Old 7th May 2010, 18:15   #346
narayan's Avatar
Thanked: 1,240 Times
sunny - yes u should stick to 14". the ride goes for a toss with 15". i am running 15" and im not happy with the ride atleast.
your FE seems to be very good and im quite surprised u get that figure in delhi traffic. 14 is more like a highway FE for an ohc.
narayan is offline   Reply With Quote
Old 7th May 2010, 18:18   #347
narayan's Avatar
Default Engine Mounts Change
When do you know its time to change the engine mounts ?
I have been getting the juddery feel whenever i start moving from 1st gear. only way to avoid it is to give some throttle input.
when i saw a friend of mine start my car and take it from 1st, i could see that the front was showing some vibrations when you merely leave the clutch to move forward ( without giving any accelerator inputs )
i also notice that with the a/c on, i can sense that the vibrations are higher. there is even a noticeable vibration of the hood.
do all these indicate the engine mount has packed ?
its a 1.5 OHC. 2001. done 85k
Old 7th May 2010, 18:37   #348
sushrutha's Avatar
Thanked: 324 Times
@Narayan,
First check the engine mountings as whether they are loose or not. If so get them tightened.
Also for the bonnet vibration, you can avoid the vibration to some extent by pasting the cello tape(Black tape used for wire insulation) on the inside part of the clamp(U shaped below bonnet), which holds the bonnet with the body.
New engine mounts would cost around 7K.
Old 24th May 2010, 12:23   #349
Thanked: 24 Times
All,
I have a OHC 1.5Exi AT bought second hand at around 74k, currently it has done 78k. I finally got around to overhauling the car - Suspension, O2 sensor, headlights and Underbody corrosion check. Ended up spending nearly 35k on all this and the result of all this is that I have a nice AT car to drive around the city comfortably :-).
Here is the spare parts cost in case anyone else is looking for over hauling there OHC. I did all this in a private garage over here in Chennai, so the prices are not the A.S.S ones - but the parts are either Genuine or equivalent to OE ones.
Timing belt - 1300
RHS drive shaft - 6500
Tie rods/Ball joints - 2200
O2 sensor - 4300
Underbody treatement - 3000
Headlight upgradation to 100/90 with relay - 5000.
Bosch wiper blades - 350.
partha379 is offline   Reply With Quote
Old 24th May 2010, 14:52   #350
sushrutha's Avatar
Thanked: 324 Times
Upgradation should not cost you more than 1.5K Rs inlcuding wiring + relay + bulbs(100/90 ).
5K seems pretty higher.
What bulb have you put ? Did you change the headlamp assembly ?
Else the pricing is too much
Old 29th May 2010, 22:57   #351
Thanked: 24 Times
The above cost was including the headlight assembly, sorry for missing that part and thanks for pointing it out.
Old 30th May 2010, 10:03   #352
_raviShankar_'s Avatar
Thanked: 65 Times
@ partha379 : Is that the rate for both left and right headlight assemblies together or just one of the two ?
_raviShankar_ is online now   Reply With Quote
Old 31st May 2010, 15:04   #353
alpha1's Avatar
Thanked: 968 Times
My exhaust pipe is rusted.
I think the portion which is below the rear seat / foot area.
Asked welder - he can't do a patch work job.
Looks like I have to buy a new one - any idea about how much a new one will cost?
Old 31st May 2010, 15:28   #354
kutlee's Avatar
Thanked: 194 Times
go for two piece (total number of pieces = 3) after market pipes. u can get one from automech. pretty decent and cost around 7k.
kutlee is offline   Reply With Quote
Old 31st May 2010, 18:00   #355
Default helppp
Hi guys..
can any of you guys tell me where can i get Exedy stock clutch for OHC 1.5EXi in Delhi??
I need to get my stock set replaced urgently. Cant seem to get me hands on one here in Delhi.
Also if youll could indicate the price, it would be great.
Thanks in advance.
sunnysdome is offline   Reply With Quote
Old 1st June 2010, 10:22   #356
alpha1's Avatar
Thanked: 968 Times
This Automech is in Pune also?
Old 1st June 2010, 10:30   #357
sushrutha's Avatar
Thanked: 324 Times
I have got my car's silencer patch work done many times.
Heck the silencer got broke yesterday evening.
Pic is when my silencer got broke sometime back. One can see the patch work done previously at the left side Name:  Sushruth 038.jpg
OEM silencer 3 piece unit costs 22K when i enquired last time.
Old 1st June 2010, 12:08   #358
VTEC_Rocks's Avatar
Get an FFE done. It would cost you half the price and the engine will be healthy.
VTEC_Rocks is offline   Reply With Quote
Old 1st June 2010, 13:39   #359
alpha1's Avatar
Thanked: 968 Times
Pic is when my silencer got broke sometime back. One can see the patch work done previously at the left side Attachment 359562
yeah ... it looks exactly like that ...
In pune?
Looks difficult.
Old 1st June 2010, 13:46   #360
kutlee's Avatar
Thanked: 194 Times
contact automech and they might have a dealer in pune. or get it shipped to your address and fixed at any garage.
4th Gen Honda City i-VTEC Manual - 1st year ownership report tejas08 Test-Drives & Initial Ownership Reports 42 12th November 2017 20:32
1st-gen Honda City: Adjustable Coilovers, Raceconcepts intake + exhaust and more bhuvan_prasad Modifications & Accessories 15 15th January 2015 20:02
DIY: 1st-Gen Honda City Door Panel Removal bowser DIY - Do it yourself 5 30th October 2014 00:18
Things I need to specifically look for in a 1st-gen Honda City Vtec Rice_tuner Sedans 8 16th June 2008 19:52
honda city (new) (old) and mitsubishi lancer fuel efficiency devarshi84 The Indian Car Scene 3 19th July 2005 12:39
