Old 13th August 2010, 03:07   #391
Mpower's Avatar
Thanked: 1,682 Times
Originally Posted by sanjayr328 View Post
BOSCH sensors dont have good feedback, poor pick up and life of the sensor is a problem - or so i am told , even the insiders i know at the dealership dont recommend it, they were thrilled with this one though
OK, but how much does it cost?
Did you check for Denso in Opera house?
Old 13th August 2010, 09:42   #392
Having heard the feedback i didn't try the BOSCH option at all - honestly .
i wanted Denso just to be sure, went straight to the website , Living in Pune has its limitations unlike Mumbai where sourcing is a little easier. I also wasn't convinced about the Denso part being genuine if bought here.
Regards..
sanjayr328 is offline   Reply With Quote
Old 13th August 2010, 10:48   #393
pranavt's Avatar
Thanked: 273 Times
It's probably hearsay. No reason why Bosch O2 sensors might be bad.
Old 13th August 2010, 13:03   #394
Shan2nu's Avatar
Thanked: 87 Times
I've got a vehicle speed sensor error on my car. Engine check light has come one, speedo/odo/trip meters not working.
VTEC disabled (checked it with a diagnostic device).
Honda charges 1,500 to fix it (including labour)
PS : I was under the impression the low profile cams were very sedate and designed for economy.....i couldn't have been more wrong. The damn thing still takes off like a rocket!!!
A "vtec-disabled" vbox test on the cards, next time i'm in Blore.
Shan2nu
Old 13th August 2010, 16:03   #395
pranavt's Avatar
Thanked: 273 Times
Shan2nu, need a VSS? I'm coincidentally converting to an electronic VSS. The torque curve flattens after around 5k though.
Old 14th August 2010, 12:44   #396
ankitahuja's Avatar
Thanked: 46 Times
Shan2nu
How does one cure this problem? I've the VSS error since over 2 months now and not touching it. Just need a speedo cable replacement and a hard reset for the ECU. What's your take on this?
Old 14th August 2010, 12:52   #397
toiingg's Avatar
Thanked: 73 Times
Guys, i thinking of changing all 4 shocks. How much damage am I looking at ? My local mech quoted me 2.5k each + labour.
toiingg is offline   Reply With Quote
Old 14th August 2010, 14:00   #398
pranavt's Avatar
Thanked: 273 Times
Ankit, either the cable or the complete VSS that bolts into the transmission.
Old 17th August 2010, 01:46   #399
ankitahuja's Avatar
Thanked: 46 Times
Hmmm. Had the same problem few years back. Replacing the cable did it. Cost was less than Rs 300.
What might be the cost of VSS? Available on the net? ;-)
Old 17th August 2010, 02:39   #400
pranavt's Avatar
Thanked: 273 Times
Free for you, will have one available when I switch to an electronic VSS. Single bolt, mounted to the transmission bell-housing. Let me know if you want it.
Old 17th August 2010, 12:47   #401
Thanked: 102 Times
What is electronic VSS? Sorry if the question is too basic.
saurabhkum is offline   Reply With Quote
Old 17th August 2010, 13:57   #402
pranavt's Avatar
Thanked: 273 Times
The Vehicle Speed Sensor bolts to the transmission and gets the speed from there. Our Indian OHC came with an analog cable-driven VSS. Since I am switching to a different speedo cluster from a JDM Honda Integra, I need to change to an electronic VSS since the cluster does not support the analog cable-driven VSS. (The part that mates to the transmission is the same, but instead of a cable, the speed is transmitted electronically via a wire.)
Old 18th August 2010, 10:57   #403
johnda's Avatar
Thanked: 11 Times
so that means the whole unit..? or jus the sensor, didn't quite follow it sorry.
if its the whole 'cluster' can you upload a pic.
johnda is offline   Reply With Quote
Old 18th August 2010, 11:08   #404
pranavt's Avatar
Thanked: 273 Times
http://www.team-bhp.com/forum/1946433-post154.html
Old 19th August 2010, 10:58   #405
johnda's Avatar
Thanked: 11 Times
thanks..wonderful. the Speedo cluster looks neat. does it fit like a glove or do you have to make any adjustments? I guess this is not the thread to ask or make mention..
4th Gen Honda City i-VTEC Manual - 1st year ownership report tejas08 Test-Drives & Initial Ownership Reports 42 12th November 2017 20:32
1st-gen Honda City: Adjustable Coilovers, Raceconcepts intake + exhaust and more bhuvan_prasad Modifications & Accessories 15 15th January 2015 20:02
DIY: 1st-Gen Honda City Door Panel Removal bowser DIY - Do it yourself 5 30th October 2014 00:18
Things I need to specifically look for in a 1st-gen Honda City Vtec Rice_tuner Sedans 8 16th June 2008 19:52
honda city (new) (old) and mitsubishi lancer fuel efficiency devarshi84 The Indian Car Scene 3 19th July 2005 12:39
