Old 8th December 2013, 11:38   #1696
Default Re: 1st Gen Honda City Owners - Problems Areas, Fuel Efficiency and more
I am having an OHC AT Exi. I am informed by my garage that power steering fluid has started leaking. What would be the cost of repairs / replacement/
ashwin_m0 is offline   Reply With Quote
Old 9th December 2013, 18:13   #1697
Thanked: 7 Times
My ac compressor has apparently seized a few days after getting the gas and oil filled because there was a broken o ring in the circuit in front near the bumper..
1. How do I know it has seized and can I find out why it did?
2. Where can I get a compressor from? The quote I got for a new one was 18.5k.. Does anyone know a place or can someone source it for me?
jayeshrc is offline   Reply With Quote
Old 11th December 2013, 15:22   #1698
Max
Thanked: 85 Times
AC compressor should not cost more then 8k-10k including labor. Check with more garages and dealers. Also check your condenser grill, if its rusty and old get it replaced as well to save on gas refilling cost later. It will cost about 4k. At the end, do let us know how much it cost you.
Max is offline   (1) Thanks Reply With Quote
Old 11th December 2013, 19:39   #1699
OHCVtec's Avatar
Thanked: 12 Times
Originally Posted by OHCVtec View Post
Guys I need your inputs here. The car throttle had become inconsistent so I got the throttle body cleaned from honda. I also decoded the ECL and it indicated that the Throttle Position Sensor(Error Code 7) is kaput.
Is the TPS available locally or can this be imported ? Do anyone of you have the exact part number /manufacturer for the TPS. Please advise.
Guys can anybody please help on this issue. Thanks.
OHCVtec is offline   Reply With Quote
Old 12th December 2013, 00:37   #1700
Thanked: 7 Times
I'll do that. Thanks! The condenser is alright, did check it. Had it replaced a while back.
Hopefully I find a place that can give me the compressor for 8ish. Would be awesome compared the the initial quote
Old 12th December 2013, 19:26   #1701
t3ofil4us's Avatar
Thanked: 7 Times
@OHC VTEC, Even i am struggling to locate the TPS, it comes only as a complete assembly with the throttle body and Mapping Sensor .Used ones come for 4500 to 5000 at CST road. i am looking at one for myself, PM me if you want in. Try decarbonizing and setting the timing first as well.The TPS is one part which is extremely rare even on CST road. Expect Honda to quote 15K for a brand new one(the Throttle body assembly)
Last edited by t3ofil4us : 12th December 2013 at 19:28. Reason: Additional Content
t3ofil4us is offline   (1) Thanks Reply With Quote
Old 12th December 2013, 22:47   #1702
Thanked: 84 Times
Originally Posted by t3ofil4us View Post
@OHC VTEC, Even i am struggling to locate the TPS, Cheers
Conact PranavT, he can source one for you.
Honda Monk is offline   (1) Thanks Reply With Quote
Old 23rd December 2013, 03:30   #1703
t3ofil4us's Avatar
Thanked: 7 Times
I did already but he seems busy at the moment.
I located one fro 3000 but it is in worse condition compared to mine. The Search is still on.
t3ofil4us is offline   Reply With Quote
Old 29th December 2013, 11:25   #1704
Thanked: 56 Times
I experienced similar prob with the TPS a few months ago. I too didn't understand the reason for the fluctuating idle rpm till I had the adjustment done to the tuning screws on the TPS while the car's OBD port was connected to the scanner. While it did rectify the problem 98% the idle still takes a wee bit longer to settle to normal especially on startup than it did before the problem arose.
I figured it was worth it to live with a slight off behaviour once I heard the ridiculous prices honda quoted for the TPS. Even after market rates are petty high I guess.. Not sure if even Shetty Motor keeps or sources it anymore.
Good luck on your search. Keep us posted on what you do for the TPS problem
Vandit is offline   Reply With Quote
Old 30th December 2013, 14:32   #1705
Max
Thanked: 85 Times
Just gave my car for suspension overhaul + break pads replacement. Will update soon with more details. Estimate is about 24k/25k.
Max is offline   Reply With Quote
Old 1st January 2014, 11:30   #1706
Thanked: 56 Times
Happy New Year all. My car starts 14years today!
Old 8th January 2014, 11:24   #1707
KaandBaaz's Avatar
Thanked: 56 Times
Unhappy Re: 1st Gen Honda City Owners - Problems Areas, Fuel Efficiency and more
Hello,
Yesterday night when I started my car, I could hear the sound of a liquid flowing from the left side ( near the glove box). So I quickly turned the engine off and the sound stopped. Again I started the car and again I could hear the sound. I started the car after 8 days as was not in town.
Can any body help me with what the issue might be?
KaandBaaz is offline   Reply With Quote
Old 8th January 2014, 12:40   #1708
Thanked: 56 Times
Does it sound like bubbling circulation sound?? And intermittent.. Not continuous sound of flowing and only during the AC being on? Then it's most likely to do with the AC circulation. My car does it.
Old 8th January 2014, 15:05   #1709
KaandBaaz's Avatar
Thanked: 56 Times
No it was continuous for a minute or two, with the A/C being OFF. Didnt check for long. Will try again today. And yes it was like bubbling circulation. Will go home today and check if it re-occurs while driving as well.
Old 12th January 2014, 01:08   #1710
Thanked: 228 Times
My VTEC is completely stock except for the tires which I upsized to Hankook 205/50/R15. My problem is whenever I reach 110 kmph on the highway the car starts to shake. How can I fix this?
I read on wiki that the 1.5 exi and VTEC are D15B engines that have been reduced in power for the Indian market. Was this power electronically limited? Is there a way to "unlock" the extra power?
Also, considering this is now 2014 and the OHC is over a decade old, is it still possible to get performance parts (like GReddy direct bolt on headers, etc.)? I'm in Hyderabad and Pete's has recently set up shop here. I went there with high hopes but one of the advisors shattered my expectations saying there is nothing they can do for my car. Sorry for the drama but this is exactly how I felt. Can someone please give me a list of basic upgrades I can do to improve the power in the low and mid range? Thanks in advance!
bowser is offline   Reply With Quote
4th Gen Honda City i-VTEC Manual - 1st year ownership report tejas08 Test-Drives & Initial Ownership Reports 42 12th November 2017 20:32
1st-gen Honda City: Adjustable Coilovers, Raceconcepts intake + exhaust and more bhuvan_prasad Modifications & Accessories 15 15th January 2015 20:02
DIY: 1st-Gen Honda City Door Panel Removal bowser DIY - Do it yourself 5 30th October 2014 00:18
Things I need to specifically look for in a 1st-gen Honda City Vtec Rice_tuner Sedans 8 16th June 2008 19:52
honda city (new) (old) and mitsubishi lancer fuel efficiency devarshi84 The Indian Car Scene 3 19th July 2005 12:39
