Old 9th July 2007, 06:39   #1
Default Need advice - Thud Sound while taking IKon out from Parking
Hi
Car : Ford Ikon, taken delivery in Feb'07
About Owner : First car for him and does not know any Technical stuff about the car
Today morning ( I start work pretty early) when i took my car out for going to office, ( I had a reverse Gear on), I heard Thud Sound, like tyre breaking a stone and getting over it. Since my car is in covered parking was sure nothing obstructive could be there, hence immediatley got down and checked near all the four tyeres, could not find any thing.
Got into the Car again, checked if all the gears are engaging correctly, checked if brakes are working properly and then drove to office
My doubt now is,
1.Should i just forget about the noise which came, since i had a safe drive to office which is 14 kms from my home
2.What could be the reason for the noise coming out
3.Should i take the car to Authorised Service Centre?
Note: I got the car to the local water wash fellow y'day, got it cleaned (underbody also) and then parked it and took it
out only today.
FlairBoy is offline   Reply With Quote
Old 9th July 2007, 10:19   #2
sammyboy's Avatar
Thanked: 338 Times
Hey bro , thats prety strange . Have you had any problem/noise like this before ? I dont think this should be something to worry about ...unless you feel some problem while driving ..
sammyboy is online now   Reply With Quote
Old 9th July 2007, 10:53   #3
bill1182's Avatar
Looks like your Brake liners were jammed and got released as you reversed. Did u park the car with Hand brakes? I am not too sure if that is the issue. If the car is running fine... don't worry and enjoy the drive.
bill1182 is offline   Reply With Quote
Old 9th July 2007, 10:59   #4
yogi1771's Avatar
could be your brakes they are getting jammed when parked check them out
yogi1771 is offline   Reply With Quote
Old 9th July 2007, 11:01   #5
Jaggu's Avatar
Thanked: 7,449 Times
out only today.
Donot worry its the water wash, the pads sticking in the rear drum when you engaged hand brake, it will be there for a day or two till water dries off.
If you are not convinced leave the car without hand brake overnight and move, you will hear no sound. I had this problem for whole of 7 years when water went into the brakes.
Old 7th September 2009, 22:37   #6
Default Dont use parking brake during heavy rains
I was recently advised by a Hyundai mechanic not to use the parking brake when the car is parked (say over night) when there is a heavy rain.
He recommends putting the car in 1st gear rather than use the hand brake.
Could the team-bhp gurus advise if this is true?
iceman
Last edited by Jaggu : 7th September 2009 at 23:37. Reason: Merging the thread since this was discussed earlier. Thanks
iceman84 is offline   Reply With Quote
Old 7th September 2009, 23:38   #7
Jaggu's Avatar
Hi iceman84, the topic of this thread might be the reason why the hyundai service advised you, NOT to leave the Handbrake ON.
cheers
Jaggu
Old 8th September 2009, 10:00   #8
Thanks Jaggu for your response.
Old 8th September 2009, 11:15   #9
Shashank.A's Avatar
This is a common problem in Monsoons, lot of people face it. And since it was in reverse gear it simply moved with a thud, sometimes they refuse to move in first gear as well. Generallly mechanics come and hammer your drum to free it up. its perfectly normal.
Shashank.A is offline   Reply With Quote
Old 8th September 2009, 14:21   #10
blackasta's Avatar
Thanked: 955 Times
I bought my car the last week, and have hard this noise while reversing (grinding kind of noise right?) after the car being parked overnight, and I (now I know correctly!) guessed that the brakes took some time to come off. I park my car at night using the hand brake.
Maybe I shall try for a couple of days without the hand brake and check. Its been raining cats n dogs in Kolkata since last week!
blackasta is offline   Reply With Quote
Old 8th September 2009, 19:52   #11
honda3938's Avatar
if you engage handbrake while parking than it may be the reason.There may be reason that there is some loose component in boot . Happened to me once the reason was that the jack was not kept properly.
honda3938 is offline   Reply With Quote
A loud 'thud' sound whenever my Ford Ikon passes over potholes on the road. InternetUser Technical Stuff 24 25th June 2013 21:38
Renault Duster 110 : THUD sound & vibration on engine startup noelravin Technical Stuff 6 21st January 2013 13:26
A thud from the rear while braking!! avigster Technical Stuff 23 29th May 2011 14:37
Thud Sound from Clutching Action atheistrical 4x4 Technical 6 29th October 2010 18:29
Thud while releasing clutch - After replacement - WagonR paragsachania Technical Stuff 10 21st December 2009 11:48
