Old 19th June 2009, 09:51   #136
KSM-Vtec's Avatar
Thanked: 439 Times
Thats an important point, can make a lot of difference. Also was there enough life left in the BP's??
FE going down and AC issues should be related i guess. Get the AC setup checked.
Are you sure if 14kmpl is what you were getting with AC in city???
Originally Posted by ankitahuja View Post
Did u get tyre alignment and balancing done after all this?
KSM-Vtec is offline   Reply With Quote
Old 19th June 2009, 16:53   #137
ankitahuja's Avatar
Thanked: 46 Times
Don't be shocked. I get similar FE in city too
Old 19th June 2009, 17:01   #138
KSM-Vtec's Avatar
Thanked: 439 Times
How do you mange that?? plz explain
Old 19th June 2009, 17:23   #139
ankitahuja's Avatar
Thanked: 46 Times
Originally Posted by abk View Post
Got my car serviced from ACE Honda NOIDA and then took it to a local garage in Sector 15, NOIDA and did:
  • Engine and gearbox mounting replacement - 3 mountings were replaced at total part cost of approx 2k
  • Front right headlamp assembly completely replaced as the original headlamp had faded and turned a little yellowish (afterall, 10 years old now). Depo purchased from Sector 15 NOIDA at 1.6k
  • Front wheel brake discs machined and polished by lathe and brake pads rubbed with sandpaper
Since the above 3 repairs/replacements I am experiencing the following problems with my car:
  • There is only a very marginal improvment in the engine vibration or noise due as felt in the driving position
  • When the AC is switched on (even with the fan position at 1 - the lowest) there is a significant increase in the overall vibration. The steering vibrates a lot. This problem wasn't bad earlier but is now very very significant
  • Upon applying the brakes even lightly at speeds above 90kmph the brake pedal vibrates and feels shaky on the foot. Am nevous of applying the brakes even moderately at speeds of 100-110kmph range
Folks, any clues what have gone wayward during the engine mounting and gearbox mounting replacement and machining of brakes?
Edited: Adding one more problem - filled the engine with synthetic oil and got the air & fuel filters replaced at ACE Honda. Since then the FE has gone down drastically (from 14 to 10ish)!
Abu, meet up sometime so that we can actually see where the problem lies. I feel your suspension / steering column is acting up. Need to check those.
You need tyre alignment/balance and a rim/alloy check too.
I don't know how good an idea is it to switch to synthetic on a high mileage engine that is used to the semi or full mineral oil. Maybe someone can enlighten us with the after effects!
Hehe, driving style I guess. Always upshift b/w 2000/2200 RPM but it doesn't mean I don't redline her often
Old 19th June 2009, 18:10   #140
abk
abk's Avatar
Dear all, thanks a lot for your advises! Unfortunately, I am a little short of time to try them before embarking on the next trip (am about to leave for Fagu now). Hope the car will hold itself up pretty well.
Ankit, sure lets meet up once am back in Delhi/Gurgaon. I will call you.
abk is offline   Reply With Quote
Old 19th June 2009, 18:31   #141
abhik's Avatar
@ankit-Switching to fully synthetic oils which usually contain a high measure of detergents might lead to the sludge deposited around the tappet seals, piston rings, gaskets to be cleant which is not a good thing for engines with high mileage as they will develop leaks and will start a whole host of problems then.
The sludge deposits occur due to mineral or semi-syns which leave behind residue because the literally get "baked" due to the heat.
@abk-since you got the brake discs machined, and did'nt switch to new pads, i belive it will take a good amount of hard braking for the pads to be adjusted to the new flat machined surface. So go around at night on an empty road and do some hard braking runs without locking the wheels. The pads were accustomed to the uneven surface and would have led them to wear unevenly and lose shape(which may not be clearly obvious to the eye) and they now need to get adjusted to the flat surface of the machined discs. Even little undulations on the pads will cause juddering under braking. And as Ankit mentioned do get the suspensions checked too.
abhik is offline   Reply With Quote
Old 23rd June 2009, 00:28   #142
pranavt's Avatar
Thanked: 273 Times
LOL, destroyed my idler pulley a couple of days ago. While redlining at Marine Drive I suddenly heard a grinding noise, plus the kind of noise you hear when going over loose gravel. Didn't notice anything wrong with the car, so kept driving. The AC belt was missing. Viper called me a bit later to tell me that the AC belt was missing and would fit one soon. Then found out today that the idler pulley was destroyed.
Guess a new one is in order. Is this something that would actually happen randomly? Or was something wrong with mine before it decided to explode?
Old 23rd June 2009, 15:36   #143
Fortuner71's Avatar
Thanked: 265 Times
Default Suggestion / Help : 2003 OHC 1.5 Exi clutch
hi all,
Some problem areas from my OHC , its run 53000 kms.
1) Gear shift is hard
2) Jerking on clutch release at low speeds ( 1st , 2nd Gear ).
I assume this to be due to the clutch => Need expert advice here , am I right ?
Questions :
1) Cost of clutch replacement ?
Thanks for the help.
Fortuner71 is offline   Reply With Quote
Old 23rd June 2009, 18:33   #144
pranavt's Avatar
Thanked: 273 Times
Ahaha, just found out. Didn't just destroy the idler pulley, it wasn't even on the car when they checked it.
Old 6th July 2009, 12:32   #145
johnda's Avatar
Thanked: 11 Times
Default Problem Area
Problem area,
I found that there was water clogged in the 'running body' (body hollow below the doors) on the right side, under the driver seat.
And the wetness on the carpet was also seen behind the driver seat.
A palio user said that i could be a blocked A/C outlet..
I wonder if its draining water, that seeps in tru the duct used for power cables for doors and mirrors????
But when I found the problem, I kinda saw there was also a breakage in the welding on the underside and when I tried to separate it the water just flowed out
I was blown away, I'm going to HONDA tomorrow. I hope i can fix the issue with out selling my gold :-)
If there are other OHC users who've had this problem- please advice!
johnda is offline   Reply With Quote
Old 6th July 2009, 15:35   #146
sushrutha's Avatar
Thanked: 324 Times
OT - Can any tell me boot space size (in Ltrs) along with Leg room space ( in cms) of OHC ?.
Old 6th July 2009, 16:21   #147
Thanked: 91,686 Times
Had the same, albeit on a smaller scale. Culprit was a badly installed rear windscreen. No more after-market for me, only Windscreen experts or authorised service.
Old 8th July 2009, 15:38   #148
Fortuner71's Avatar
Thanked: 265 Times
Default OHC clutch
hi all,
Questions :
Old 8th July 2009, 16:47   #149
Sunilb's Avatar
My OHC also has the same problem which I too thought to be the clutch issue but its working fine.
Then I read in one of the threads quoting it to be faulty ECU for all OHCs upto 2003. Need someone to revalidate this.
Sunilb is offline   Reply With Quote
Old 8th July 2009, 19:30   #150
Tejas@perioimpl's Avatar
Thanked: 5,058 Times
I have a 2001 ohc. No such issue happened. How can this be related to the ecu? I don't think there is any correlation.
Tejas@perioimpl is offline   Reply With Quote
4th Gen Honda City i-VTEC Manual - 1st year ownership report tejas08 Test-Drives & Initial Ownership Reports 42 12th November 2017 20:32
1st-gen Honda City: Adjustable Coilovers, Raceconcepts intake + exhaust and more bhuvan_prasad Modifications & Accessories 15 15th January 2015 20:02
DIY: 1st-Gen Honda City Door Panel Removal bowser DIY - Do it yourself 5 30th October 2014 00:18
Things I need to specifically look for in a 1st-gen Honda City Vtec Rice_tuner Sedans 8 16th June 2008 19:52
honda city (new) (old) and mitsubishi lancer fuel efficiency devarshi84 The Indian Car Scene 3 19th July 2005 12:39
