Closed Thread
Old 10th July 2007, 19:23   #1
swiftcrazy's Avatar
Question Only brake OR clutch+brake
Hey All,
Dont know whether this is the right place for this post, but here goes...
I am a noob at driving and was wondering when does one just break and when does one use clutch + brake
I tried asking my driving instructor but he was of no use as he hardly spoke the language
I am a bit coz this will be my first ride and i dont want to spoil it with bad habits..
Just read through a post on shifting gears...the suggestions were fantastic
Please respond
Last edited by Rehaan : 10th July 2007 at 23:20. Reason: 2 smileys max. PLEASE READ THE RULES.
swiftcrazy is offline
Old 10th July 2007, 20:44   #2
arunphilip's Avatar
Thanked: 4,825 Times
Ideally, you should use the brake only, and press the clutch prior to your engine stalling.
Since you're a beginner to driving, you might want to press the clutch when you reach speeds of 10 - 20 kmph, as you may not be familiar with exactly when your engine would stall.
See this thread, which discusses similar questions:
http://www.team-bhp.com/forum/techni...ral-right.html
arunphilip is offline
Old 10th July 2007, 21:05   #3
bottle's Avatar
Thanked: 138 Times
press the brake alone and when its really slowed down depress the clutch so that the engine doesnt stall
i have this bad habbit of pressing clutch while braking which i cant seem to break
bottle is offline
Old 10th July 2007, 21:09   #4
Please .. no clutch. Use only when the vehicle almost stops.
chanapli is offline
Old 10th July 2007, 21:11   #5
merve_extreme's Avatar
Thanked: 12 Times
yes press the brake only,when you have sufficiently slowed down you depress the clutch to shift to lower gear or prevent a stall in case of a full stop brake.
if u use the clutch during braking you lose the benefit of engine braking and stopping distance increases.very important in case of climbing down ghats or slopes.
merve_extreme is offline
Old 10th July 2007, 21:13   #6
manikjeet's Avatar
Thanked: 110 Times
only use the break and when you are really slow and you fell the car will stall only then use the clutch
manikjeet is offline
Old 10th July 2007, 21:15   #7
speedmiester's Avatar
Thanked: 932 Times
Yup only brakes unless you think that the engine might stall. As merve said you would be losing out of engine braking. Very crucial in case of emergencies and while coming down steep slopes. It reduces the load on brakes and will prevent them from getting overheated.
speedmiester is offline
Old 10th July 2007, 21:17   #8
Vid6639's Avatar
Thanked: 21,083 Times
We have a similar thread which you could read up. very useful info there.
ps: there's a 2 smiley limit on posts.
Vid6639 is offline
Old 10th July 2007, 23:19   #9
Rehaan's Avatar
Thanked: 25,043 Times
Please use the search feature before posting a new thread.
PLEASE read the rules that can be found in the announcements section, or at the top of every forum listing.
Follow the link here
Thread Closed
cya
R
Rehaan is offline
Closed Thread
Future Perfect! China-only/Sedan-only car Brands SankalpDesai The International Automotive Scene 1 8th August 2012 16:52
Engine Stalls and shuts down during de clutch ONLY with GAS TANK FULL in Accent darthvader5000 Technical Stuff 20 7th May 2009 19:59
Bird watching....but only the feathered kind only Perez Travelogues 9 1st April 2009 12:28
Which is the right Sequence Clutch-Brake Or Brake-Clutch ankura12 Technical Stuff 2 9th July 2007 10:02
wet clutch vs dry clutch and slippers clutches devsus Motorbikes 7 16th May 2006 10:08
