Old 7th October 2013, 19:25   #1681
ankitahuja's Avatar
Thanked: 46 Times
Default Re: 1st Gen Honda City Owners - Problems Areas, Fuel Efficiency and more
Originally Posted by shelleve View Post
Hi, my 2003 1.5 Exi wont start as off this morning. Battery is perfect, cranks and everything. I stood the car last night after a short drive. Went to drop someone home and it wouldn't start. Felt like it ran out of fuel whereas the fuel meter shows that there is fuel. Just to be safe I am going to fill some more to eliminate that doubt. Any suggestions for a good mechanic around Sushant lok I? Thanks in advance.
Everything sounds right. Check after re-fuelling. Can be a faulty fuel line, distributor, dirty fuel etc.
Old 7th October 2013, 19:30   #1682
ankitahuja's Avatar
Thanked: 46 Times
Everything sounds right. Check after re-fueling. Can be a faulty fuel line, distributor, dirty fuel etc.
ankitahuja is offline   (1) Thanks Reply With Quote
Old 10th October 2013, 13:51   #1683
Thanked: 61 Times
Check the Fuel pump fuse. You may require a screw driver to open it up and then check the continuity of the same.
dip27in is offline   Reply With Quote
Old 15th October 2013, 13:08   #1684
t3ofil4us's Avatar
Thanked: 7 Times
There is nothing that beats the feel of the OHC steering while driving. I tried newer cars like the Duster and Dzire and the OHC beats them hands down on the feel of the road.Another reason to love the OHC.
t3ofil4us is offline   Reply With Quote
Old 17th October 2013, 18:21   #1685
Thanked: 20 Times
ok I had Honda come and have a look at the car and it seems fuel is not travelling from the rear to the main engine bay which could mean a faulty fuel pump in the petrol tank or I think in this one its situated somewhere under the gear leaver - will have to check that out. Anyways, according to Honda a new fuel pump costs 18000 + labor. Anybody got any suggestions? Thanks!
shelleve is offline   Reply With Quote
Old 28th October 2013, 15:08   #1686
OHCVtec's Avatar
Thanked: 12 Times
Guys,
My car has developed this low RPM issue since the last two days. The rpm is extremely low, around 100 and the car stops if not revved. It's kind of undrivable as the rpm drops in between gear shifts and the car halts. Any suggestion to resolve this issue?
OHCVtec is offline   Reply With Quote
Old 7th November 2013, 15:31   #1687
Thanked: 20 Times
I am planning to change the fuel pump on my own. Has anyone experienced doing this before. Do I need to remove my fuel tank for this job. In my opinion no but i could be wrong. a couple of mechanics seem to think otherwise but they too have never changed a fuel pump to a 1.5 Exi so my guess is as good as theirs. The company gave me some ridiculous estimate of 30k.
Old 8th November 2013, 10:37   #1688
Pankaj401's Avatar
Originally Posted by OHCVtec View Post
Guys,
I had the same problem. First step would be to open and clean the IACV.
Pankaj401 is offline   Reply With Quote
Old 12th November 2013, 00:31   #1689
KaandBaaz's Avatar
Thanked: 56 Times
I have recently bought a May 2001 VTEC, Heather Mist in colour with 129000 on the ODO.
Few things that are coming to light :
1.)Small leak near/behind the tappet on the left side if you stand facing the car. Please can anybody tell what needs to be done cause a garage guy near my house quoted 3k to change some 'O' ring that may have gone bad.
2.)Steering tilted to left. Car goes to left if steering is kept straight. (Think so need to get the alignment and balancing done)
3.) Small thud sound followed by vibrations in the back side after going over a speed bump or those white paint lines that are painted nowadays instead of speed bumps.
4.) As the tires need to be changed can anyone please tell me if 185/60 R14 is the right choice or 175/65 R14 is the right size. Currently running on 185/60 R14 . And does this affect FE.
5.) Need to get the car painted as the roof and some parts have lost the base coat due to oxidation or to much exposure to sun. Can any one suggest a good painter. And cost attached to getting a overcoat cause I have been quoted 35k for the whole body and another 8k for alloys.
Last thing please suggest a good garage somewhere in Kothrud or Deccan area to get my car serviced.
Please bear with me. This is my first car. THANKS IN ADVANCE
KaandBaaz is offline   Reply With Quote
Old 12th November 2013, 10:17   #1690
Desmosedici's Avatar
Thanked: 408 Times
Tappet cover gasket might have gone bad. I had recently changed mine. O rings are on the piston, aren't they?
Alignment and balancing should resolve the issue.
Can be minor like bushes or maybe the shocks have gone bust. If you are getting this even on the painted lines then might be serious as those lines are only slightly above the ground and should not have such an impact.
I think I am running 185 65 R 14. It's doing fine.
35k plus the 8k sounds steep. Overcoat should generally cost around 20 to 25k.
No idea since I am in Mumbai. And congrats on the Vtec. It will keep you happy.
My answers in between.
Cheers,
Raj
Desmosedici is offline   (1) Thanks Reply With Quote
Old 21st November 2013, 15:34   #1691
Thanked: 70 Times
@KaandBaaz
I think you have a power steering rack leak. If that's the case you should always keep an eye on the power steering oil resorvoir behind the right headlight. If this goes dry, a noise will develop and you will loose your power steering pump.
Replacing the o-rings in the steering rack MIGHT fix the leak, but does not guarantee it.
micraft is offline   (1) Thanks Reply With Quote
Old 21st November 2013, 15:38   #1692
Thanked: 70 Times
Which is the best synthetic/mineral engine oil which you have used in your OHC?
I usually let the garage or dealer decide based on there preference, but I think we should compile and decide.
So please list the engine oil and the OHC model.
micraft is offline   Reply With Quote
Old 21st November 2013, 17:00   #1693
KaandBaaz's Avatar
Thanked: 56 Times
In the picture you can see the part I am talking of where the leak is. The garage guy is quoting 2-3k for that work.
Bhpian's from PUNE who own an OHC please advice a good garage apart from the Authorised Service Station.
Old 23rd November 2013, 13:32   #1694
OHCVtec's Avatar
Thanked: 12 Times
Guys I need your inputs here. The car throttle had become inconsistent so I got the throttle body cleaned from honda. I also decoded the ECL and it indicated that the Throttle Position Sensor(Error Code 7) is kaput.
Is the TPS available locally or can this be imported ? Do anyone of you have the exact part number /manufacturer for the TPS. Please advise.
Old 23rd November 2013, 13:35   #1695
OHCVtec's Avatar
Thanked: 12 Times
You can take your car to the Honda Service station and get the O ring changed. I got mine changed for 450 bucks an year back.
OHCVtec is offline   (1) Thanks Reply With Quote
4th Gen Honda City i-VTEC Manual - 1st year ownership report tejas08 Test-Drives & Initial Ownership Reports 42 12th November 2017 20:32
1st-gen Honda City: Adjustable Coilovers, Raceconcepts intake + exhaust and more bhuvan_prasad Modifications & Accessories 15 15th January 2015 20:02
DIY: 1st-Gen Honda City Door Panel Removal bowser DIY - Do it yourself 5 30th October 2014 00:18
Things I need to specifically look for in a 1st-gen Honda City Vtec Rice_tuner Sedans 8 16th June 2008 19:52
honda city (new) (old) and mitsubishi lancer fuel efficiency devarshi84 The Indian Car Scene 3 19th July 2005 12:39
