Old 18th May 2013, 18:00   #1606
Sprucegoose's Avatar
Thanked: 40 Times
Originally Posted by bowser View Post
I have the original Bridgestone tyres that came with the car. They're about 10 yrs old and have done about 28,000 km. Yes, you read that right! The car is practically brand new. I got it second hand about 2 months ago.
I can only upgrade the tyres right now. Will that fix this problem?
Get new tyres even if they are the stock size they will have a marked improvement over your current tyres.
The rubber compound of the tyres generally go hard and hence provide low levels of grip after about 5 years.
Even if they haven't been used much.
Getting larger section tyres (205) will adversely effect mileage
Sprucegoose is offline   Reply With Quote
Old 18th May 2013, 19:42   #1607
infotech58's Avatar
Thanked: 217 Times
Default Re: 1st Gen Honda City Owners - Problems Areas, Fuel Efficiency and more
Get the suspension checked anyways. Rubber bushes go bad after couple of years and a timely replacement might save you an expensive repair later on.
I have not used 205 profile on my OHC but have heard that it is harsh on suspension and touches the wheel wells on full turns; search within this thread for reviews from others. I use 195 profile tyres on my OHC and the grip levels are good. I feel if i lower my car a little bit, it will improve the handling.
The suspension is silky smooth right now. Can't even hear a single squeak from it! Should I still get it checked and replace the bushes? The car has barely been used all these years.
Also, if I go for 205 profile will the front tyres touch the wheel wells when the steering is turned completely?
infotech58 is offline   Reply With Quote
Old 18th May 2013, 20:32   #1608
Thanked: 40 Times
There will be no touching as long as your suspension is in good order.
Old 18th May 2013, 20:32   #1609
BLACKRiVAL's Avatar
Thanked: 15 Times
Originally Posted by BLACKRiVAL View Post
How much oil need to be filled in 1.5 OHC? My mechanic puts in 3.5 litres. Which is the best oil and what should be the grade rating?
Guys any answer for my query.
BLACKRiVAL is offline   Reply With Quote
Old 19th May 2013, 02:22   #1610
pranavt's Avatar
Thanked: 274 Times
3.5L is fine with an oil filter change. Final say depends on the dipstick.
10w30 or 10w40 should be fine. Best oil depends on what your budget is.
Old 25th May 2013, 13:59   #1611
Thanked: 232 Times
Guys, need some advice on a good brand of tyre. I've decided to upsize to 205/50/R15. I tried with one tyre and there were no issues with rubbing/touching. Yokohama S-drive is Rs. 8100 each and Hankook is Rs. 6100. The size is not available in Bridgestone and Michelin.
Please let me know which is the best in terms of grip and ride comfort and road noise.
bowser is offline   Reply With Quote
Old 26th May 2013, 11:53   #1612
Thanked: 40 Times
Don't know about the hankook ones, but the S.Drives are insane
Old 26th May 2013, 12:14   #1613
BLACKRiVAL's Avatar
Thanked: 15 Times
I had Yoko ES100 size 185/60/r14. I must say they were very good handlers but they wore out in 25k kms.
Old 26th May 2013, 18:49   #1614
Thanked: 232 Times
Thanks guys, but I went ahead with Hankook since the Yokos were too expensive and I read good reviews about Hankook. And I got a 5-yr guarantee with them.
Now I'm starting to have the (all too common) problem with my exhaust pipe. If I have to replace it I might as well get an FFE to increase the power at lower RPMs. Does anyone know a good tuner in Hyderabad who has knowledge about VTEC? I couldn't find anything in the teambhp directory. I read elsewhere in the forums that VTEC is more sensitive than the 1.5 and a bad mod will kill the engine.
Old 2nd June 2013, 12:57   #1615
Thanked: 56 Times
survived a bit of a scare yesterday. The wiper motor conked out and even though i switched it off on the control stalk.. apparently the charge to the motor was still going through.. before i knew it, there was thick smoke coming through the dash below the steering.. I immediately pulled over to the side and put off the ignition but not before having a tough time breathing and rolling down the window.
Popped the hood, switched on the ignition again, checked the wiper switch was off.. and still there was smoke coming from the wiper motor. Only option i had was to disconnect the wiring harness to the power molex for the motor which solved the problem.
So anyone know the rates for a new wiper motor? :P
Vandit is online now   Reply With Quote
Old 8th June 2013, 01:17   #1616
Thanked: 42 Times
You could probably get the motor refurbished instead of putting a new one.
To repair it will cost around 1500 or so.
raycers_honda is offline   Reply With Quote
Old 8th June 2013, 01:35   #1617
BLACKRiVAL's Avatar
Thanked: 15 Times
Can someone post a pic of the universal joint connecting the rack to the steering rod? I got refurbished my steering rack and now the think the coupling isnt in the right place.
Old 8th June 2013, 20:01   #1618
Thanked: 232 Times
My VTEC has developed a "khat khat" sound whenever I take a right turn. It seems to be coming from the front left tire. There is no sound when I take a left turn.
Any idea what the problem might be and how to fix it and the probable cost?
Old 8th June 2013, 20:13   #1619
BLACKRiVAL's Avatar
Thanked: 15 Times
Replace the left side axel.
Old 8th June 2013, 20:38   #1620
OHCVtec's Avatar
Thanked: 12 Times
Got my Vtec a shiny new pair of Tail Lights at 2700 a pair, EZDENSO Taiwan. Got a spare old one which I can pass on, let me know if any of you need it. It will fit all Type 2s.
OHCVtec is offline   Reply With Quote
4th Gen Honda City i-VTEC Manual - 1st year ownership report tejas08 Test-Drives & Initial Ownership Reports 42 12th November 2017 20:32
1st-gen Honda City: Adjustable Coilovers, Raceconcepts intake + exhaust and more bhuvan_prasad Modifications & Accessories 15 15th January 2015 20:02
DIY: 1st-Gen Honda City Door Panel Removal bowser DIY - Do it yourself 5 30th October 2014 00:18
Things I need to specifically look for in a 1st-gen Honda City Vtec Rice_tuner Sedans 8 16th June 2008 19:52
honda city (new) (old) and mitsubishi lancer fuel efficiency devarshi84 The Indian Car Scene 3 19th July 2005 12:39
