Old 11th July 2013, 15:51   #1651
Desmosedici's Avatar
Thanked: 408 Times
Default Re: 1st Gen Honda City Owners - Problems Areas, Fuel Efficiency and more
Originally Posted by t3ofil4us View Post
Has anyone ever replaced the black plastic mud guards or underbody mouldings, mine were missing on one side, Need to find a set as mud and water is sprayed everywhere underneath the bonnet and inside the door hinges.
I am getting a qquote of 1000 for each side (original spares from Opera house my mechanic says), Is it good enough or should I be better off to kurla CST ROAD
As far as i know, the mud guards for the Type 2 were rubber ones and not plastic moulded ones. I got a set of 4 rubber ones for around 300 bucks from Shetty Motors, Opera House last year.
Desmosedici is offline   Reply With Quote
Old 11th July 2013, 16:05   #1652
BLACKRiVAL's Avatar
Thanked: 15 Times
I got one from decent motors kurla cst for 600rs. It was of left side.
BLACKRiVAL is offline   Reply With Quote
Old 11th July 2013, 22:43   #1653
Thanked: 228 Times
Guys, on the way back from office just now I was forced to drive my precious VTEC though a 2-foot deep pool of water for a distance of 15-20 feet.
It's running fine but what all should I check to make absolutely sure there is no damage?
bowser is offline   Reply With Quote
Old 12th July 2013, 11:57   #1654
alpha1's Avatar
Thanked: 967 Times
Originally Posted by alpha1 View Post
My car's rear dampers (both) are shot.
How much would be the cost?
I hope I can get dampers alone, and it doesn't come packaged with spring and all other auxiliary stuff ...
Can anyone please help!
Also two funny things have cropped up:
1. Looks to be wiring problem. Horn and headlights have stopped working. This happened suddenly yesterday evening (gasp! just made it) during downpour!
2. The Oil level low indication light suddenly comes up for a fraction of a second, and then vanishes. I have not been able to make out the pattern (whether it happens during acceleration/deceleration/braking/turning/engine braking etc).
Old 12th July 2013, 13:17   #1655
pranavt's Avatar
Thanked: 273 Times
If your oil level is upto mark, then you either have a bad pump that isn't able to pump oil constantly and properly (gerotor gears most probably) or the clearances between your crank and bearings has opened up to the point where oil pressure is being lost.
I'd bet it's just low amount of oil in the pan causing it to slosh and feeding the oil pickup some fresh air. Get it checked.
pranavt is offline   (1) Thanks Reply With Quote
Old 15th July 2013, 12:31   #1656
alpha1's Avatar
Thanked: 967 Times
Thanks, it was the low level of oil only (phew!)
Wiring problem has been solved.
Incidentally I faced this wrath of wiring issues while traveling in peak summer - no AC!
Looks like all the socket/plug clips create issues when they get old.
But for the oil problem, there IS a leak, and the mechanic told about one gasket and one bearing that need to be replaced.
Old 15th July 2013, 14:17   #1657
pranavt's Avatar
Thanked: 273 Times
How did he figure out a bad bearing by refilling oil? Assuming it is related to the oil leak issue.
Get the whole engine cleaned to a shine, then spray some white powder in places where the leak could be. Run the engine for some time and recheck the powder and you will find your leak.
Old 18th July 2013, 17:02   #1658
johnda's Avatar
Thanked: 11 Times
2 nights ago I heard a tic tic tic noise from the dash, soon found that my speedo was not working, figured that the cable would have snapped or come off... but the next thing was that the ECL (yellow) dreaded light came on 5 mins after the tic tic music.
my first thought was the O2 sensor is busted again!
The light goes off when i start the engine and reappears after 10mins of running, due to the rains I haven't been able to change the cable or get the car to the mechanic.
Any suggestion to solve this other than change the cable
How complicated is this cable change? is there a way to DIY to know if my sensor is kaput..
johnda is offline   Reply With Quote
Old 18th July 2013, 18:30   #1659
Thanked: 408 Times
Cable change is a fairly simple job. I too had my cable snapped but no tic tic noise. Speedo wouldnt work and the CEL would light up after few minutes of driving. Cable replacement sorted out the things.
On a separate note, while getting the car serviced what all sensors should one check and clean. Heard about MAF or MAP sensors, IAC, Vtec Solenoid etc. Can the gurus provide a list of such sensors to be checked.
Desmosedici is offline   (1) Thanks Reply With Quote
Old 18th July 2013, 20:29   #1660
OHCVtec's Avatar
Thanked: 12 Times
I got this done some time back. Got the cable from Honda A** and got it fixed from my local mechanic due to time constraints. The cable costed around 450/-. Installation was not as straight forward as I had thought as the guy took out the steering and the speedometer from the dash. Only issue I have now is that I get a tic tic noise in the 80-100 kmph range,this might be installation issue. The CEL Light is gone though.
OHCVtec is offline   Reply With Quote
Old 18th July 2013, 23:06   #1661
ankitahuja's Avatar
Thanked: 46 Times
Start reading from post 1341
http://www.team-bhp.com/forum/techni...ml#post2962322 (1st Gen Honda City Owners - Problems Areas, Fuel Efficiency and more)
Notice that the ECU light will come on ONLY when you allow engine breaking = speed up and then take your foot off the accelerator without shifting to neutral for a few seconds, the light will come on. In case you engage the clutch-hit neutral (not allow any engine braking) then the light won't come on!
ankitahuja is offline   (1) Thanks Reply With Quote
Old 30th July 2013, 17:37   #1662
Thanked: 408 Times
Car wont start.
Started the car on Saturday Morning, idled it for a few minutes and switched off. Tried starting the car on Sunday Night and it doesnt. Battery is new and ok. It cranks very slow and then just stops cranking. Could it be the starter motor or something associated with it. Can i try anything at home to start the car. Is push start advisable?
Old 30th July 2013, 17:37   #1663
alpha1's Avatar
Thanked: 967 Times
I guess that he just guessed ...
You have any idea what bearing he was talking about? (no repair done yet)
Also anyone here knows what are the wiper sizes for OHC?
Old 30th July 2013, 21:27   #1664
ankitahuja's Avatar
Thanked: 46 Times
Originally Posted by Desmosedici View Post
Car wont start.
Push start is not advisable. Any recent head work done?
It's either to do with the starter motor or even the alternator - even though the battery is new.
Call the battery guy first thing and check the alternator.
Old 30th July 2013, 21:56   #1665
Thanked: 408 Times
Thanks Ankit. Engine never opened.
Battery is a month old and Alternator work was done 2 months back so it has to be starter motor.
4th Gen Honda City i-VTEC Manual - 1st year ownership report tejas08 Test-Drives & Initial Ownership Reports 42 12th November 2017 20:32
1st-gen Honda City: Adjustable Coilovers, Raceconcepts intake + exhaust and more bhuvan_prasad Modifications & Accessories 15 15th January 2015 20:02
DIY: 1st-Gen Honda City Door Panel Removal bowser DIY - Do it yourself 5 30th October 2014 00:18
Things I need to specifically look for in a 1st-gen Honda City Vtec Rice_tuner Sedans 8 16th June 2008 19:52
honda city (new) (old) and mitsubishi lancer fuel efficiency devarshi84 The Indian Car Scene 3 19th July 2005 12:39
