Thread Tools
Old 3rd July 2007, 20:52   #1 (permalink)
Exclamation Swift switching off
Hi All,
A few weeks ago my Swift Vxi suddenly switched off when I was driving back home from work at night. I kept cranking it but it refused to start. Checking under the hood revealed no clues. All fluid levels were normal and it was not overheating either. After about 10 minutes it started but the check engine light remained on. I drove back home with the engine light switched on. The next morning when I started it, everything was fine and the engine light did not stay on.
I drove to Pratham motors and asked them to check it out. The service engineer asked his electrician to inspect all wiring and the engine diagnostics as well. They found nothing amiss and remarked that some stone might have hit one of the sensors and caused the ecm to refuse to allow the car to start. But other than that they gave a clean chit.
I shrugged it off as a one time thing and did not find any problems after that. This evening while driving back home again the same thing happened. Engine suddenly switched off, refused to start. After 15 minutes it started with the check engine light on. This time I drove it to a corner, switched the engine off and waited for another 10 minutes. When I started it after this the light went away. I am completely perplexed by this. Now I know it is not a one off thing. But the problem with taking it to a service centre would be the same. The problem wont repeat itself when they do a checkup and I am not sure of the exact conditions under which this issue would crop up.
What could be wrong!!!!!
abinesh is offline   Reply With Quote
Old 3rd July 2007, 21:46   #2 (permalink)
low_bass_makker's Avatar
i think some sensor is misbehaving here.
Old 3rd July 2007, 22:06   #3 (permalink)
Do you have any immobilizer? If yes, it must be giving problems. This depends on how old is your swift?
neel12345 is offline   Reply With Quote
Old 3rd July 2007, 22:18   #4 (permalink)
merve_extreme's Avatar
Check your ignition coil.does the car shrudder while engine switches off ?
__________________
No one has done more to improve the automobile than the one who invented it ----- Mercedes Benz
merve_extreme is offline   Reply With Quote
Old 3rd July 2007, 22:48   #5 (permalink)
I dont think the igntion coil is at fault. The car is just 5 months old and has run only 3.5K kms. There is no shuddering whatsoever when it switches off. It just silently turned off when I was driving. I noticed it only when I sensed the loss in power and glanced at the dials.
The car did have an accident about 3 months ago wherein the left side doors along with the front suspension components were replaced. Apart from these the AC compressor, the Crankshaft Position sensor and the driveshaft were also replaced. Could any of these replacements be responsible for this problem?
Old 3rd July 2007, 23:12   #6 (permalink)
then why does the engine light lit up on the console
same here
why are these replaced because of the accident.
Old 3rd July 2007, 23:27   #7 (permalink)
Its difficult to conclude immediately on the system but we can narrow down, The Major system which gives you malfunctioning while running are fuel system, ignition primarily !
Fuel system:
- It could be either fuel system leakage (20%)or Fuel pump loose connection (80%)
- Sparking / Ignition coil circuit
- 2 days is the switch off happened in the same area, Incase you have strong pot holes, speed breaker defnitely pump loose wiring ! we design these parts for some other vehicles ! Incase this happens on sudden gear change and acceleration mode it confirms the same.
The above reasons would miss firing a particular cylinder. (Engine missing is the word used)
sparking: It would be again loose connections wiring - 3.5 k seems to be less reason for the same.
Swift - You should insist the maruti service manager to check for engine control unit using diagnosis tool . That MUST give you the reason code for intermittent switch off. They are recorded in the ECU. Bangalore, let me know where do you work ? Let us ask the Bimal service to check as we have contacts there. Or at the worst case me and my application engineer will try to check your vehicle (we will not open any component !)
Meenakshi
meenakshi is offline   Reply With Quote
Old 4th July 2007, 00:03   #8 (permalink)
mclaren1885's Avatar
Check the crank position sensor once again. Also, it is quite possible for the crank pulley to have taken a hit. In such cases car will normally refuse to start. Check the teeth of the crank pulley to see if there is any crack.
__________________
I am proud of you, binzy boy !!! Keep up the good work.
Old 4th July 2007, 00:05   #9 (permalink)
The front and left portion of the car sustained some damages during the accident. These among others were some of the parts replaced.
Old 4th July 2007, 00:19   #10 (permalink)
it is an eletrical or elctronic issue for sure,because with an mechanical issue the problem will be persistent and not intermittent like this one.also it will not resolve itself.
Also an ignition coil failure can happen any time due to any reason and will mostly not be detectable on a scanner machine.
Does the warning light come on immediately or after your try a few restarts,because if it comes after a few attempted restarts its OK (i think you check light comes on because of multiple failed restart attempts and not because of the problem that kills you engine).
Tell me one thing,once the car stops and then you wait and restart it like you said after 10 mins,how long can you go before it stops again.
__________________
Old 4th July 2007, 00:28   #11 (permalink)
esteem_lover's Avatar
Hi All,
Sorry to hear about your problem, please leave your car at a Maruti A.S.S and ask them to sole the riddle.
Are you sure your the software in your ECM has not been developed by Microsoft ? it sure has all the ingredients of a windows failure.
__________________
"can't you hear me? What, do you have bubble gum in your ears ? like Mr.Bean ?"
The Bean effect on my 4 year old
esteem_lover is online now   Reply With Quote
Old 4th July 2007, 08:54   #12 (permalink)
The vehicle does not start for about 10 minutes. When it finally starts the light comes on. If I switch it off then and start after another 10 minutes it goes away.
As of now this problem has cropped up again after a period of 3 weeks. During that intervening period there was no problem whatsoever.
Old 4th July 2007, 11:37   #13 (permalink)
Take it back to the dealer. Don't think that it's OK, it won't happen again.
There seems to be a problem w/ the starter circuit of Swifts. Sometimes it turns off, won't turn on. Sometimes it'll turn on spontaneously.
Other people are having this problem, so have some backbone and don't let them tell you differently.
caliper is offline   Reply With Quote
Old 4th July 2007, 11:43   #14 (permalink)
Sideways's Avatar
I would have to agree with mclaren, although I don't expect any harm to the pulley. Just have the Crank sensor checked.
__________________
He's Back
Sideways is offline   Reply With Quote
Old 4th July 2007, 11:43   #15 (permalink)
lohithrao's Avatar
This problem occurs in the evening, so might be some electrical malfunction. try to on the headlights in the morning and fdrive for a while. should be able to spot the issue.
__________________
" I'd rather live with the consequences of my actions rather than the regrets of my inactions."
lohithrao is online now   Reply With Quote
Thread Tools
Switching on Your AC in Cold Start esteem_lover Technical Stuff 172 25th June 2008 12:44
Zen - Engine Switching off on long drives Tiger Technical Stuff 10 11th January 2008 09:28
Switching Tyres Accent - - Santro vkochar Tyre & Alloy wheel Section 0 5th April 2007 16:09
Switching off with AC dsinz Technical Stuff 5 13th September 2006 11:51
Idling the Turbo engines before switching off.. Could this be a solution? DRC Technical Stuff 14 5th April 2006 21:19
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
