reply With Quote
Old 11th February 2008, 11:05   #4
spadival's Avatar
Thanked: 16 Times
alankar, your answer is absolutely correct.. but you are a bit late !!
Anyway, CMP conking off seems to be a common problem. Any idea how much would a replacement cost?
spadival is offline   Reply With Quote
Old 11th February 2008, 13:49   #5
HI, the reason for me being late is that i have joined the forum in dec 08.The cost of CMP sensor is aprox Rs 2300/-
Old 11th February 2008, 14:44   #6
spadival's Avatar
Thanked: 16 Times
You mean Dec 07 .. Dont u ..
Thanks for the details.. Sent you a PM on Tech2. Please respond.
Old 17th December 2011, 21:41   #7
Thanked: 48 Times
Default Re: 1999 Baleno - Check Engine Light
is CMP sensor of Baleno interchangeable with other marutis like alto, just like many people have used O2 sensor of alto to replace O2 sensor of Baleno (at a lower cost and easy availability)
rock75 is offline   Reply With Quote
Old 22nd December 2011, 11:51   #8
Thanked: 94,655 Times
Aasspl dropped the following reply for you:
Theoretically there is no difference,between CMP sensors of Versa, old Swift,and the Baleno, the difference is only with the coupler design. The values are the same, but there is hardly any cost difference. Just make sure if you are buying Baleno CMP,then the manufacturing year of the sensor should be post 2006. This was the time it was identified at Maruti. Also make sure to flush the engine oil and replace with new one before you replace the sensor.
Maruti Esteem Check Engine Light Blinking amitpunjani Technical Stuff 10 12th November 2012 16:41
Vista Tdi - Engine oil and the Check engine light turns ON skartik2 Technical Stuff 4 27th August 2009 14:50
Check engine light on thanks to mechanics msharma_79 Technical Stuff 14 13th February 2008 03:39
"Check Engine" Light! adman77 Modifications & Accessories 22 31st July 2007 15:44
Check engine light mystery gbpscars Technical Stuff 7 4th December 2006 23:12
