| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| Senior - BHPian | Hi folks, There are a lot of theories out there on what is the best way to run in a new/rebuilt engine. The most well known one is "for the first 3-5k kms shift well below the redline and don't take it past 80". Also, running the car at varying speeds and rpm's is another accepted method, but even in this case, the idea is never to go near the redline. So what is your theory, and how have you run-in your engine? I used a combination of the above 2 - no redlning, stay within 80 and as for the varying speeds - Calcutta traffic takes care of that for you! But is this the best way? I did some hunting around and found this site, which has a compeltely radical view-point. Makes for an intersting read, and makes a lot of sense. Break In Secrets--How To Break In New Motorcycle and Car Engines For More Power Do write in with your views on this. Last edited by razor4077 : 9th July 2007 at 17:35. |
| | #2 (permalink) |
| Team-BHP Moderator ![]() | Good question. And lots of interesting answers and viewpoints in THIS thread! Please do a search before opening new threads.
__________________ He who makes the loudest noise usually has the least to say. Unfortunately they don't realise that and keep at it! ____ |
| Thread Tools | |
Similar Threads | ||||
| Engine Swap for a 9 yr old 1,60,000 Run Fiat Sienna 1.7TD | maxbhp | Modifications & Accessories | 25 | 12th May 2008 19:19 |
| Turbo? NOS? Engine Swap? High CR NA build? How would you modify your engine? | mclaren1885 | Modifications & Accessories | 50 | 26th March 2008 10:55 |
| Does the fuel pump run even when engine is off, but key in ON position ? | supremeBaleno | Technical Stuff | 29 | 22nd January 2008 19:17 |
| DDiS - A run-in on the engine | navdeep | The Indian Car Scene!! | 19 | 26th January 2007 14:13 |
| Changing Engine Oil..After run-in period | netarchie | Technical Stuff | 6 | 31st May 2006 00:02 |
