Old 5th July 2007, 11:03   #1
Akshay1234's Avatar
Thanked: 7,242 Times
Default noise and vibration
when a take a right turn in my getz above 70kmph. the steering wheel starts vibrating and there is some noise. this also happens if a go in a circle above 20 kmph. send it for a service a few days ago and they were supposed to do wheel alignment and balancing. any ideas guys?
Old 5th July 2007, 11:08   #2
viper's Avatar
Thanked: 9 Times
Its either something fouling in your suspension or your wheel alignement is out.
Viper
viper is offline   Reply With Quote
Old 5th July 2007, 11:13   #3
If the noise has not disappeared after wheel alignment / balancing
1. Is the noinse and vibration observed only when the steering is at its extreme right position? if this is the case it could be a problem with the wheel bearing on one or both of the front wheels.
2. Similar problems are noticed with matuti 800s that have doen considerable years of flogging. In their case the noise and vibration is due to worn out joints on the font drive axles (being front wheel drive cars)
the answers to these questions could throw some light as to the real cause of the irritant.
barry is offline   Reply With Quote
Old 5th July 2007, 11:14   #4
Akshay1234's Avatar
Originally Posted by viper View Post
Viper
but ive only noticed it after we put on the exhaust. i think itll be something to do with the suspension since the alignment was supposed to be done.
what if i put on the spare wheel and try it?
Old 5th July 2007, 11:19   #5
How old is your Getz? How much beating has it taken? As Viper says, it could be someting fouling with your suspension ... do you notice the noise when the steering is turned to its extreme right position at any speed?
Old 5th July 2007, 14:01   #6
Akshay1234's Avatar
its 1.5 years old and has done 15k kms. not ben driven badly at all. this used to happen when i went around a circle above 20kmph but tday when i took a medium right turn at 70 the same thing started. willl get it checked in a bit.
Old 5th July 2007, 14:56   #7
risga's Avatar
Thanked: 46 Times
I have a Getz of similar vintage. I am sure your car feels as good as new.
Did you by any chance bend one of the wheel rims or bump the suspension while driving over a pothole recently?
risga is offline   Reply With Quote
Old 5th July 2007, 20:10   #8
Akshay1234's Avatar
nope. but ive gone to 120 on a straight and its fine. only when i turn the vibration and noise start.
Loud noise and vibration with A/C on Maruti Ritz cs_rajesh Technical Stuff 20 1st May 2013 23:32
Windshield vibration noise in Fiesta gadget.fr Technical Stuff 18 8th February 2012 16:45
Damping Safari 2.2 - My Experiments with in-cabin Noise/ Vibration Reduction Ishlesh In-Car Entertainment 13 9th February 2011 15:47
Engine Vibration & Noise Aashutosh Technical Stuff 1 2nd January 2009 10:32
Noise and vibration in Baleno engine sans33 Technical Stuff 14 20th June 2008 18:42
