Old 18th September 2013, 19:03   #61
govigov's Avatar
Thanked: 452 Times
Default Re: ABS with EBD?
I believe EBD is helpful in scenarios where one set of wheels are on the gravel and other on the tarmac. (Like in a shoulder, where the right hand wheels may be gravel and the left hand wheels on tarmac). In this scenario, with EBD, the wheels on the gravel might slip faster and needs more pulsations, while the wheels on the tarmac may require pulsation of a different frequency. This is attained by changing the brake pressure being applied to the four wheels independently.
Additionally, I have also read that EBD may be two channel, i.e only for the front wheels and that rear wheels might just have ABS without EBD. EBD working on the four wheels are also known as 4 channel EBDs
govigov is online now   Reply With Quote
Old 18th September 2013, 19:32   #62
ecosport's Avatar
Thanked: 163 Times
Source: Wikipedia
EBD is always hand-in-hand with ABS. I don't think it is always giving sole in a car. The EBD just modulates the brake pressure to each wheel by sensors that sense the wheel speed and grip it is having at that point of time.
Anurag.
Originally Posted by akshay4587 View Post
I dont think so,I have a Scorpio,and it has ABS only,there is no mention of EBD anywhere in the Manual or anywhere else.
However in my Linea its specifically mentioned ABS+EBD.
Infact EBD has a separate error code and a light associated in the console.
It just means that EBD does not come alone, but comes along with ABS. ABS, on the other hand, may come independently.
ecosport is offline   (1) Thanks Reply With Quote
Old 18th September 2013, 19:35   #63
akshay4587's Avatar
Thanked: 1,629 Times
Yes that is correct.
It cannot be EBD alone,it has to be ABS+EBD
However it can be just ABS in your vehicle without EBD.
Old 19th September 2013, 01:58   #64
Thanked: 13,387 Times
Is there any use for a car without EBD but only equipped with ABS? I thought ABS+EBD is better than a sole ABS feature.
I am new to this so asking it again!
Anurag.
a4anurag is offline   (1) Thanks Reply With Quote
Old 19th September 2013, 06:31   #65
Wildy's Avatar
Thanked: 621 Times
"The job of the EBD as a subsystem of the ABS system is to control the effective adhesion utilization by the rear wheels. The pressure of the rear wheels is approximated to the ideal brake force distribution in a partial braking operation. To do so, the conventional brake design is modified in the direction of rear axle overbraking, and the components of the ABS are used. EBD reduces the strain on the hydraulic brake force proportioning valve in the vehicle. EBD optimizes the brake design with regard to: adhesion utilization; driving stability; wear; temperature stress; and pedal force." EBD may work in conjunction with ABS and Electronic Stability Control ("ESC") to minimize yaw accelerations during turns. ESC compares the steering wheel angle to vehicle turning rate using a yaw rate sensor. "Yaw" is the vehicle's rotation around its vertical center of gravity (turning left or right). If the yaw sensor detects more/less yaw than the steering wheel angle should create, the car is understeering or oversteering and ESC activates one of the front or rear brakes to rotate the car back onto its intended course. For example, if a car is making a left turn and begins to understeer (the car plows forward to the outside of the turn) ESC activates the left rear brake, which will help turn the car left. The sensors are so sensitive, and the actuation is so quick that the system may correct direction before the driver reacts. ABS helps prevent wheel lock-up and EBD helps apply appropriate brake force to make ESC work effectively and easily.
Source: Wikipedia. http://en.wikipedia.org/wiki/Electro...e_distribution
For the reasons unknown, few companies are cutting out EBD in their cars. But, Personally, I would prefer to have ABS+EBD in my car as it definitely enhances the safety.
Wildy is online now   (1) Thanks Reply With Quote
Old 19th September 2013, 06:50   #66
I feel it is cost cutting measures by companies to save that extra buck. Extra sensors, equipment, calibration etc so why create extra headache, let's skip EBD and only give ABS. People will be happy and no questions would raise. Awareness is lacking else every manufacturer wouldn't dare omit safety features in a car/bus/truck.
No manufacturer in India cares about occupant safety rather 'Kitna Deti Hai' question is only answered.
Anurag.
Old 19th September 2013, 08:05   #67
Wildy's Avatar
Thanked: 621 Times
Anurag.
It sure is a cost cutting method. Just Found out Ford Ecosport and VW Polo are offering ABS+EBD and host of other safety features in their exported editions, But not in India.
http://www.vw.co.za/en/models/polo/t..._overview.html
http://www.ford.co.uk/Cars/EcoSport/Safety
Wildy is online now   Reply With Quote
Old 19th September 2013, 08:08   #68
I won't blame the manufactures alone here for this issue. The Government of India is also not forcing manufacturers for providing safety features in the cars sold.
SIAM, ARAI etc.. what are these guys doing sitting? They very well know the importance of these safety features but still neglect and skip it off while selling in India. No company had the guys to fill around with respect to safety when exporting vehicles and selling to the foreign market.
Not fair but both the public and government must wake up.
Anurag.
Old 19th September 2013, 08:18   #69
Wildy's Avatar
Thanked: 621 Times
That's another issue and let's all may force the Gov't to make a mandatory rule on safety features viz. airbags, ABS+EBD etc on every car. Although that may cost a little more, the competition would make the companies to lower the prices after a while.
But as of now, they are charging the premium amounts for the top variants and still compromising on safety features. I think that's really a bad attitude.
Old 19th September 2013, 13:13   #70
akshay4587's Avatar
Anurag.
Why not;a lot of cars in our Market Come with Just ABS.
ABS+EBD is better,but just ABS is way better than no ABS.
Old 15th September 2015, 12:43   #71
Hi, I am new here, planning to buy my first hatch and have fallen in love with VW Polo after I drove it for a good 800+ KMS. If I am not wrong, Polo now comes with ABS+EBD, isn't it? Drove a friend's Highline 1.2 (P) and it says it has ABS+EBD. In fact, this is one of the reasons I have my eyes on Polo.
help.
deveshshukla53 is offline   Reply With Quote
Engine tune up of scorpio crde using EBD ssbhide Technical Stuff 0 17th July 2009 18:24
swiftDz ZDi Vs verna SX Abs Vs fiesta sxi tdci abs Vs logan dlsx Vs indigo XL G-dicor dayaraamm Sedans 1 27th August 2008 14:22
Ford Fusion+ TDCi with ABS,EBD undead The Indian Car Scene 40 22nd March 2008 01:33
Fusion + ABS or Baleno VXI or Accent Viva ABS? What to buy? Confused like anything.. sendu79 Sedans 47 3rd June 2006 20:21
Ebd VMG Technical Stuff 3 8th June 2005 10:21
