Old 8th July 2007, 18:19   #1
jramprakash's Avatar
Default Maruti 800 problem | Suggestions Please
I have a Maruthi 800 car, its been nearly 4000 odd Kms since i've got the servicing done.
Recently there is thick white smoke when i race the car. I had checked and found that in the Oil was present in the Spark Plug.
Can anyone suggest me an alternative to help. If its servicing please let me know on what all parameters to check and change. Please let me know the Brand of Oil i need to use for Engine oil.
jramprakash is offline   Reply With Quote
Old 9th July 2007, 10:11   #2
extreme_torque's Avatar
Thanked: 1,489 Times
Dude thick white smoke means your piston rings are gone. The engine oil is seeping into the combustion chamber. Time to overhaul the engine.
extreme_torque is offline   Reply With Quote
Old 9th July 2007, 11:15   #3
Jaggu's Avatar
Thanked: 8,686 Times
how much has the car run till date?
Old 10th July 2007, 01:16   #4
Default What will be cost of piston ring??
How much will it cost?? any idea??
Car has run around 92500kms
Old 10th July 2007, 09:13   #5
Sankar's Avatar
Thanked: 4,647 Times
That is a fair bit of mileage isnt, it?
Your car will need a rebore and maybe a head job. Take it to a good mechanic he'll sort it out.
Sankar is online now   Reply With Quote
Old 10th July 2007, 09:35   #6
Thanked: 103,523 Times
Hi Jramprakash,
We would appreciate if you take the time out to post your threads in the correct forum section. This topic obviously didnt belong in the accessory / parts section.
Old 10th July 2007, 12:24   #7
nitrous's Avatar
Thanked: 285 Times
U're in for an engine rebuild.
And its the cheapest for an m800.
http://www.team-bhp.com/forum/indian...tml#post230428 (Spare Part Price List of cars that are sold here)
Old 10th July 2007, 12:44   #8
2fast4u's Avatar
white smoke equates that its a coolant leak in ur combustion and signals a head gasket job.
When doing the head gasket job make sure that the HEAD has no cracks.
do let us know ur coolant consumption
2fast4u is offline   Reply With Quote
Old 10th July 2007, 12:46   #9
2fast4u's Avatar
eating oil in combustion = blue smoke
correct me if i am wrong
Old 10th July 2007, 12:49   #10
nitrous's Avatar
Thanked: 285 Times
2fast, he's got oil stains on his plugs!
Old 10th July 2007, 13:04   #11
2fast4u's Avatar
but hes saying white smoke also need to know if its one plug or all that has oil.
and an easy test would be to get the radiator cap out, warm the engine and smell for exhaust gas or a 20min pressure test with all plugs out and cranking will give the feedback required.
coolant consumption should give a clear view.
Old 11th July 2007, 20:32   #12
sumeethaldankar's Avatar
Thanked: 1,158 Times
Hi guys typically white smoke in the rainy season seems common in most cars.Usually white smoke means it's water vapor,black means engine needs tuning and is burning too much petrol and blue means its burning oil.
I have noticed white smoke from many cars in the rainy season.neverthless have the car checked out at a garage.
sumeethaldankar is offline   Reply With Quote
Old 12th July 2007, 12:36   #13
2fast4u's Avatar
gosh I hope @Jram is not referring to this kind of white smoke.
if its then good thinking on ur part.
the oily "plug" could be a rich issue
Old 13th July 2007, 00:34   #14
Smile Thanx for overwhelming suggestions!!!
Guys you have provided valuable information to me. Please keep on pouring the information.
Regards to one & all.
Sorry GTO for posting the thread in wrong place...!!!!
Old 13th July 2007, 12:24   #15
ravradha's Avatar
Thanked: 105 Times
"Oil was present in the Spark Plug" - a tell tale sign of piston ring problem. Your engine is due for an overhaul - 20 K I guess and you get warranty for 50K Kms or so...
ravradha is offline   Reply With Quote
Maruti 800 STD & 800 DX..pros & cons ? shapath Technical Stuff 6 21st August 2015 11:32
Problem in partly overhauled 5 speed maruti 800 ramkris Technical Stuff 19 3rd August 2010 13:25
Maruti 800 Problem humyum Technical Stuff 13 24th November 2009 16:05
Maruti 800 5S - AC Problem sureshshanmugam Technical Stuff 1 5th April 2008 22:18
Maruti 800 5 Gear MPFI problem anoovis Technical Stuff 3 28th February 2007 10:07
