Old 19th January 2009, 15:19   #76
jassi's Avatar
Thanked: 11 Times
Smile
Originally Posted by bblost View Post
I dont know about Pune.
But in Hyderabad the number plate of the vehicle is photographed and printed on the PUC certificate.
same for bangy - infact on my rear plates one alphabet is slightly come off and they ensured they took a pic of the front plates instead !!
jassi is offline   Reply With Quote
Old 26th April 2010, 17:19   #77
krazydriver84's Avatar
Thanked: 42 Times
Hi guys,
I recently had to get my cat con removed because it was all broken inside.
After the removal I have experience huge decrease in FE.
Am currently getting a FE of 12km/l on my M-800 (MPFI) whereas i used to get 17km/l.
Please advise if its due to the removal of the Cat Con.
Thanks.
krazydriver84 is offline   Reply With Quote
Old 20th May 2010, 20:51   #78
clevermax's Avatar
Thanked: 445 Times
Originally Posted by moralfibre View Post
Guys I wanted to know whether getting rid of the Cat-Con on the Palio will make any different to the performance?
Same case here,
I was contemplating on removing the catcon in my Palio and putting it back after removing all the stuff in it so that it only acts as an expansion chamber.
Just wanted to know whether this will be a better option instead of removing the catcon and placing a straight pipe in its place. Your thoughts please...
clevermax is offline   Reply With Quote
Old 28th September 2011, 21:58   #79
chetanhanda's Avatar
Thanked: 44 Times
Default Re: Removing a Catalytic Converter (Cat Con) - Do you guys think its worth it?
Same case here,
Replying nearly a year late ..
But gutting a cat is one of the worst possible things that can be done to your exhaust system.
Its got to be a straight through pipe of the same bore as the existing pipe.
Expansion pipe/Gutted cats are bad for the velocity of the gas flowing through your exhaust, these things break up the continous stream of exhaust pulses and create turbulence.
Trust me I have tried Gutted cat, aftermarket hi-flow Cat(magnaflow probably 900/99000 something series dont remember exactly),expansion pipe and straight through (with stock headers but aftermarket axle backs)
Main difference is the driveability(more torquey), tone and top end power...
Nothing beats a straight through..followed by a hi flow cat for the velocity, avoid the gutted cat and the expansion chamber.
But I somewhat love the raw sound with the straight thru
Last edited by chetanhanda : 28th September 2011 at 22:05. Reason: model number of hi flow cat
chetanhanda is offline   (3) Thanks Reply With Quote
Old 29th September 2011, 10:21   #80
sgiitk's Avatar
Thanked: 3,884 Times
@chetanhanda; Absolutely correct. We had to remove the catcon our our old Zen in 1997 since Unleaded was not freely available. I managed to drive from Kanpur to Manipal without having to go for leaded (just, since at one point the fill was 32+ l). So in Manipal I has the MASS remove the cat (no unleaded in Manipal). He did exactly what you suggest. Replace the cat with a pipe of identical diameter and length. Six months later Unleaded was available, so the cat went back after a few months.
sgiitk is online now   Reply With Quote
Old 29th September 2011, 11:50   #81
Thanked: 44 Times
That works best..
Can you let us know your experience in terms of driveability with and without the cat ? what felt good ?
Sometimes the gut feel on the road means more than dyno numbers.
chetanhanda is offline   Reply With Quote
Old 18th October 2011, 10:24   #82
fiat_tarun's Avatar
Thanked: 640 Times
I had been experiencing drop in pick up and a throaty sound from my air filter in my 2004 MPFI Zen the last few days. Took it to MASS yesterday and he said the cat con was all clogged up and that he cleaned it. The car is flying now. The pickup is just awesome (especially the top end).
Called him up this morning to find out if he had removed it as from what i've read cat cons cannot be cleaned, but need to be replaced. He inisists that he only cleaned it and that its good to go for another 10k odd km. Can a cat con be cleaned ? And anyone has any idea how much a new catcon costs for a Zen ?
fiat_tarun is offline   Reply With Quote
Old 18th October 2011, 11:27   #83
sgiitk's Avatar
Originally Posted by chetanhanda View Post
That works best..
We felt no difference with and without the Cat. Remember it was a Carb Zen, with all of 50 horses.
Old 2nd September 2013, 14:00   #84
clevermax's Avatar
Thanked: 445 Times
My cat con us 8 years old (as old as the car). Do these components continue to function as expected, or can they turn into unnecessary artifacts inside the exhaust system thus affecting the the gas flow?
I am thinking to remove the cat con - if my assumption that its functionality has deteriorated over time can be proven correct
Old 2nd September 2013, 17:03   #85
saket77's Avatar
Thanked: 5,043 Times
A catalytic converter, if taken proper care of, mostly by using the correct (unleaded) & unadultered fuel will last as long as the normal life of the car. Though, some carbon & some compounds spit through the exhaust can lay a layer over the metals which are used as catalyzers, which can reduce its efficiency, since the exposure of those metals inside the cat become limited to the exhaust gases.
However, its efficiency is only reduced somewhat, but still they are quite effective. I think that a car without a Cat-Con will not pass the emission tests too. Also, Cat cons can clear the deposits with some long runs but this is just my opinion, not very sure about this.
My opinion is not to remove it. More than anything, it is illegal too.
Saket
saket77 is offline   Reply With Quote
Old 2nd September 2013, 18:12   #86
tharian's Avatar
Thanked: 3,168 Times
Cars without the cat-con do pass emission tests, It is just that they will not adhere to the emission norms set when they rolled out from the factory.
Removing the cat-con will give you a load of extra power for sure.
In my opinion, it is better to just leave it if you feel there is no harm it is doing.
tharian is offline   Reply With Quote
Old 3rd September 2013, 13:05   #87
Prodigy07's Avatar
Thanked: 329 Times
The stock Muffler in my Fiesta 1.6 has been replaced with a Cosworth End Can. The Catcon/Resonator is still in place.
Over the last few weeks, I have been noticing a drop in power and sluggish behaviour in the second gear. Should I go ahead and remove the Catcon and replace it with a straight pipe or get a new Cat con?
Can someone guide me please?
Prodigy07 is offline   Reply With Quote
Old 31st October 2013, 16:43   #88
Prodigy07's Avatar
Thanked: 329 Times
Mods, sorry for back to back posts.
Though I didn't get a response for my above query, I went ahead and removed the Catalytic converter/Resonator and fixed a straight pipe. I got this job done along with the 40K service at a Bosch service centre. Now, I find the pick up better and there is no sluggish behaviour. But, a new issue has cropped up. I hear a wierd sound from the End can whenever I stop pressing the accelerator. I am not sure about the right term to use, but I can sense something similar to a Drone/Rattling noise from the exhaust.
Guru's, could you please help me out?
Old 2nd November 2013, 02:08   #89
Thanked: 14,604 Times
Sorry for the late reply.
I feel the replacement of the end has made the fuel be lean and so loss in power. Post replacement you should have made the mixture a bit rich. Not to rich also to lose on efficiency and it would cause carbon deposits in the cylinder head.
The sound is normal and nothing to worry. I guess this sound is only heard when the foot is lifted from the accelerator. Right?
Can you just find what the Bosch guys do for the sluggish behaviour or was it solved pay the end can change.
Anurag.
a4anurag is online now   Reply With Quote
Old 4th November 2013, 14:39   #90
Prodigy07's Avatar
Thanked: 329 Times
Anurag.
Yes, the wierd sound comes only when I lift my foot from the accelerator.
Bosch folks did the routine 40K service. Apart from this they replaced the Cat con with a straight pipe. The Cosworth End can stays in place.
Think Volvo Buses, think safety? Think again! rahul_intlad Commercial Vehicles 89 14th April 2016 12:09
Wagon R: Noise from Catalytic converter? EDIT: Cat Con is GUILTY. bblost Technical Stuff 26 12th July 2012 15:08
2011 i10 Asta A/T - its Korean, its new, its fast, its red, and its coming. nirupesh Test-Drives & Initial Ownership Reports 1 8th January 2011 10:45
Settings gone after removing HU and removing key achopraa In-Car Entertainment 14 15th December 2007 22:18
