Old 25th November 2009, 23:37   #256
johnda's Avatar
Thanked: 11 Times
waiting for your PM. nice to know that there is a store where you have all the OHC spares and upgrades.
Thanks Shan2nu
johnda is offline   Reply With Quote
Old 26th November 2009, 00:20   #257
vinayvtec's Avatar
Thanked: 9 Times
The most common issue faced by the OHC owners now days is steering rack oil leakage issue.
vinayvtec is offline   Reply With Quote
Old 26th November 2009, 17:40   #258
Question Need a 1.5 VTEC - Spec sheet
Guys,
i am about to get my first VTEC, a 2003 one, been trying to source a brochure or spec and tech that some of you may still have from the old days when you bought the car new ( lucky folks) . If any of you have the brochure / spec data that compared all the models side by side in a table type format, do you mind scanning and posting here, will be a real help.
Thanks.
sanjayr328 is offline   Reply With Quote
Old 26th November 2009, 18:30   #259
ssjr0498's Avatar
Thanked: 120 Times
What spec's are you looking at?
Shrey
Originally Posted by sanjayr328 View Post
Guys,
Thanks.
ssjr0498 is offline   Reply With Quote
Old 26th November 2009, 20:10   #260
honda3938's Avatar
Guys,
Thanks.
i have a manaul on my HD . If you want i can send that to you . Pm your email id
honda3938 is offline   Reply With Quote
Old 26th November 2009, 21:00   #261
@shrey - looking for a scanned copy of the original brochure basically.. If it is still around..
cheers
Old 28th November 2009, 20:05   #262
The VTEC's going to come to me tomorrow , so Tyre size recommendations please , i need the tyre size to be sane, we drive all around the country, so need something that wont rub and all that - 195/ 60 - R14 ? any experience anyone with Potenzas or Turanzas ? i have run Turanzas on my Indigo now for the last three years - and they have been pretty good, sharp handling but stiff ride which is am fine with, but this is not a Indigo , so will Turanzas do guys ?
Old 28th November 2009, 20:18   #263
Thanked: 9 Times
My OHC when driven on night with headlights on for few mins the horn stops working. When i press the horn the dash board lights get dim but no issue with the headlight and stereo . The battery light is not glowing. When the headlight is off the horn starts working. Also the car starts in first crank till now . What could be the reason ?
vinu_pm is offline   Reply With Quote
Old 29th November 2009, 08:33   #264
honda3938's Avatar
i think horns are not properly grounded. another reason may be that alternator is supplying less current.if you have upgraded horn and headlights than you need a relay.
Old 29th November 2009, 13:15   #265
KSM-Vtec's Avatar
Thanked: 440 Times
it could be the alternator or your batter cells could be weak. Should be a simple issue to resolve, just go to one of these battery sales/service guys and ask him to check the output on your alternator and battery. Do the check at full load.(AC+headlights+ICE+hazard)
KSM-Vtec is offline   Reply With Quote
Old 29th November 2009, 22:28   #266
johnda's Avatar
Thanked: 11 Times
is there any co-relation with the similar problem - While I have my a/c on full blast and i'm driving there is a slight drop in the fan speed at intervals.
for eg. I'm driving with a/c on and blower on 3. while i'm driving the fan blower 'seems' to dip it its speed just for a brief 10secs, like as if the compressor came on or something.
I've had no issues thus far but wanted to know if there is a sting around the bend:-)
Old 30th November 2009, 01:36   #267
pranavt's Avatar
Thanked: 274 Times
Just wanted to confirm, what's the heat range of the stock spark plugs of the OHC VTEC engine?
Old 30th November 2009, 09:40   #268
ssjr0498's Avatar
Thanked: 120 Times
6E is what is standard on the OHC Vtec!
@sanjay: 195/60/14 should be the perfect upsize. It wont give you any issues whatsoever!
Shrey
Old 30th November 2009, 14:34   #269
@ shrey - thanks, i will go with 195/60/14 then..
A few days back i was looking for this data sheet of the VTEC , finally got it from Honda directly, posting here in case someone else needs it.. it's low resolution, but does the job ..
1st Gen Honda City Owners - Problems Areas, Fuel Efficiency and more-1.5vtec.jpg
Last edited by Jaggu : 30th November 2009 at 14:46. Reason: back to back posts, please EDIT the original post after its approved, if you want to add. thanks
Old 2nd December 2009, 20:40   #270
Thanked: 9 Times
The battery guy Checked and told me that it is perfectly ok. He used a multi meter to check and unscrewed the battery and checked the fluid with a sucker .He said it could be relay or alternator problem and he is not qualified to check that.
Now I am worried .if it is relay could be simple fix i guess ,but if it alternator Honda is going to rip me .
Is there any good mechanic appart from HASS near old Airport Road to check that ?
4th Gen Honda City i-VTEC Manual - 1st year ownership report tejas08 Test-Drives & Initial Ownership Reports 42 12th November 2017 20:32
1st-gen Honda City: Adjustable Coilovers, Raceconcepts intake + exhaust and more bhuvan_prasad Modifications & Accessories 15 15th January 2015 20:02
DIY: 1st-Gen Honda City Door Panel Removal bowser DIY - Do it yourself 5 30th October 2014 00:18
Things I need to specifically look for in a 1st-gen Honda City Vtec Rice_tuner Sedans 8 16th June 2008 19:52
honda city (new) (old) and mitsubishi lancer fuel efficiency devarshi84 The Indian Car Scene 3 19th July 2005 12:39
