Old 11th December 2009, 00:53   #286
Thanked: 364 Times
I have an update on the buffing vs replace windscreen issue, I was going to replace the windscreen because of swirlies, and a lot of them which was making night driving extremely dangerous, and most forum opinion seems to suggest change which I concurred with. However on my recent service at Linkway the polishing guy managed to convince me to do the polishing for 1.5k with a one year warranty.
I warned him that if there were any issues I would get hold of him without fail. Well I have been driving the car for over a week since including a late night trip to Pune from Bbay and back and I must say for 1.5k I am quite impressed.
All the swirlies and scratches are gone and windscreen is as good as new, and to think it took the polishing guy barely 15 minutes to get it done, I am wondering why I put up with it for 6 months. Of course time will tell how well it wears but for the time being I am satisfied.
raul is offline   Reply With Quote
Old 11th December 2009, 22:23   #287
@ ankit & sprucegoose
thanks, 100/90 with a harness and relay it is, stick to reputed brands - this is tomorrows project, even city driving on low beam (which is what we prefer ) is starting to become harrowing..so need to do this quickly.. cheers.
sanjayr328 is offline   Reply With Quote
Old 25th December 2009, 14:53   #288
johnda's Avatar
Thanked: 11 Times
Originally Posted by KSM-Vtec View Post
Not sure but most insurance cos give 90% on the glass. just got once changed for the Ikon and we had to pay only 1k for the entire job including labour.
It was cash less. btw the WS cost was 5.5k.
Yes, I got the WS changed, and it came up to about 1.6K only. the rest was cover by insurance. and the WS is 6K.
I've changed both Drive shafts too.
I have the O2 sensor left.
I still have a rumble while on a bad road, I hope its not my suspension arms.
johnda is offline   Reply With Quote
Old 26th December 2009, 22:17   #289
Default Update on VTEC restoration and first long drive
Guys,
a quick update on my brief restoration project
1. Headlamp bulbs changed to 90/100 - Hella with original Hella harness - about 1000 Rs - much improved than before
2.Alloys repainted, a two day DIY project with some tips from other threads here as well as other internet sources - after pictures enclosed,before pictures were posted earlier in this thread - reasonable results, will need more work i guess 6 months down the line
3. ICE installed, sub, 2 amps - will provide more details later with pictures
4. Did our first long drive - Pune to Bangalore, car performed well, mostly three digit speeds, around 100 to 120 most of the time - got 15.5 avg - which is damn good, had an aching butt by the end of the trip seats need some work i guess, hard to add more cushioning on the other part he he.
5. The Yoko ES100's are shaping up well so far, grip levels are decent, tyre noise is ok..
6. Proud to have TBHP stickers on the car now , see samples
more updates later, thanks for all the tips..
1st Gen Honda City Owners - Problems Areas, Fuel Efficiency and more-19122009002.jpg
1st Gen Honda City Owners - Problems Areas, Fuel Efficiency and more-20122009.jpg
1st Gen Honda City Owners - Problems Areas, Fuel Efficiency and more-19122009003.jpg
Old 20th February 2010, 14:17   #290
_raviShankar_'s Avatar
Thanked: 67 Times
Guys,
I feel very happy bumping into this thread. Exactly what I was looking for.
My OHC 1.5 EXI has developed a leak in the steering rack and i need to repair it. The Honda guys suggested replacing the entire assembly (would cost me around 15-16k).
Can anybody here (fellow Bangloreans) suggest a reliable mechanic who can fix this for me.
_raviShankar_ is offline   Reply With Quote
Old 20th February 2010, 22:43   #291
KSM-Vtec's Avatar
Thanked: 440 Times
Originally Posted by _raviShankar_ View Post
Guys,
Double check if the entire assembly has to be changed, in most cases its just the oil-seal.
KSM-Vtec is offline   Reply With Quote
Old 21st February 2010, 22:54   #292
Thanked: 67 Times
@ KSM-Vtec: I believe its just the oil seal.
I just need a reliable mechanic to confirm this and do the repair. I am not familiar with any workshop guys here and i hope you guys can point me in the right direction.
I stay in Vidyaranyapura, Bangalore so if you guys know any reliable workshops around this area (anything around 10-15 kms) please do let me know.
Old 22nd February 2010, 10:30   #293
KSM-Vtec's Avatar
Thanked: 440 Times
Changing the oil seal is a trick job. in mumbai we have specialist who do only power steering work.
Old 22nd February 2010, 10:52   #294
Thanked: 138 Times
Is it true that a hard clutch can actually damage the flywheel if one doesn't get it overhauled over a period of time, even though there's no slippage?!
I was quoted 10K for a clutch overhaul (coz it's hard) and was advised the above when I took my VTEC to a garage in Goregaon, short while ago. Thankfully, the rear wheel bearings (which were busted as per Linkway) are just fine.
Experts, please advise.
Avinash
avinash_m is offline   Reply With Quote
Old 22nd February 2010, 12:16   #295
KSM-Vtec's Avatar
Thanked: 440 Times
Avinash
10K for a clutch overhaul is too much. i think a new clutch assembly should cost you less than that.
Old 22nd February 2010, 12:40   #296
Thanked: 138 Times
@KSM-Vtec: Thanks, I thought so too. Infact, just read this whole thread and saw people getting it done for quite less. Any pointers as to where should I get the OEM assembly from and which brand?
Old 22nd February 2010, 14:09   #297
KSM-Vtec's Avatar
Thanked: 440 Times
You can get the parts from Laxman Auto or City Motors at Opera House.
Let me know if you need any help i know them personally.
Old 25th February 2010, 09:13   #298
johnda's Avatar
Thanked: 11 Times
I noticed another issue with my OHC. every time is use the car after a break eg.. in the morning. After I start the engine the rpms are a lil above 1.3k.. and then drops to 1k or lower (which i know is natural) and let say after a minute i start driving and the in motion the engine start to rev - so car is moving but acceleration is fluctuating when the clutch is pressed. I started noticing this esp when i change gears. The acceleration doesn't drop fully so the engine revs when I press the clutch. (the rev is in intervals)
the problem seems to go if slowly released the clutch and run a lil more on the same gear or also if I rev the engine a bit, it drops back.
One time I stopped the car while this was going on and the engine was revving on its own. its not like the cable is stuck and the rev is staying up. its going up and down on a regular interval.
Old 25th February 2010, 09:44   #299
Shan2nu's Avatar
Thanked: 89 Times
Get the throttle sensor (tps), vacuum hoses and throttle body checked.
Shan2nu
Old 25th February 2010, 09:51   #300
KSM-Vtec's Avatar
Thanked: 440 Times
Originally Posted by johnda View Post
I noticed another issue with my OHC. every time is use the car after a break eg.. in the morning. After I start the engine the rpms are a lil above 1.3k.. and then drops to 1k or lower.
Did you get a TB cleanup done before the problem started??
Originally Posted by Shan2nu View Post
Get the throttle sensor (tps), vacuum hoses and throttle body checked. Shan2nu
Ya it has to be one of the 3. Mostly it would be the tps sensor setting.
@Shan - whats the cost of the tps in bang??
4th Gen Honda City i-VTEC Manual - 1st year ownership report tejas08 Test-Drives & Initial Ownership Reports 42 12th November 2017 20:32
1st-gen Honda City: Adjustable Coilovers, Raceconcepts intake + exhaust and more bhuvan_prasad Modifications & Accessories 15 15th January 2015 20:02
DIY: 1st-Gen Honda City Door Panel Removal bowser DIY - Do it yourself 5 30th October 2014 00:18
Things I need to specifically look for in a 1st-gen Honda City Vtec Rice_tuner Sedans 8 16th June 2008 19:52
honda city (new) (old) and mitsubishi lancer fuel efficiency devarshi84 The Indian Car Scene 3 19th July 2005 12:39
