Closed Thread
Old 8th July 2007, 22:58   #1
Default Which is the right Sequence Clutch-Brake Or Brake-Clutch
While slowing down, I normally apply brake and when the car slows down to a level where there is a need to change the gear, press the clutch. But my friend says, he presses clutch before applying brake.He reasons that disengaging the engine from the wheels by pressing the clutch increases the effectiveness of brake, reduces wear on transmission. Which is right? Pressing Clutch before brake or applying Brake before pressing clutch?
ankura12 is offline
Old 9th July 2007, 09:14   #2
Thad E Ginathom's Avatar
Thanked: 8,373 Times
You are correct and your friend is absolutely wrong.
Engine braking should be utilised and, of course will not be there with the clutch depressed.
braking shifts the weight of the car forward; engine braking does not do this so much. The clutch should not be depressed until it is necessary to prevent the engine stalling --- aided by changing down as you approach the point where you know you will stop.
Progressive braking is part of this and, as the car comes to a final stop, it will be requiring very little pressure to achieve this: smooth driving, no jerks and comfort for you and your passengers.
The aim is to have full control over the car at all times. Being in the right gear for the right circumstances is part of this. Never, ever coasting, is part of this too.
Sorry... send your friend back to driving school!
Thad E Ginathom is offline
Old 9th July 2007, 10:02   #3
Rehaan's Avatar
Thanked: 25,038 Times
You are right. Brake before clutch, no doubt about it.
Check out this thread, its discussed in detail >
Shifting to Neutral (or pressing the clutch) -
Thread Closed
cya
R
Rehaan is offline
Closed Thread
Right sequence to start the engine?? swift8847 Technical Stuff 119 17th September 2009 16:35
Modifications for Gypsy King - Does the sequence of modifications matter? khan_sultan Modifications & Accessories 18 6th September 2009 14:02
Only brake OR clutch+brake swiftcrazy Technical Stuff 8 10th July 2007 23:19
