Old 21st June 2013, 19:21   #1636
t3ofil4us's Avatar
Thanked: 7 Times
Default Re: 1st Gen Honda City Owners - Problems Areas, Fuel Efficiency and more
Originally Posted by Desmosedici View Post
Tie Rods, Lower Arms, Ball Joints also i guess when you mention Suspension Work. Atleast i did get all these done when i had got my Vtec. I'll see if i can fish out the bill and mention what all was done for the Front Suspension. Rear was fine hence left it.
Till then the gurus can pour in.
My rear suspension seems fine, its just the front I am worried about. any help will be appreciated.
Theo
t3ofil4us is offline   Reply With Quote
Old 21st June 2013, 19:53   #1637
Desmosedici's Avatar
Thanked: 405 Times
Originally Posted by johnda View Post
I have water in the boot of the car... slowly collecting under the spare tire, The funny thing is i don't see any drip marks on the carpet like floor, Its somehow dripping in thru the walls i think, and i see it only when i lift the carpet.
I emptied the boot and kinda got in to see if i could see the seep.. tough luck! i thought maybe the mud flap section was breaking, but this is coming even when the car is stationary.
Are there things i could look out for to find this leak?
Maybe the below might help you.
http://www.team-bhp.com/forum/techni...y-more-79.html (1st Gen Honda City Owners - Problems Areas, Fuel Efficiency and more)
Desmosedici is offline   (1) Thanks Reply With Quote
Old 22nd June 2013, 19:13   #1638
Thanked: 185 Times
I feel the reverse lights are not bright enough. Any tips to make them brighter? Will a simple bulb change suffice or is it more complicated?
bowser is offline   Reply With Quote
Old 25th June 2013, 04:11   #1639
t3ofil4us's Avatar
Thanked: 7 Times
@Desmosedici I just noticed , water in my boot as well in the spare tire well.
Got get wet now, cleaning it.
Old 2nd July 2013, 19:53   #1640
t3ofil4us's Avatar
Thanked: 7 Times
Issue Fixed, busted rear antenna was at fault, cut and sealed and spray painted to perfection. Got the rear Bumper which was lowering itself by the minute fixed with my reliable mechanic.
Up Next Front Suspension Overhaul!
Old 3rd July 2013, 14:11   #1641
Thanked: 49 Times
Could be just a bulb change involved.. try with a slightly higher bulb wattage.. ofcourse take into account the fuse capacity to handle the wattage.
Before all that, one thing to remember with the OHC is that the wear of the plastic and its dullness with time drastically affects the throw of lights, so if the plastic of the lights is dull itself, doubt you'd get much improvement by just swapping the bulbs.
Btw, guys... i need a slight clarification on a query i have regarding the TPS which is attached to the TB. I think the problem with my TPS has cropped up again ... and I'm thinking of getting it replaced by an original part. What I'm confused about is whether the TPS can be changed individually or am I looking at an entire TB replacement??
Vandit is offline   Reply With Quote
Old 3rd July 2013, 19:13   #1642
ankitahuja's Avatar
Thanked: 46 Times
TPS can be changed individually. It's a separate part that's mated to the TB.
ankitahuja is offline   (1) Thanks Reply With Quote
Old 3rd July 2013, 19:18   #1643
Thanked: 49 Times
Thank You. Is there anywhere else i can try apart from Shetty Motors for a reliable genuine part? Any idea of the approximate cost?
TIA for the guidance.
Old 3rd July 2013, 19:28   #1644
Thanked: 405 Times
Try City Motors ate Opera House. Heard that you get most Honda City parts there. and please keep us updated
Desmosedici is offline   Reply With Quote
Old 4th July 2013, 17:23   #1645
Thanked: 49 Times
Wilco. Thanx for the tip
Old 4th July 2013, 18:34   #1646
alpha1's Avatar
Thanked: 926 Times
My car's rear dampers (both) are shot.
How much would be the cost?
I hope I can get dampers alone, and it doesn't come packaged with spring and all other auxiliary stuff ...
Old 7th July 2013, 12:01   #1647
pranavt's Avatar
Thanked: 272 Times
Nobody will sell you the TPS separately. Even though it is a separate part, it is mated to the TB using break-away screws. So once tightened, the screw head with notches breaks off leaving a small screw head that has no notches. You can still remove the TPS by making a new notch into the head and using a flat screw driver. Check Kurla's wrecking shops for a TPS, but quality would be suspect. Plus, the TPS needs to be calibrated to the throttle using a multimeter.
pranavt is offline   (1) Thanks Reply With Quote
Old 8th July 2013, 00:15   #1648
Thanked: 41 Times
Check your back seat. Lift it up if its wet that means water is coming somewhere through the rear glass. Also check the corners of the dickey lining when open. As u rightly said water also could be coming from the walls of the boot.
Another good area to check is those black strips on the roof. I always seal the end ,where the glass starts , with araldite as water could leak from there. In these old Hondas the rubber gasket hardens and cracks.
raycers_honda is offline   Reply With Quote
Old 8th July 2013, 19:19   #1649
infotech58's Avatar
Thanked: 213 Times
Windscreen in my OHC used to leak a little bit under heavy rain and after a long struggle I found that the leakage was from the area where roof stripes end. I got it taken care of during I replaced the windscreen and there were no leakages after that.
infotech58 is offline   Reply With Quote
Old 11th July 2013, 04:22   #1650
t3ofil4us's Avatar
Thanked: 7 Times
Has anyone ever replaced the black plastic mud guards or underbody mouldings, mine were missing on one side, Need to find a set as mud and water is sprayed everywhere underneath the bonnet and inside the door hinges.
I am getting a qquote of 1000 for each side (original spares from Opera house my mechanic says), Is it good enough or should I be better off to kurla CST ROAD
4th Gen Honda City i-VTEC Manual - 1st year ownership report tejas08 Test-Drives & Initial Ownership Reports 41 5th October 2015 21:18
1st-gen Honda City: Adjustable Coilovers, Raceconcepts intake + exhaust and more bhuvan_prasad Modifications & Accessories 15 15th January 2015 20:02
DIY: 1st-Gen Honda City Door Panel Removal bowser DIY - Do it yourself 5 30th October 2014 00:18
Things I need to specifically look for in a 1st-gen Honda City Vtec Rice_tuner Sedans 8 16th June 2008 19:52
honda city (new) (old) and mitsubishi lancer fuel efficiency devarshi84 The Indian Car Scene 3 19th July 2005 12:39
