Thread Tools
Old 4th July 2007, 13:22   #1 (permalink)
sans33's Avatar
Default Palio fuel pump
I have just got my Palio 1.6's fuel pump replaced at an authorised Fiat dealer.These people told me that fuel pump is same for both Palio 1.2 and 1.6.But,while I was enquiring about availibity of pump at different dealers,they always asked me for 1.2 or 1.6.Also,old pump from my car and new one,they have installed are a bit different in shape.I'm not satisfied with power and pick-up either.Is it possible that they have fitted a 1.2's fuel pump in my car as 1.6 was not available?Help
__________________
Great ideas need Landing gear,as well as,Wings.
sans33 is online now   Reply With Quote
Old 4th July 2007, 15:41   #2 (permalink)
moralfibre's Avatar
Sans33, I confirmed that the fuel pump is same for the 1.2 as well as the 1.6. Dont worry. The issue with low power and pick-up could be something else.
__________________
Ask not what your country can do for you, think of a way you can make them do it!
Old 4th July 2007, 21:07   #3 (permalink)
sans33's Avatar
Thanks moralfibre. I have recently purchased this S10. It had this faulty fuel pump. I was expecting some improvement in performance after change but its just same. It feels sluggish in city traffic. Below 2000 rpm acceleration is not crisp and sharp. It also has some starting problem. It starts normally in morning,but when re-starting at traffic signals,it turns me nervous. It either start in a instant or take atleast 2-3 long rounds, as if flooded.FE is 9 without ac and 8 with mix ac usage,all with light foot and quick gear changes. I use IOC Premium only in all my cars.
__________________
Old 5th July 2007, 11:02   #4 (permalink)
moralfibre's Avatar
Changing the fuel pump wouldn't improve performance. Atleast not that I know of any performance benefits with a new fuel pump. What was wrong with the old one and why did you replace? Any breakdowns you faced with the fuel pump conking off?
If you expect crisp acceleration, the car needs to be revved up and shift at more than 4000 rpm which you cannot do in city traffic. But there seems to be some prob with your car because I haven't experienced sluggishness in shifting up at 1100 rpm which I do when I am driving conservatively.
Weird starting problem, normally it is the other way round. Get the car checked. Boss, FE depends completely on driving style and traffic conditions.
__________________
Old 5th July 2007, 14:29   #5 (permalink)
sans33's Avatar
I didn't change the fuel pump for performance.It was giving trouble in Delhi summer.It used to stop after about 20 kms.I got car checked at three different dealers,all had same solution for all my problems,change the fuel pump.
__________________
Old 5th July 2007, 20:53   #6 (permalink)
moralfibre's Avatar
I agree Sans but I probably misread your posts and gathered that you anticipated better performance!
__________________
Old 5th July 2007, 22:50   #7 (permalink)
gr8guzzler's Avatar
Sans, what trouble was the fuel pump giving you earlier? Was the car jerking while accelerating? Was the motor weak?
As moralfibre has suggested, changing a fuel pump would not give you better performance, it must have would however taken care of the initial problem you were facing.
__________________
Kishore
gr8guzzler is offline   Reply With Quote
Old 8th July 2007, 21:03   #8 (permalink)
Hi...I bought a used Palio GTX a month ago. A few days ago it started to vibrate when the car used to be stationery(idle). The vibration increased quite a lot when the AC was turned on. The engine noise also changed and the car lost a lot of power during acceleration....The acceleration feel was not the same.The fuel injector light remained constantly ON.
I have taken the car to Shaman Mumbai, and have yet to receive it back. They say that two out of the four fuel injectors are spoilt. They are replacing the two injectors.
Is this a major problem? I hope the performance of the car comes back to its original specs.....
Any advice on how this may have happened. Is it fuel quality. The car has clocked 50K...Is this a usual problem for this age of car?
__________________
Vikram
Palio GTX (2002)
gudakesh is offline   Reply With Quote
Old 9th July 2007, 13:28   #9 (permalink)
gudakesh
Do you still have the same problem?? I had the same problem... (I would say very same symptoms..)
The car would vibrate a lot and more so when AC was turned on. I went to*BU*Bhandari.*Now*this*is*what*they*done*so*far* and*looks*like*it*will*resolve*problem.
I will get my CAR today, so let's see.
1. checked spart plugs - all ok
2. ignition ciol - all ok
3. opened the injector body. One injector totaly blocked with black material. Result of impure petrol and adulteration.
They also cleaned petrol tank and replaced fual filter.
Sent the injectors for cleaning and will be fitting them. Let's see.
.wysiwyg { background-attachment: scroll; background-repeat: repeat; background-position: 0% 0%; background-color: #ffffff; background-image: none; color: #000000; font-family: Verdana, Arial, Arial; font-style: normal; font-variant: normal; font-weight: 400; font-size: 10pt; line-height: normal } p { margin: 0px; }
cranil7 is offline   Reply With Quote
Old 9th July 2007, 13:39   #10 (permalink)
gudakesh,
Very same symptoms here. The car would vibrate excessively and more so when AC is turned on.
This is we have done so far. (BU Bhandari Pune.)
1. checked all spark plugs-ok
2. checked ignition ciol - ok
3. Opened up all injectors and found one was completely clocked.
They say bad fuel-adulterated fuel. It was completely blocked.
They sent it to cleaning and will be fitting back today.
In the process they also cleaned the fuel tank and replaced fuel filter. LEt's see what happens. I will get delivery today.
Old 6th August 2007, 21:52   #11 (permalink)
Default Fuel Injector
How is your car working now? In my case, they replaced two injectors and gifted me a heavy bill.
A couple of weeks ago the same problem started. It happened the moment I reached my office's parking lot. I parked the car and went to office to do my work. When I came back in the afternoon and was to take the car to Shaman, the problem was gone. I however , went there , where they ran some diagnostics but did not find any problem.
I havent driven much since then, as I am out of town mostly. The problem has not recurred, but I have lost confidence in taking the car to long drives.
Anyway, I was surprised to learn that the fuel injector can be cleaned.....Looks like the folks in Pune dont gift customers with heavy bills. An injector costs Rs 4000+.
Best Wishes
- Vikram
Palio GTX (2002)
__________________
Vikram
Palio GTX (2002)
Thread Tools
Wanted: 2nd hand Fuel Pump / Fuel Pump Body ramie2400 Shifting gears 2 6th October 2007 11:16
palio 1.6 fuel pump motor sans33 Technical Stuff 5 27th April 2007 15:57
PalioD fuel pump Lukeskywalker Technical Stuff 6 26th January 2007 16:57
Fuel Pump Pressure valve cheatingdeath Technical Stuff 1 27th November 2004 11:05
Fuel Pump Filter cheatingdeath Technical Stuff 0 28th August 2004 09:29
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
