Old 4th July 2007, 22:33   #16
rishibravo's Avatar
Originally Posted by merve_extreme View Post
"Furr Furr" sounds comes because your silencer or the connecting pipes have rusted and have holes in them.you have to change the silencer or the pipes for this.
but his car is brand new.. I dont think its the rusted piped problem.
rishibravo is offline   Reply With Quote
Old 4th July 2007, 22:58   #17
merve_extreme's Avatar
Thanked: 12 Times
maybe then some part of the exaust must have come lose.
merve_extreme is offline   Reply With Quote
Old 5th July 2007, 03:19   #18
Thanked: 17 Times
He should get his car checked by a Fiat A.S.S. I'm sure There's something wrong in his ECU because he says his warning lights are behaving like christmas lights.
The above mentioned problems like silencer coming loose etc... Doesn't apply. Because, I've heard a lot that Fiat is a very strong and reliable car.
Old 5th July 2007, 03:31   #19
Thanked: 12 Times
I own one and the silencer has a tendency to get rusted.If there is anythig wrong with the ECU the injector lamp will remain continously lit and not go off.
Old 5th July 2007, 12:04   #20
kapilsharma80's Avatar
Thanked: 28 Times
Guys, thanks for the help, even io think that one of the silencer couplings is loose. The expert guy at the dealersip is on leave so have to wait till Wednesday
GOD Bless my car!!
kapilsharma80 is offline   Reply With Quote
Old 5th July 2007, 12:48   #21
moralfibre's Avatar
Thanked: 6,533 Times
Kapil, this has happened to one of the cars at my dealer and my works manager friend suspects loose wiring! Nothing too complicated here, basically that light comes on as soon as you turn "ON" the ignition key without cranking the engine. The light denotes that the fuel pump is building up the desired injector pressure for cranking the engine and as soon as you hear a "tak" sound (the fuel pump relay cutting off) the injector light goes off. So check the relay and the related wiring and you should be good to go. Keep us updated on what the F.A.S.C (Fiat authorised stupid center) has to say!
Petrol Telgi? (Petrol Theft in Parking Lots) msprabhakar The Indian Car Scene 37 3rd December 2013 22:29
My Story of Going from Petrol (Palio 1.1) to Diesel (Palio MJD) ant_vas Test-Drives & Initial Ownership Reports 13 8th November 2010 14:28
Aveo 1.4 Petrol Base Variant or Swift ZX Petrol amitsethi100 Hatchbacks 23 27th October 2007 20:04
Petrol & Petrol Additives askulkarni Technical Stuff 42 6th May 2005 09:59
