Old 28th February 2013, 11:00   #1486
cityvic's Avatar
Thanked: 2,583 Times
Originally Posted by raycers_honda View Post
I keep reading post but have never really seen all the pics of the ohcs on this thread.
This is thread for promblems,queries main I guess.
To post pictures of modded honda city's this is the thread
http://www.team-bhp.com/forum/modifications-accessories/1962-pics-modified-honda-citys-vtecs-65.html
cityvic is offline   Reply With Quote
Old 28th February 2013, 21:48   #1487
cityvic's Avatar
Default Re: 1st Gen Honda City Owners - Problems Areas, Fuel Efficiency and more
Guys need help here please.
My deffoger switch is getting illuminated but the OVRM adjusting switch and the driver side power window switches are not getting illuminated when switching on the headlights.
Are both the OVRM adjusting switch and the driver side power windows supposed to be illuminated or mine are perfectly fine?
1st Gen Honda City Owners - Problems Areas, Fuel Efficiency and more-img2013022801378.jpg
1st Gen Honda City Owners - Problems Areas, Fuel Efficiency and more-img2013022801380.jpg
Old 28th February 2013, 21:56   #1488
Desmosedici's Avatar
Thanked: 409 Times
Only the defogger switch has an amber light which lights up when pressed. The others do not have any illumination.
Desmosedici is offline   Reply With Quote
Old 1st March 2013, 11:16   #1489
cityvic's Avatar
Thanks for your reply.The amber light does glow when the defogger is switched on.
So my car has its lights running normally only,the OVRM adjuster and power window switches are not supposed to be illuminated when the headlights are switched on.
Old 1st March 2013, 17:24   #1490
Thanked: 56 Times
Guys, where can i get my engine compression test and tuning check done in Mumbai??
I believe you need a special machine for it? Does anyone specialise in tuning OHC's here in mumbai??
Vandit is offline   Reply With Quote
Old 1st March 2013, 18:53   #1491
Thanked: 56 Times
Sorry to bump this again.. but I got the IAC serviced and the problem suddenly has escalated.. the rpm now is unstable and keeps fluctuating!
I was recommended to get the car checked using the OBD scan. But i don't have a scanner nor know of anyone here who does diagnostics for the OHC.
Any of the mumbai guys can help out?? I'm afraid if the last resort means i take it to Arya Honda... they're gonna rip me off
Old 1st March 2013, 19:17   #1492
infotech58's Avatar
Thanked: 217 Times
What do you want to know using ODB scan? Is your CEL is ON? Or you just want to know the operating parameters?
OHC does have a port for ODB but needs an adapter. There is a guy in the opposite lane to Prakash Motors (Santacruz) who specializes in ODB scanning/ODO repair, etc. He shall charge you around 500 bucks and tell you what you want to know. Contact# RK - 26602380 - 9892618798.
If your CEL is ON, following may help too:
http://www.team-bhp.com/forum/techni...ml#post2808367 (1st Gen Honda City Owners - Problems Areas, Fuel Efficiency and more)
http://www.team-bhp.com/forum/techni...ml#post2809881 (1st Gen Honda City Owners - Problems Areas, Fuel Efficiency and more)
infotech58 is offline   Reply With Quote
Old 1st March 2013, 19:40   #1493
Thanked: 56 Times
Thanks for the info Sumeet. The CEL is not on, but my mechanic said the best way to figure out the idling adjustment & simultaneously rule out any sensor issue was to use the OBD scan.
I will try to visit him on Sunday.
Old 1st March 2013, 20:20   #1494
Thanked: 409 Times
When i had got my Vtec in 2010, it used die down and as an interim solution i had to keep the idle a bit higher. It used to suffer from erratic idling, suddenly going up and down which used to result in heavy jerking behaviour. Got the car serviced, which included throttle body cleaning, air filter etc. Dont remember if injectors were cleaned but that solved it all.
I had got the car serviced from a known guy at andheri east.
Old 1st March 2013, 20:31   #1495
Thanked: 56 Times
Did you adjust the idle screw yourself manually?? My injectors were cleaned in October as was the TB. This problem is completely new. Although my mechanic did try to adjust the idle.. This problem remains. The IAC was checked too
Old 2nd March 2013, 15:05   #1496
Thanked: 84 Times
I also have this RPM fluctuation issue but very minor rpm flickers within +- 50 range. So my mechanic suggested not to change the IACV valve (also known as rpm actuator) right now, if the problem escalates then we can go for it. Low RPM jerks might be related to the same, although many old honda city owners have this jerk problems.
Honda Monk is offline   Reply With Quote
Old 4th March 2013, 17:34   #1497
Thanked: 409 Times
No i went to the Mech to get the idle set at a higher RPM at the very beginning. This was before the servicing.
Pre 2002 Vtecs do have the 'jerking at low speed' issue. Its related to some issue in the older version of the ECU. i have noticed it only below 1.5k RPMs, above that its all good as normal.
Old 4th March 2013, 18:01   #1498
Thanked: 56 Times
As luck would have it, my mechanic decided to try one last look into the TB and the system before taking it to get the OBD scan done & he found one of the pipes cracked slightly resulting in air leaking ( I don't know what exactly he was referring to but all I could understand was this).
Once he got it fixed the rpm behaviour was no longer erratic & he could adjust the idle much better. It's almost back to behaving as before except I still feel it needs a but more fine tuning on the idling behaviour.. The rpm takes a tad longer than originally to drop on gear shifting or when shifting from higher gears into neutral ( or it could just be me nitpicking)
Can anyone explain what exactly happened & how he fixed it?
Old 4th March 2013, 18:49   #1499
cityvic's Avatar
Guys,last week suddenly the AC stopped giving out air in the 1st and 2nd modes,the 3rd and 4th is working perfectly fine.
What could be the problem and aprox damages to the pocket?
Old 4th March 2013, 19:34   #1500
Thanked: 409 Times
If the 3rd and 4th speed modes are working fine then it might just be a case of the blower switch gone kaput! If the AC itself is not working, then its a big headache.
4th Gen Honda City i-VTEC Manual - 1st year ownership report tejas08 Test-Drives & Initial Ownership Reports 42 12th November 2017 20:32
1st-gen Honda City: Adjustable Coilovers, Raceconcepts intake + exhaust and more bhuvan_prasad Modifications & Accessories 15 15th January 2015 20:02
DIY: 1st-Gen Honda City Door Panel Removal bowser DIY - Do it yourself 5 30th October 2014 00:18
Things I need to specifically look for in a 1st-gen Honda City Vtec Rice_tuner Sedans 8 16th June 2008 19:52
honda city (new) (old) and mitsubishi lancer fuel efficiency devarshi84 The Indian Car Scene 3 19th July 2005 12:39
