Old 17th April 2009, 23:08   #31
kb100's Avatar
Originally Posted by dockap View Post
I have a magnum with abs the only time the abs light comes on is when i turn on the ignition i have never ever seen it light up when i brake does that mean that its not working?
also when i apply the brakes at high speed the steering vibrates/shudders is that normal
First point .. please be worried only if the light stays on - that means the ABS unit is not working (sensor trouble and such)
The shuddering steering means a warped brake disc. IN most cases you can get away with skimming it on a lathe - but in some cases you might have to change the disc/rotor itself.
kb100 is offline   Reply With Quote
Old 18th April 2009, 00:31   #32
dockap's Avatar
Thanked: 376 Times
thanks for the info. whats a warped brake disk my car has all 4 wheel disk brakes and the disks look ok but have lines running in a circular fasion over them more obvious on the front disks
dockap is offline   Reply With Quote
Old 18th April 2009, 09:48   #33
kb100's Avatar
Shuddering steering means you have a problem with one - or both of your FRONT discs only.
Take it to the service centre - they will diagnose it for you... replacing the discs is a half hour job.. getting it done on lathe may take a day... or two - depends on the traffic at the service centre and the lathe centre. The Lathe will cost you only 500 bucks or so. While the discs can cost between 1.5-2k .. or more.( dont know the Bowtie pricing)
They 'might' change the brake pads as well.
Old 18th April 2009, 12:48   #34
aseemjohari
Posts: n/a
After reading the compleate post...m confused..!
i own Swift VDi(ABS) 2007 model..!
1) is my car equiped with ALL FOUR WHEELS with ABS.....??
2) is my car have EBD IN ALL FOR WHEELS...???
Old 18th April 2009, 13:06   #35
siddartha's Avatar
Thanked: 22 Times
Originally Posted by ashish22 View Post
well thats true vRS only comes equipped with ABS for braking. However i'm always confused on the ASR part. Some say it has it and some say it has been eliminted from the indian spec vRS.
there is no traction control /ASR on the RS in india. positive!
@aseemjohari- all the wheels will have abs and ebd , even the spare wheel! lol.
siddartha is offline   (1) Thanks Reply With Quote
Old 18th April 2009, 13:08   #36
vikram_d's Avatar
Thanked: 936 Times
Yes the Swift has ABS & EBD on all four wheels.
Old 20th April 2009, 18:34   #37
aseemjohari
Posts: n/a
thanks for the reply...
but some where in other websites i had read..swift have abs only in front two wheels.
Old 20th April 2009, 19:42   #38
equinox22's Avatar
ABS only on front wheels would be dangerous. In an emergency the rear wheels would lock and it would be equivalent to pulling the E-Brake. I have heard of only rear-wheel ABS on some SUVs and light trucks, but not of only front wheel ABS.
equinox22 is offline   Reply With Quote
Old 21st April 2009, 16:42   #39
ajithbc's Avatar
Thanked: 9 Times
Default ABS upgrade for Skoda
How far is it feasible to upgrade my 1.9 Tdi with ABS? Anyone has done it or any pointers on cost and feasibility pls!
ajithbc is offline   Reply With Quote
Old 21st April 2009, 16:56   #40
vikram_d's Avatar
Thanked: 936 Times
Not true. I have put up the schematic diagram of the Swift's ABS system on the following link.
http://www.team-bhp.com/forum/techni...ml#post1270324 (ABS types and generations)
Old 22nd April 2009, 09:15   #41
agbenny's Avatar
Thanked: 95 Times
I do not think it is it feasible in India with after market fitments. If there is something to be done, only the manufacturer can do it - it might not be cost effective or possible.
agbenny is offline   Reply With Quote
Old 22nd April 2009, 10:07   #42
Thanked: 55 Times
in simple terms, traction control cuts power off to drive wheels ( either front or rear) in case if they loose grip of the road and spin on snow or wet conditions. Because if the car is skiding, acceleartion only makes it worse. So when the TCS is activated, car wont accelerate even if you push the gas pedal (accelerator) to the floor. Once the sensors make sure that wheels are not spinning, then crank shaft will be engaged to axle again.
raveen_2023 is offline   Reply With Quote
Old 22nd April 2009, 11:04   #43
ImmortalZ's Avatar
Thanked: 139 Times
There is no crankshaft/axle business except for in new generation AWD systems. In simple RWD/FWD TCS systems, there are two methods:
a) Control spark. Cut off engine power when the car is losing grip.
b) Selective braking of wheels. Bring the car into line by applying the brake on selected wheels.
You can install systems with only the first type of control from the aftermarket. Cost will be around 50K + customs + labor for a fully kitted out unit from Racelogic. Utilizes the ABS wheel speed sensors.
Retrofitting ABS to a car is... difficult.
Old 25th July 2012, 14:13   #44
suman's Avatar
Thanked: 257 Times
Default Re: ABS with EBD?
Bumping up an old thread since I have a related question......
Would anyone be able to highlight possible downsides of EBD not being present? Let's say, a car with ABS, EBD & BA versus a car with only ABS & BA?
My question arises out of the fact that I recently found out that the Rapid does not come with EBD (Vento doesn't either) - had always been under the impression that both went hand in hand!
Old 25th July 2012, 14:31   #45
AlphaKilo's Avatar
Thanked: 362 Times
There is no physical way to check but one way possible is to turn the ignition on and when the system does a self check, ABS light will come on. Ensures, you car has ABS. Well, EBD ensures that the wheel with most traction gets the most braking, thereby effectively assisting you in stopping earlier or controlled stopping. Otherwise, I dont think we brake everyother day on two wheels(stunts) only to make a really huge difference.
Bumping on this thread mainly for siddartha's comment!!
OT: and
Sirji, I hope this comment doesn't end up in the "Quriky logic and comments by Petrol and Non-Petrol heads thread".
AlphaKilo is offline   Reply With Quote
Engine tune up of scorpio crde using EBD ssbhide Technical Stuff 0 17th July 2009 18:24
swiftDz ZDi Vs verna SX Abs Vs fiesta sxi tdci abs Vs logan dlsx Vs indigo XL G-dicor dayaraamm Sedans 1 27th August 2008 14:22
Ford Fusion+ TDCi with ABS,EBD undead The Indian Car Scene 40 22nd March 2008 01:33
Fusion + ABS or Baleno VXI or Accent Viva ABS? What to buy? Confused like anything.. sendu79 Sedans 47 3rd June 2006 20:21
Ebd VMG Technical Stuff 3 8th June 2005 10:21
