Old 5th July 2007, 12:37   #16
moralfibre's Avatar
Thanked: 6,532 Times
Originally Posted by BUSA View Post
I want to know things like oil filter(purolator is a good brand i have heard), gear fluid, brake fluid, radiator flush, coolant, etc can be bought from outside or is it better to let the GM guys do it, wont it be cheaper outside or is it? Can i get stock plugs cheaper outside.And is KnN oil filter good, i heard its not recomended.
Oil Filter + Gear Fluid + Brake Fluid + Radiator flush + Coolant + plugs combined will not set you back by more than 1k and its better to stick to the service station for this but if you want to save up then you can opt for aftermarket stuff from Opera house which is quite some distance from your house (New Bombay) and you wont make much difference I suppose. Make sure you get Spark plugs with the correct Heat range for the Optra.
Old 5th July 2007, 12:41   #17
BUSA's Avatar
I guess i will leave all that to the service guys, including the sparks.
Well i will be going to Opera for Mobil1 and Abro.
Optra takes in 4 liters of oil(3.8 in the engine and 200ml in the oil filter)
Edit - Any inputs about KnN Oil Filters? The service guys at GM told me that a KnN air filter is not a problem but please dont change the oil filter to KnN.
Old 3rd August 2007, 16:44   #18
BUSA's Avatar
Bump. Guys is it ok if i put 5W40? Since Mobil1 dealership doesnot have 5W50 and service is tomorrow.
Flush i am not buying since GM uses OWS(German) flush.
He was saying OWS, Oozze.. LOL
40000 km = 80000 km. 2007 Verna CRDi. Got cheated, Now sold. sarthakgupta Long-Term Ownership Reviews 39 5th November 2014 17:21
My Red Pimento - Maruti Swift Vdi Euro IV review - 40000 Kms update ontheroad Test-Drives & Initial Ownership Reports 19 9th June 2013 20:01
Letz Getz Started (Hyundai Getz CRDi)- UPDATE: 40000, new alloys, tires!!! (page 30) ph03n!x Long-Term Ownership Reviews 598 6th November 2012 00:02
