Old 25th February 2010, 09:58   #301
VTEC_Rocks's Avatar
Originally Posted by _raviShankar_ View Post
Guys,
I feel very happy bumping into this thread. Exactly what I was looking for.
My OHC 1.5 EXI has developed a leak in the steering rack and i need to repair it. The Honda guys suggested replacing the entire assembly (would cost me around 15-16k).
Can anybody here (fellow Bangloreans) suggest a reliable mechanic who can fix this for me.
Hi Ravishankar,
You could get it done in Bosch Cars on Chord Road or RAC in Koramangala.
RAC is a good place, Please speak to a person called "Ranjith" when you go there. He should be able to help. I can give you the service advisor's number there. PM me if you want to get it done there.
Bosch cars do a good job too. Bosch cars will be closer to your place.
VTEC_Rocks is offline   Reply With Quote
Old 25th February 2010, 16:57   #302
johnda's Avatar
Thanked: 11 Times
Originally Posted by KSM-Vtec View Post
Did you get a TB cleanup done before the problem started??
Ya it has to be one of the 3. Mostly it would be the tps sensor setting.
@Shan - whats the cost of the tps in bang??
No, I haven't checked any of them. The sad part is a taking this car for service. The HASS is a day-out. 7hrs total travel + time at service center.
I hope there is one that opens closer. But will get these checked.
@KSM - TB clean up? I didn't follow that (my bad ) but I didn't do any work other than the periodic service.
johnda is offline   Reply With Quote
Old 25th February 2010, 17:03   #303
KSM-Vtec's Avatar
Thanked: 440 Times
Throttle body clean up. When the carbon is taken off there is little more space between the butterfly and the TB which leads to fluctuating rpm.
normally the tps is also cleaned with the tb and hence there could be a problem with the tps setting.
KSM-Vtec is offline   Reply With Quote
Old 25th February 2010, 17:32   #304
johnda's Avatar
Thanked: 11 Times
Thanks for the explanation . I'll be checking all the areas advised by you all. One more thing is there a problem driving around like this atleast for another 2 -3 weeks? Coz its impossible for me to get outta here to get the car checked. I know that a stupid question but i asked anyway!
Old 25th February 2010, 17:40   #305
KSM-Vtec's Avatar
Thanked: 440 Times
Cool. I dont think it should be a problem. If you notice that the problem has increased then do stop driving the car.
otherwise it will only impact your FE.
Old 25th February 2010, 23:06   #306
_raviShankar_'s Avatar
Thanked: 67 Times
Changing the oil seal is a trick job. in mumbai we have specialist who do only power steering work.
Thanks for the advice. I hope i can find somebody who can do it for me here.
Originally Posted by VTEC_Rocks View Post
Hi Ravishankar,
Thanks a lot man
_raviShankar_ is offline   Reply With Quote
Old 5th March 2010, 17:45   #307
narayan's Avatar
Thanked: 1,324 Times
Guys - ive got a 85k done OHC 1.5
2 days back have started a tak tak sound - sound is quite mild but i can feel it in the floor well and it comes when i take a right turn and start moving. sound is absent while moving in a straight line
what could be the problem ? drive shaft ?
narayan is online now   Reply With Quote
Old 5th March 2010, 17:50   #308
KSM-Vtec's Avatar
Thanked: 440 Times
are you sure that it has nothing to do with the suspension??
Check if the sound comes on bad roads or only on right turns.
is the sound present when you turn right at standstill.
Old 5th March 2010, 17:52   #309
narayan's Avatar
sound is present when i turn right at stand still.
Old 5th March 2010, 18:17   #310
KSM-Vtec's Avatar
Thanked: 440 Times
it could still be your ball joint or lower arm. i think it will be a better idea to get it checked.
Old 5th March 2010, 19:33   #311
Ford Rocam's Avatar
Thanked: 16 Times
probably yes, Get the axle checked.
Ford Rocam is offline   Reply With Quote
Old 5th March 2010, 20:16   #312
Shan2nu's Avatar
Thanked: 89 Times
I had that tak tak sound in my car every time i turned the steering. Turned out to be a simple tie rod end prob.
Shan2nu
Old 9th March 2010, 09:04   #313
johnda's Avatar
Thanked: 11 Times
Shan2nu
So was that a replacement or was it re-adjusted.. I'm asking coz the Honda folks mentioned that my Tie Rod had an issue.
Old 9th March 2010, 09:53   #314
Shan2nu's Avatar
Thanked: 89 Times
They replaced it. Wasn't very expensive, i think i paid around 400 (this was in 2004) for both tie rods ends.
http://www.team-bhp.com/forum/techni...b-my-vtec.html (Steering prob on my vtec!!!)
Shan2nu
Old 13th March 2010, 14:29   #315
Thanked: 9 Times
Default idiling rpm
I recently noticed my idle rpm has gone up slightly on my OHC 1.3 previously it was 800 and when AC on it was close to 1000 . Now without AC it is 1200 and with AC its close to 1300 . What could be the reason . 2 days back i reved the car on stand still till 6K - 7K just to notice the K&N sound. Will that be a cause ?
And give the car for refixing the Rear bumper .RAC took 2 days to deliver it . Not sure whether they screwed it up.
vinu_pm is offline   Reply With Quote
4th Gen Honda City i-VTEC Manual - 1st year ownership report tejas08 Test-Drives & Initial Ownership Reports 42 12th November 2017 20:32
1st-gen Honda City: Adjustable Coilovers, Raceconcepts intake + exhaust and more bhuvan_prasad Modifications & Accessories 15 15th January 2015 20:02
DIY: 1st-Gen Honda City Door Panel Removal bowser DIY - Do it yourself 5 30th October 2014 00:18
Things I need to specifically look for in a 1st-gen Honda City Vtec Rice_tuner Sedans 8 16th June 2008 19:52
honda city (new) (old) and mitsubishi lancer fuel efficiency devarshi84 The Indian Car Scene 3 19th July 2005 12:39
