Old 20th August 2006, 14:30   #61
roms's Avatar
Thanked: 22 Times
Default The sniffing continues!
Yesterday,I did'nt need any sniffing actually.A swift just passed me and it had this smell too,and it was'nt even stationery! Just a thought,could it be anything to do with the air conditioning?
roms is offline   Reply With Quote
Old 21st August 2006, 16:41   #62
Thanked: 7 Times
Infractions: 0/1 (4)
Hi Pillai,
The smell you get may be due to the coolant getting over heated and would have reduced in volume.( i faced this problem once when my car was new).
Bye
Alex
alexrabbi is offline   Reply With Quote
Old 21st August 2006, 19:51   #63
Thanked: 151 Times
If that were the case wouldn't you expect the temp gauge to register an increase in temperature?
That has not been happening to me, but the burning smell is pretty prominent, especially when I run the car at a high rpm in any gear.
NPP
pillainp is online now   Reply With Quote
Old 22nd August 2006, 10:21   #64
Thanked: 230 Times
Still not had time to take it to dealer. Maybe today...
sandeep108 is offline   Reply With Quote
Old 22nd August 2006, 11:09   #65
Hello Friends,
If you are experiencing any unusual behaviour in SWIFT or kind of sluggishness,get take it to any authorised dealer workshop and get your vehicle checked there by using a diagnostic tool known as Tech-2.
Maximum of your problems will get resolved.I use to face some problems like humming noice in 5th gear and sluggishness and low pickup.I got it done last week and my lovely SWIFT is unmatcheable now...
So please do it...
Thanks and regards,
Rajendra
raja748 is offline   Reply With Quote
Old 22nd August 2006, 15:11   #66
Thanked: 7 Times
It is true but my temp guage did not show any sign too
Bye
Alex
Old 22nd August 2006, 15:31   #67
Thanked: 230 Times
Well I did take it to the dealer and took a test drive with their mechanic. Funnily enough (why is this ALWAYS the case?) with him sitting there, there was NO burning smell, even after revving the engine to high heaven. He complimented me on my driving skills (since I was taking it to 80-90km/h in 2nd gear) and NO damn burning smell.
He said that it may take some time for the clutch plate to set against the flywheel or something to that effect and since car was new, there may be some play / material friction at initial stages and whatever it was is now ok, since clutch/handbrake setting was quite ok.
The 5th gear engine humming noise, he insisted was due to timing belt resonance(!) due to engine load at exactly 50km/h in 5th gear and is a design issue, just like maruti water pump noise.
Old 22nd August 2006, 15:45   #68
Thanked: 7 Times
Hey sandeep,
it is not design issue with maruthi. that mechanic can't give u a better answer.
I too had couple of questions abt rattling sound in my swift doors , so the mechanic told me that all the swift cars have it and they have sent a letter to maruthi( i just kept quite knowing there is no point in talking 2 them).
Bye
Alex
Old 9th July 2007, 12:12   #69
bill1182's Avatar
Default Sluggish Swift, Edit: And other swift speed related queries
Yesterday I was travelling back from Lonavala. Tried pusing hard but the speedo was stuck at 140. RPM 3500. Drive was smooth and good but some how vehicle stopped responding to the gas peddal at 140.
Can this be because vehicle is new (Just 2600 km run). Is it possible that Maruti keeps the speed limit for new cars, to avoid engine damage?
Has anyone else experienced such thing?
bill1182 is offline   Reply With Quote
Old 9th July 2007, 12:57   #70
Shan2nu's Avatar
Thanked: 89 Times
It could have also been the fact that you were in 5th (which is an overdrive). Since the torque reaching the wheels is the least among all the gears, the car could have been bogged down by head wind, road gradient or any other factor.
Try accelerating in 3rd or 4th, i'm sure you'll see better results. BTW, is your car petrol or diesel?
Shan2nu
Old 9th July 2007, 13:01   #71
Thanked: 90 Times
Originally Posted by bill1182 View Post
Isnt that the speed set in the speed limiter?? by Maruti?
and it is the max speed a Swift should be used upto!! go over that speed only in a skoda or corrolla etc.
scooby05 is offline   Reply With Quote
Old 9th July 2007, 13:19   #72
theMAG's Avatar
Thanked: 1,574 Times
No speed limiter - only rev limiter that cuts in at 6500 rpm. Also the Swift is capable and under her limits for speeds greater than 140 kmph !
Old 9th July 2007, 14:26   #73
bill1182's Avatar
Shan2nu
Petrol Swift.
Maruti quotes max speed as 160 kmph. I am sure it can take more.
As I have already mentioend it was doing 140 at around 3.5k on RPM.
If the rev limiter allows 6.5k then surely the speed should increase.
What i faced was, rev stuck at 3.5k at full throttle
Old 9th July 2007, 22:30   #74
Shan2nu's Avatar
Thanked: 89 Times
Petrol Swift.
Thats what, try accelerating in 4th gear. You shud be able to cross 140kmph without probs.
Shan2nu
Old 9th July 2007, 22:59   #75
manikjeet's Avatar
Thanked: 110 Times
Shan2nu
he would be able to cross 140 in the 4th gear but isn't the rev limit in 5th gear of 3500rpm to low for the swifts engine
manikjeet is offline   Reply With Quote
First Long Trip - Bangalore to Vijayawada - Route Query and other related queries Newpunter Route / Travel Queries 6 13th December 2010 15:09
Wireless Bandwidth and related queries Venkatesh.C Gadgets, Computers & Software 5 18th October 2007 23:37
2 Tyres and Alloys related queries abhibh Tyre & Alloy wheel Section 9 22nd August 2007 19:20
Wanted : Quarter Mile Time Calculators and other Drag Related Software !!! mclaren1885 Technical Stuff 12 1st July 2006 18:38
