Old 12th June 2009, 14:15   #16
Thanked: 49 Times
Default I woke up but my car didn't
Posting my problem here in this thread. The background -
Its a 2000 model (carb) M800 with 1.1L km's on the odo. The engine's a tad coarse but decent FE and not so high oil consumption (burns about a half liter in 1500 Km's). I haven't been able to get a compression test done. The FE stands at 15(city) and 18(highway). She was running just fine until today morning.
The problem -
I started her up today morning and the idling seemed a little higher. Anyways - slotted her into gear and the pickup was absent - stopped and let her idle for a couple of minutes (with the choke) and tried to wake up the engine. There's noticeable shudder the moment the RPM rises above idle.
My first thought was - maybe a rat bit thru a wire in the ignition system. Didn't find any damage - no cut vacuum hoses either. I'd filled her up yesterday at Shell so I didn't think that the fuel was bad.
Dragged her to work (was really late) and the engine sounded normal once it got moving to higher RPM's. But the shudder and low pickup are still there.
Any suggestions on what to look for ?
CrackedHead is offline   Reply With Quote
Old 12th June 2009, 14:54   #17
Thanked: 16 Times
Seems like one of your sparkplug is misfiring. get your distributer also checked and replace point-condenser if required. I recently changed them along with Engine oil to Gulf Multigrade 20W50 in my 99 Carb 800. Big change in cold start performance and acceleration and Engine noise also reduced.
Prass is offline   Reply With Quote
Old 12th June 2009, 16:19   #18
Thanked: 49 Times
Originally Posted by Prass View Post
Will be checking the engine timing later today - but I don't think that's the issue here.
Correct me if I'm wrong - Timing related problems cause a gradual loss of power (over several kms) and don't not the drastic overnight drop that I'm seeing.
Old 12th June 2009, 18:46   #19
The smoke ( same as thrown by diesel buses / trucks ) along with oil deposit in spark plugs is enough indication for a engine overhaul. compare the price of engine overhaul with a new engine block from maruti , it costs about 10K for an idea . Its always better to get a new engine block than to rebore . but depends upon person to person
passion4cars is offline   Reply With Quote
Old 12th June 2009, 19:52   #20
Thanked: 49 Times
Default My Maruti does a Nano!
Got back home and got my tools out. The timing was fine - up next were the spark plugs.
Opened them up and found that the ceramic (center electrode) insulator on the #2 spark plug had broken off. So I replaced all three plugs and fired her up. All's good again.
OT - the #1 and #3 plugs were bone dry and clean - but the #2 electrode had lots of oil deposits on it. Looks like the rings in the #2 cylinder are leaking alright.
Maruti 800 STD & 800 DX..pros & cons ? shapath Technical Stuff 6 21st August 2015 11:32
Problem in partly overhauled 5 speed maruti 800 ramkris Technical Stuff 19 3rd August 2010 13:25
Maruti 800 Problem humyum Technical Stuff 13 24th November 2009 16:05
Maruti 800 5S - AC Problem sureshshanmugam Technical Stuff 1 5th April 2008 22:18
Maruti 800 5 Gear MPFI problem anoovis Technical Stuff 3 28th February 2007 10:07
