Old 10th July 2007, 15:57   #16
yuv
Thanked: 39 Times
Just got a call from Ichibaan... and it IS the O2!
Going to pick-up my baby, will share the details after i see the hi-scan report.
Now, where to buy the O2 for 2.5 - 4k as mentioned by senior members on this board. Pls help!!!!!!
Thanks alot.
Yuv.
yuv is offline   Reply With Quote
Old 10th July 2007, 16:40   #17
yuv
Thanked: 39 Times
Originally Posted by Dhar's View Post
@Yuv
I confirmed with my Dad. The cost was 16K.
Thanks Dhar.
And I agree with you, the number of complaints on the HC O2 sensor seem to be far larger in number then other cars.... wonder if this is perculiar to the OHC's.
Meantime, Im scouting hard to find a good/reasonable dealer for a jap O2 sensor for around 3-4k... so I need help from all you esteemed members.
Thanks in advance.
Yuvi
Old 10th July 2007, 17:39   #18
viper's Avatar
Thanked: 9 Times
You can go to Opera House City Motors. He will help you out.
Viper
viper is offline   Reply With Quote
Old 11th July 2007, 00:25   #19
yuv
Thanked: 39 Times
Originally Posted by viper View Post
Viper
Thanks alot Viper.
Impatience got the better of me and I went ahead and bought 1 today... and Im happy to say that my OHC is back to its glorious self!.... minus the yellow light...
It was touch and go... 1 moment the adamant yellow light was there and the next moment, it vanished. Takes less then a minute to change the O2.
Also got wobbling fixed... turns out the potholes in Mumbai pretty much messed-up the alignment and balancing. After the wheel balancing, she flys and how...
Thank you all for your timely help and support, truly appreciate it.
Cheers!
Yuvi
Old 11th July 2007, 10:07   #20
Dhar's's Avatar
Thanked: 163 Times
Originally Posted by yuv View Post
Thanks alot Viper.
Yuvi
And its only the size of a ..say a tv cable plug or a car charger and it costs 16K!!!! The service guys reportedly says that it contains Platinum. If thats true, wonder, if platinum from the used O2 sensors can be sold.
Else where in the forum, fellow t=bhpian reported a case of bad smell from NHC. Does this have any relation to the o2 sensor?
http://www.team-bhp.com/forum/techni...hc-2004-a.html (Bad smell after starting the car (NHC-2004))
@ yuvi,
can you please give me the honda part no. for the same?
Dhar's is offline   Reply With Quote
Old 12th July 2007, 23:01   #21
yuv
Thanked: 39 Times
@ yuvi,
I didnt pay 16k Dhar, there is no way im going to let Honda rip me... not even close, I got myself the sensor for 1800/- bucks flat.
lol@platinum, sounds like some over zealous salesmans imagination.. but then again, who would pay 16k? so sure. it has platinum, maybe even diamonds. hehe
Burning smell thread. O2 seems like a far cry, most likely some belt about to give way. my 2 cents
Part number, I will look it up and let you know.
Thanks and Cheers!
Yuvi
Old 13th July 2007, 12:10   #22
Dhar's's Avatar
Thanked: 163 Times
1800/-? My Dad is gonna faint hearing this.
Which make? where did u fix it? in Opera House City Motors?
Damn it. I should have run a thread in t-bhp that time.
Old 13th July 2007, 12:23   #23
Thanked: 1,172 Times
Hi Guys,
Does NHC also inherit this O2 sensor and it's failure rate?
And which make for that Rs1800 O2 sensor?
anandpadhye is offline   Reply With Quote
Old 13th July 2007, 13:03   #24
Dippy's Avatar
Thanked: 192 Times
Glad to know your problem is solved yuv. Like others, my question to you? Did you buy the sensor from City Motors?
Dippy is offline   Reply With Quote
Old 13th July 2007, 14:45   #25
vishnuvijay's Avatar
hi guys, 2 days back my uncle's cars yellow light went on. it's a 2003 OHC 1.3 exi. i guess it's the O2 sensor thats the culprit here too.
can anybody please tell me whats the purpose of an O2 sensor?
is there any problem/disadvantage if we don't rectify/replace it?
does anybody know where to buy an aftermarket O2 sensor in kerala?
vishnuvijay is offline   Reply With Quote
Old 13th July 2007, 15:25   #26
yuv
Thanked: 39 Times
I dont know the make.... n didnt care much of it.. as long as it worked.
I know i took a risk but it works so alls well that ends well.
No, not city motors... I got it from a friend, who says its an imported one.
I personally think its a taiwan make or something... it had a serial number on it though. Like i said, I didnt care much abt that... as long as yellow light gone and FE stable, im a happy camper!
Cheers...
Yuvi
Old 13th July 2007, 15:54   #27
narayan's Avatar
Thanked: 1,339 Times
had same problem. had posted a thread on this earlier...
i had gone for a similar after market option sourced from cochin at 3500
after fitting it also, i had the lights coming on ...then the mechanic checked the connections and tighted the same...
so even before buying the cheaper one, u cud ask them to chek all connections and also to clean the O2SENSOR head which if clogged could also trigger the light
narayan is offline   Reply With Quote
Old 13th July 2007, 19:48   #28
yuv
Thanked: 39 Times
The outer part is like a mesh and dirty.... so cleaning might work.
Loose connections is another story altogether and before changing the O2, I would suggest anyone to 1st check the connectors for any loose connections.
Sometimes, even after changing the O2... the light doesnt go.....
Possible Solution: Remove the battery terminals overnight, which will reset everything.
Loose fuel cap is another reason for the light.
cheers & all the best
Old 13th July 2007, 22:48   #29
yuv
Thanked: 39 Times
I think the O2 sensor is connected to the ECU, thereby regulating the flow of Air & Fuel for providing the optimum mix... which is why when the O2 blows, the 1st thing u should notice is a drop in FE or worse still, stalling or starting problems because of more fuel or more air.
Ordinarily there is no urgent need to replace it ie. If u dont mind the drop in FE... but the problem is that the yellow light could mean alot of things like engine issues or fuel tank issues, etc.
So use your discretion and if your car is running normally... most likely all is normal and u need not replace the O2 immed.
Srry, no idea about Kerala aftermarket.
Disclaimer: Im no expert and my comments r based upon study and research I did during my recent O2 days :P
Best Of Luck.
Yuvi
Old 13th July 2007, 23:26   #30
yuv
Thanked: 39 Times
@ yuvi,
234000-2180
07B10
OG make is Denso.
Malfunction-Indicator light stays on after push-starting car. How serious is this ? supremeBaleno Technical Stuff 18 17th August 2017 16:49
Honda dealer in Chandigarh sold old accidental Honda City to a customer PaddleShifter Indian Car Dealerships 13 12th September 2010 22:57
Baleno altura high rpm at idling and malfunction indicator sukrit7 Technical Stuff 2 6th November 2008 12:14
malfunction indicator on Gypsy King MPFI khan_sultan Technical Stuff 8 26th August 2007 23:27
