Old 3rd November 2009, 12:20   #181
ankitahuja's Avatar
Thanked: 46 Times
Agreed. Dippy, go in for TB and IAC valve cleaning. Should do you good.
Old 3rd November 2009, 12:28   #182
Sprucegoose's Avatar
Thanked: 40 Times
Sorry for the n00b question, but whats an IAC valve?
Sprucegoose is offline   Reply With Quote
Old 3rd November 2009, 13:55   #183
KSM-Vtec's Avatar
Thanked: 440 Times
if i am not wrong its the Intake air control valve.
KSM-Vtec is offline   Reply With Quote
Old 3rd November 2009, 14:50   #184
pranavt's Avatar
Thanked: 274 Times
It's on the throttle body, in front of you when you open the hood. 2 rubber pipes for coolant going in and out of it.
Old 3rd November 2009, 15:08   #185
Thanked: 40 Times
Is it the valve which opens up when the throttle is applied?
the butterfly valve?
Old 3rd November 2009, 15:10   #186
Thanked: 40 Times
Originally Posted by Ford Rocam View Post
Keeping Electrical & electronics part on side, i will also recommend first you go more deep in to engine mechanical, like understanding air flow basic, manifold design (int/exh), compression ratio, flame front,octane rating of fuel, knock,air fuel ratio, the role camshaft plays in performance of an engine & how camshaft timing influence performance, plus lots more.
Once you know that, then you will know how to play with the AFRs & Ignition without that it will be like you are running blind folded, cause you can even damage your N.A engine with a wrong tune.
Trust me, it might take you years not months to learn all that, its never ending, you will need to keep up learning always to keep pace with technology.
Can anyone point me to some good reference material, I have a lot of free time on my hands.
Old 3rd November 2009, 15:16   #187
pranavt's Avatar
Thanked: 274 Times
No, not the butterfly valve. Outside, but connected to the TB, in front of you.
Old 4th November 2009, 01:45   #188
pranavt's Avatar
Thanked: 274 Times
The circled part is the IACV.
Old 4th November 2009, 15:39   #189
Thanked: 40 Times
cool, thanks.
and the IACV essentially bypasses the butterfly valve inside the throttle body to ensure that the engine Idles at the specified RPM?
The IACV will let more air through when the AC is on so that the Idling increases?
Old 4th November 2009, 19:31   #190
honda3938's Avatar
I am having a problem with my OHC. The starter solenoid is giving up after one or two months. I have changed it 3 times but samething happens again and again.It gets jammed after few weeks.I am unable to start the car and hear only a clicking sound . If i am lucky the car will start in 3-4 attempts otherwise have to hit the solenoid with something to start the car.What could be the cause of this.The solenoid i am using is the aftermarket one .Which is the original brand for Honda and where can i get it and for what price.I am totally fed as i have no confidence that whether my car will start or not .Plz give me solution...thanks
honda3938 is offline   Reply With Quote
Old 4th November 2009, 19:48   #191
pranavt's Avatar
Thanked: 274 Times
cool, thanks.
Correct. There's a movable plate inside the IACV which varies the amount air passing through.
Old 9th November 2009, 12:18   #192
sushrutha's Avatar
Thanked: 325 Times
My OHC is having starting trouble.
Battery is fine(lights + stereo everything works fine).Even replaced the battery and verified. Ignition lights comes up, but when I crank the car, it's not starting , just tak sound is comming. Car starts by PUSH Start. so what could be the issue ?
Starter motor ?? Flywheel ?
Old 9th November 2009, 12:30   #193
KSM-Vtec's Avatar
Thanked: 440 Times
Well i was facing a similar issue on and off. Checking if the starter motor is working fine or not is not very difficult.
If the starter motor is fine then.....
Try cleaning the injectors, change the fuel filter and then check.
If the problem still remains it could be the fuel pump.
Old 9th November 2009, 12:49   #194
sushrutha's Avatar
Thanked: 325 Times
Oops ..don't gimme shock dude. That's the last thing I don't want to see, FUEL pump issue.
But if Fuel pump is the issue, how come push start woks perfectly.
I don't see any warning lights on. C.E.L is working perfectly fine(I can hear fuel pump supplying fuel, when the key is tuned on for ignition)
Old 9th November 2009, 12:59   #195
Dippy's Avatar
Thanked: 189 Times
Originally Posted by vid6639 View Post
That's a simple one. There is usually an idle control stepper motor near the TB opening. It varies the idling with and without AC.
If there is too much kachra stuck it stops working and does not increase the rpm. It just needs a bit of cleaning a 5 min job. When you turn on the ac the load causes the rpm to drop which is usually compensated by this stepper motor.
Thanks guys
The car is due for service and I'm sending it in coming Saturday. I'm going to request a throttle body cleaning and AT oil change. Anything else in particular that I should look at? The car is right now at 69k kms.
Dippy is offline   Reply With Quote
4th Gen Honda City i-VTEC Manual - 1st year ownership report tejas08 Test-Drives & Initial Ownership Reports 42 12th November 2017 20:32
1st-gen Honda City: Adjustable Coilovers, Raceconcepts intake + exhaust and more bhuvan_prasad Modifications & Accessories 15 15th January 2015 20:02
DIY: 1st-Gen Honda City Door Panel Removal bowser DIY - Do it yourself 5 30th October 2014 00:18
Things I need to specifically look for in a 1st-gen Honda City Vtec Rice_tuner Sedans 8 16th June 2008 19:52
honda city (new) (old) and mitsubishi lancer fuel efficiency devarshi84 The Indian Car Scene 3 19th July 2005 12:39
